rellla Posted June 22, 2016 Posted June 22, 2016 No, just default settings should be enough. You don't need the whole UMP or CMA stuff. Use ve_mem_reserve instead. You can just use a ready made armbian Server image and then build the other packages by yourself.. No need to build the kernel afaik.
RagnerBG Posted June 22, 2016 Posted June 22, 2016 To let Mali and the VE use the same memory area for zerocopy features in the future (for the upcoming vdpau_gles_interop feature e.g.) you need to use UMP with CMA memory as backend. I am curious - what is vdpau_gles_interop? What are the advantages against regular libvdpau-sunxi? I already saw so called "libvdpau-sunxi (gles interop)" from your page. Can i use it ? Is there any requirements for building and installations, or everything needed is in the link? Could you give me a correct way or link how to install libvpau propelry? Thanks, Sp0T I always build Armbian kernel/image with CMA = Y and set it to 192Mb: CONFIG_CMA=y # CONFIG_CMA_DEBUG is not set # # Default contiguous memory area size: # CONFIG_CMA_SIZE_MBYTES=192 CONFIG_CMA_SIZE_SEL_MBYTES=y # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set # CONFIG_CMA_SIZE_SEL_MIN is not set # CONFIG_CMA_SIZE_SEL_MAX is not set CONFIG_CMA_ALIGNMENT=8 CONFIG_CMA_AREAS=7 Then remove all sunxi memory restrictions from boot.scr file (remove "sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16" from boot.cmd, then "sudo mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr") and leave everything to be auto/dynamically allocated. As for libvdpau/libvdpau-sunxi i am using the following order for master branch, as it is in README: sudo apt-get update sudo apt-get install va-driver-all vdpau-va-driver wget http://ftp.de.debian.org/debian/pool/main/libv/libvdpau/libvdpau1_1.1.1-3_armhf.deb wget http://ftp.de.debian.org/debian/pool/main/libv/libvdpau/libvdpau-dev_1.1.1-3_armhf.deb wget http://ftp.de.debian.org/debian/pool/main/v/vdpauinfo/vdpauinfo_1.0-1+b1_armhf.deb sudo dpkg -i *.deb git clone https://github.com/linux-sunxi/libcedrus.git cd libcedrus make sudo make install sudo ldconfig cd .. http://www.pixman.org/ wget http://cairographics.org/releases/pixman-0.34.0.tar.gz tar -xzvf pixman-0.34.0.tar.gz cd pixman-0.34.0 ./configure make -j2 sudo make install cd .. git clone https://github.com/linux-sunxi/libvdpau-sunxi.git cd libvdpau-sunxi make sudo make install export VDPAU_DRIVER=sunxi export VDPAU_OSD=1 Pixman may not be needed for A10/20, but it's in requirements. If you go for rellla's branch, you need to install libcsptr . I also add "export" lines in the following files: sudo nano /etc/environment sudo nano /home/"user"/.bashrc sudo nano /etc/X11/Xsession.d/90environment And you also need proper permissions for some files like disp, ump, cedar_dev. I have to note - this is my way of doing things, that i found workable. It's far from good, but is sufficient.
rellla Posted June 22, 2016 Posted June 22, 2016 gles_interop is a hack, to try to imitate nv_gl_interop (<- you can google for that) That is a feature, which original nvidia vdpau implements, that lets you use vdpau surfaces as textures you can render to and/or display them with your app using OpenGL. Or render to them and give them back to vdpau to display them. I began to implement this for sunxi and opengl/es, also user mosterta did this. It can be useful for kodi and VDR for example, to name 2 apps which can use this. But this is all very WIP and just necessary if your app depends on that feature or profits from that. For MPV e.g. this is not needed. Yo sum up, for this feature you need ump memory provider using CMA, because you need to memory between Mali and the VE for doing zerocopy and not have to do memcpy. Because that would be slow. Regards
RagnerBG Posted June 23, 2016 Posted June 23, 2016 I got the idea, but even mentioning kodi make this dеsirаble. I am unable to build kodi for A20 so far. Except CMA enabled, is there anything else, your libvdpau-sunxi (gles interop) require? Are those patches necessary: https://github.com/mosterta/linux-sunxi/commit/563e0154269acffaa36ec3b678e4b35cbf7ee1c0.patch https://github.com/mosterta/linux-sunxi/commit/67de2b9320eeb1fe205d29a49742919c1613da68.patch or only CMA is enough? Thank you.
