ethDreamer Posted September 9, 2019 Posted September 9, 2019 I've been working on a project to boot a custom kernel on my NanoPC-T4. I haven't gotten too far though because as soon as I make the smallest change to the source, everything goes to hell (see below). I've built 3 images following EXACTLY the same process. All I did was change the KERNELBRANCH variable in userpatches/lib.config to point to different branches in the same repository. For completeness, here's my lib.config (which simply points to my fork of ayufan-rock64/linux-mainline-kernel): KERNELSOURCE='https://github.com/ethDreamer/linux-mainline-kernel' KERNELBRANCH='branch:BRANCHNAME' Here's the script I wrote to ensure everything was built exactly the same way: #!/bin/bash for branch in master vanillacopy tinychange ; do # restart the box vagrant halt && sleep 5 && vagrant up # cleanup old build vagrant ssh -c 'cd armbian && sudo rm -r ./cache/sources/linux-rockchip64 ./output/images/Armbian*.img*' # edit lib.config sed -i ./userpatches/lib.config -e "s/branch:.*/branch:${branch}\'/" # build the image vagrant ssh -c 'cd armbian && sudo ./compile.sh BOARD=nanopct4 BRANCH=dev RELEASE=buster\ BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no' # move the image mkdir -p ../outimages/${branch} && mv output/images/*img ../outimages/${branch}/ && \ cp ./userpatches/lib.config ../outimages/${branch}/ done You can see from github that my fork is identical to ayufan's upstream fork; I've made NO CHANGES. Then I created 2 extra branches off of master: vanillacopy and tinychange. The first branch (vanillacopy) like the name implies, is simply a copy of master with no changes. The second branch tinychange contains one tiny change (click to see diff). All I wanted to do was change the kernel's release string that's output by uname -r so that I could be sure I had booted my kernel.RESULTS: the kernels built with master and vanillacopy boot just fine. When booting the image with the kernel built from the tinychange branch: HDMI output stops working networking stops working board takes FOREVER to boot I wouldn't even know it booted without the serial console which stops displaying output after booting the kernel (any kernel) and only resumes output once the system has fully boot on the bright side, the uname string did change: Quote root@nanopct4:~# uname -a Linux nanopct4 5.3.0-rc4-rk3399_eth #5.96 SMP PREEMPT Sun Sep 8 20:20:43 UTC 2019 aarch64 GNU/Linux I can't see how this could possibly break everything like this.. what the hell am I missing?
ethDreamer Posted September 9, 2019 Author Posted September 9, 2019 dmesg.tinychange.log dmesg.vanillacopy.log