rellla Posted June 23, 2016 Posted June 23, 2016 Those patches are already included in armbian kernel. What do you want to do with my gles libvdpau branch?? It's far away from useable. You don't need to try it, because kodi is not working. You need a special kodi version. It's all W(ork)I(n)P(rogress)!! If you want to help developing, please tell me, but we are still not at the point for testing it. Though if anybody has DVB hardware and want to try www.tvdr.de using this feature, let me know. Regards rellla
RagnerBG Posted June 23, 2016 Posted June 23, 2016 I was thinking of trying again this . Last time i tried everything in the topic, but always failed with mosterta libvdpau-sunxi. But if you say it's WIP - ok. Thanks for the patience with my noob questions.
rellla Posted June 23, 2016 Posted June 23, 2016 Mosterta is working on a new implementation afaik. So stay tuned and be patient. My vdpau gles does not work with kodi. It should (basically) with vdr. But the dependencies are the same (kernel, libump...). The instructions in the kodi thread are missing a few bits still... Regards rellla
Sp0T Posted June 28, 2016 Author Posted June 28, 2016 Hello Rellla, I tried to install softhddevice and i run into the following error: root@orange:/usr/local/src/vdr-sunxi# make (export PKG_CONFIG_PATH=/usr/lib/arm-linux-gnueabihf/pkgconfig; cd VDR; make all) make[1]: Entering directory '/usr/local/src/vdr-sunxi/tmp/vdr-2.2.0' *** Plugin dvbhddevice: make[2]: Nothing to be done for 'all'. *** Plugin dvbsddevice: make[2]: Nothing to be done for 'all'. *** Plugin epgtableid0: make[2]: Nothing to be done for 'all'. *** Plugin hello: make[2]: Nothing to be done for 'all'. *** Plugin osddemo: make[2]: Nothing to be done for 'all'. *** Plugin pictures: make[2]: Nothing to be done for 'all'. *** Plugin rcu: make[2]: Nothing to be done for 'all'. *** Plugin remoteosd: make[2]: Nothing to be done for 'all'. *** Plugin remotetimers: make[2]: Nothing to be done for 'all'. *** Plugin servicedemo: make[2]: Nothing to be done for 'all'. *** Plugin skincurses: make[2]: Nothing to be done for 'all'. *** Plugin skindesigner: make -C libskindesignerapi *** Plugin softhddevice: Package glu was not found in the pkg-config search path. Perhaps you should add the directory containing `glu.pc' to the PKG_CONFIG_PATH environment variable Package 'glu', required by 'glew', not found g++ -pipe -O2 -mfloat-abi=hard -mtune=cortex-a8 -mcpu=cortex-a8 -D__ARM_NEON__ -mfpu=neon -march=armv7-a -fPIC -Werror=overloaded-virtual -Wno-parentheses -fsigned-char -fPIC -fPIC -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -I/usr/include/alsa -I/usr/local/include -I/usr/local/include -I/usr/include/freetype2 -I/usr/local/include -DPLUGIN_NAME_I18N='"softhddevice"' -D_GNU_SOURCE -DAV_INFO -DAV_INFO_TIME=3000 -DUSE_PIP -DUSE_MPEG_COMPLETE -DH264_EOS_TRICKSPEED -DUSE_VDR_SPU -DUSE_ALSA -DUSE_OSS -DUSE_VDPAU -DUSE_SCREENSAVER -DUSE_SWRESAMPLE -DUSE_OPENGLOSD -DGIT_REV='"2259084"' -I/usr/local/src/vdr-sunxi/tmp/vdr-2.2.0/include -g -W -Wall -Wextra -Winit-self -Werror=overloaded-virtual -std=c++11 -pipe -O2 -mfloat-abi=hard -mtune=cortex-a8 -mcpu=cortex-a8 -D__ARM_NEON__ -mfpu=neon -march=armv7-a -fPIC -Werror=overloaded-virtual -Wno-parentheses -fsigned-char -fPIC -c -o softhddevice.o softhddevice.cpp Package glu was not found in the pkg-config search path. Perhaps you should add the directory containing `glu.pc' to the PKG_CONFIG_PATH environment variable Package 'glu', required by 'glew', not found Package glu was not found in the pkg-config search path. Perhaps you should add the directory containing `glu.pc' to the PKG_CONFIG_PATH environment variable Package 'glu', required by 'glew', not found In file included from openglosd.h:7:0, from softhddevice.cpp:41: /usr/include/GL/glew.h:1205:24: fatal error: GL/glu.h: No such file or directory # include <GL/glu.h> ^ compilation terminated. <builtin>: recipe for target 'softhddevice.o' failed make[2]: *** [softhddevice.o] Error 1 *** Plugin status: make[2]: Nothing to be done for 'all'. *** Plugin streamdev: make -C ./tools make[3]: 'sockettools.a' is up to date. make -C ./client make[3]: Nothing to be done for 'all'. make -C ./tools make[3]: 'sockettools.a' is up to date. make -C ./libdvbmpeg make[3]: 'libdvbmpegtools.a' is up to date. make -C ./remux make[3]: 'remux.a' is up to date. make -C ./server make[3]: Nothing to be done for 'all'. *** Plugin svdrpdemo: make[2]: Nothing to be done for 'all'. *** Plugin svdrposd: make[2]: Nothing to be done for 'all'. *** Plugin svdrpservice: make[2]: Nothing to be done for 'all'. *** failed plugins: softhddevice Makefile:210: recipe for target 'plugins' failed make[1]: *** [plugins] Error 1 make[1]: Leaving directory '/usr/local/src/vdr-sunxi/tmp/vdr-2.2.0' Makefile:12: recipe for target 'all' failed make: *** [all] Error 2 root@orange:/usr/local/src/vdr-sunxi# Could you please help. Thanks, Sp0T
zador.blood.stained Posted June 28, 2016 Posted June 28, 2016 Package glu was not found in the pkg-config search path. Perhaps you should add the directory containing `glu.pc' to the PKG_CONFIG_PATH environment variable Package 'glu', required by 'glew', not found Package glu was not found in the pkg-config search path. Perhaps you should add the directory containing `glu.pc' to the PKG_CONFIG_PATH environment variable ➜ ~ % apt-file search glu.pc libglu1-mesa-dev: /usr/lib/arm-linux-gnueabihf/pkgconfig/glu.pc So you probably need to install libglu1-mesa-dev package 1
rellla Posted June 28, 2016 Posted June 28, 2016 1) use https://github.com/rellla/softhddevice-openglosd/tree/glesas source for the softhddevice plugin 2) compile it with "GLES2=1 make" Glut is needed for the opengl version. We are on arm, we don't have that. And be aware: it's WIP! Didn't I say that already ? 1
Sp0T Posted June 28, 2016 Author Posted June 28, 2016 @zador.blood.stained Thank you it's worked @rellla I installed that repo. I followed the wiki page you linked. Than i got that error so i installed glut. Also in the openglosd at line 1632 this runs on error: "this->bcolor = BORDERCOLOR;" so i commented out in the cpp. now i have corruped decoder error problem with "libavcodec_plugin.so tried with vlc" @RagnerBG Tomorrow i'll try your method. Looks faster . But i don't want to build a whole os my virtual server is bad so i stick to mem_reserv.
rellla Posted June 29, 2016 Posted June 29, 2016 @Sp0T: Why do you ignore what I suggest? Installing libglu1-mesa-dev may mess up your system. You DON'T need it. Meaning, you must not install it. The original softhddevice-openglosd was designed for OpenGL on i386 machines and is using glut. We don't have i386, we are on ARM. And so we don't have OpenGL, we have OpenGL/ES. Therefore, you have to check out the "gles" branch of my repo and compile it with the environment variable GLES2 set to 1. Otherwise you will run into issues. But do you really need that? What do you intend to do with libvdpau-sunxi? If you don't want to use VDR, you can drop that gles thing at all?? @Sp0T, @RagnerBG: And regarding kodi, mosterta was doing a rewrite of a sunxi-kodi implementation (a newer one of the one you linked). I don't know if it's finished yet, at least for noobs there is a documentation missing. So please be patient and don't waste your time with needless efforts. Except you know what you are doing, or at least know, that you will run into issues. And please, the most important one, don't use the kodi implementation that uses binary blobs or GPL violating allwinner code. Thanks. I think, this topic goes far away from "black screen mpv player", it got more general, but it's your topic, Sp0t Regards PS: It's really time to set up the automatic deb creation of the media related packages....
Sp0T Posted June 29, 2016 Author Posted June 29, 2016 @rellla I'm not ignoring what you suggest i'm following the instructions what you made here http://linux-sunxi.org/User:Rellla/Armbian. There are some parts when i run on error and ask suggestion here. Sometimes i get good ones sometimes i mess up the whole thing. All i would like to do is play videos with my Orange PI. The fastest way is if i install the desktop version but there i run into the black screen problem, that is why i would like to build my own desktop from the begining. Linux is new for me but i'm not afraid from failures also not noob for programing. I'll try it again till i wont succeed. I'm also very grateful that you help me, i know you have other things to do . Regards, Sp0T
rellla Posted June 29, 2016 Posted June 29, 2016 I just gave that statement because it looks like some try-and-error ... And using this mechanism within WIP code may not be fun ... Ok. Let's start from the beginning, according my armbian install protocol 1) Take a armbian server image 2) Get a H3 kernel, which re-enables fb_wait_for_vsync, you probably have to do that by yourself ..., the other CMA related tweaks are not needed if you don't use UMP and don't set CMA 3) Build xf86-video-fbturbo, libcsptr, libvdpau, ffmpeg, libcedrus (without USE_UMP=1), libvdpau-sunxi (upstream) <- you may use the dev branch, and finally mpv 4) You don't need: libump, sunxi-mali, libvdpau-sunxi (glesinterop), vdr, softhddevice-openglosd (gles interop), vlc 5) make sure ve_mem_reserve is set to a big enough value. I don't know if that is used on H3, or if /dev/ion is used instead 6) make sure the you have the needed rights for /dev/disp, /dev/cedar_dev (and maybe /dev/ion) 7) export VDPAU_DRIVER=sunxi 8) start X in background: X & 9) run mpv That hopefully should be enough. You should use my "brain protocol" together with (the partly outdated) http://linux-sunxi.org/Cedrus/libvdpau-sunxi If you want, you can also try vlc. I did not yet. Would be glad to find a tester Regards rellla
Sp0T Posted June 29, 2016 Author Posted June 29, 2016 Just a question. H3 kernel for A20?. And sure i'll test vlc
rellla Posted June 29, 2016 Posted June 29, 2016 Ah, no. I thought, OrangePI is H3. If not, then A20 for sure So you can use armbian default kernel.
RagnerBG Posted June 29, 2016 Posted June 29, 2016 And regarding kodi, mosterta was doing a rewrite of a sunxi-kodi implementation (a newer one of the one you linked). I don't know if it's finished yet, at least for noobs there is a documentation missing. So please be patient and don't waste your time with needless efforts. Except you know what you are doing, or at least know, that you will run into issues. And please, the most important one, don't use the kodi implementation that uses binary blobs or GPL violating allwinner code. Thanks. Thanks for the info, i will follow the progress for sure . Meanwhile, as we already escape from the point of the topic, i started to use your commit of libvdpau-sunxi - https://github.com/rellla/libvdpau-sunxi/commit/271c27b7eeea31a33dea9f39a025bdca89d8243b, but on my H3 devices, to check if bright, contrast, saturation and hue can be adjusted. Because with master branch non of this worked. But it doesn't work either. I tried on mpv player. Of course H3's doesn't need this to be adjustable in common cases, because the picture is bright enough, but i can't try this on my A20 for the moment and it use to work with the latest master branch i installed. My question is - should this fixes work on H3 or are only for A10/20 versions of libvdpau-sunxi? Except of this, there are no issues with your commit, CPU load is very low, almost non existed . Unfortunately i can't provide more info and/or logs sooner, because i put myself in some adventure to start dealing with Xenial version of Armbian and trying to make it the way i used from scratch, with not much success so far. Maybe i will just go back to Jessie...
rellla Posted June 29, 2016 Posted June 29, 2016 The CSC thing is only related to A10/A20. Adjustement of bright,... is not possible on H3 at the moment, because it's not implemented in the H3 display code of libvdpau-sunxi... This code: https://github.com/linux-sunxi/libvdpau-sunxi/blob/dev/sunxi_disp.c#L259is missing in sunxi_disp15.c and sunxi_disp2.c . So any changes won't have any effect. With or without the csc patch. I forgot that to mention Regards
zador.blood.stained Posted June 30, 2016 Posted June 30, 2016 @rellla It may be a little bit offtopic, but is this config for ffmpeg good for creating packages for Armbian? Command line (Ubuntu default + --enable-vdpau) CONFIG := --prefix=/usr \ --extra-version="$(DEB_REVISION)" \ --build-suffix="-ffmpeg" \ --toolchain=hardened \ --libdir=/usr/lib/$(DEB_HOST_MULTIARCH) \ --incdir=/usr/include/$(DEB_HOST_MULTIARCH) \ --cc=$(CC) \ --cxx=$(CXX) \ --enable-gpl \ --enable-shared \ --disable-stripping \ --disable-decoder=libopenjpeg \ --disable-decoder=libschroedinger \ --enable-avresample \ --enable-avisynth \ --enable-gnutls \ --enable-ladspa \ --enable-libass \ --enable-libbluray \ --enable-libbs2b \ --enable-libcaca \ --enable-libcdio \ --enable-libflite \ --enable-libfontconfig \ --enable-libfreetype \ --enable-libfribidi \ --enable-libgme \ --enable-libgsm \ --enable-libmodplug \ --enable-libmp3lame \ --enable-libopenjpeg \ --enable-libopus \ --enable-libpulse \ --enable-librtmp \ --enable-libschroedinger \ --enable-libshine \ --enable-libsnappy \ --enable-libsoxr \ --enable-libspeex \ --enable-libssh \ --enable-libtheora \ --enable-libtwolame \ --enable-libvorbis \ --enable-libvpx \ --enable-libwavpack \ --enable-libwebp \ --enable-libx265 \ --enable-libxvid \ --enable-libzvbi \ --enable-openal \ --enable-opengl \ --enable-x11grab \ --enable-vdpau Configuration log install prefix /usr source path /root/build/ffmpeg C compiler cc C library glibc ARCH arm (armv7-a) build suffix -ffmpeg version string suffix 1ubuntu2~armbian5.14+1 big-endian no runtime cpu detection yes ARMv5TE enabled yes ARMv6 enabled yes ARMv6T2 enabled yes VFP enabled yes NEON enabled yes THUMB enabled yes debug symbols yes strip symbols no optimize for size no optimizations yes static yes shared yes postprocessing support yes new filter support yes network support yes threading support pthreads safe bitstream reader yes SDL support yes opencl enabled no JNI support no texi2html enabled no perl enabled yes pod2man enabled yes makeinfo enabled yes makeinfo supports HTML yes Enabled programs: ffmpeg ffprobe ffserver ffplay External libraries: avisynth libiec61883 libvpx bzlib libmodplug libwavpack frei0r libmp3lame libwebp gnutls libopencv libx264 iconv libopenjpeg libx265 ladspa libopus libxcb libass libpulse libxcb_shape libbluray librtmp libxcb_shm libbs2b libschroedinger libxcb_xfixes libcaca libshine libxvid libcdio libsnappy libzvbi libdc1394 libsoxr lzma libflite libspeex openal libfontconfig libssh opengl libfreetype libtheora sdl libfribidi libtwolame xlib libgme libvorbis zlib libgsm External libraries providing hardware acceleration: vaapi vdpau xvmc Libraries: avcodec avformat postproc avdevice avresample swresample avfilter avutil swscale Enabled decoders: aac avrn fic aac_fixed avrp flac aac_latm avs flashsv aasc avui flashsv2 ac3 ayuv flic ac3_fixed bethsoftvid flv adpcm_4xm bfi fourxm adpcm_adx bink fraps adpcm_afc binkaudio_dct frwu adpcm_aica binkaudio_rdft g2m adpcm_ct bintext g723_1 adpcm_dtk bmp g729 adpcm_ea bmv_audio gif adpcm_ea_maxis_xa bmv_video gsm adpcm_ea_r1 brender_pix gsm_ms adpcm_ea_r2 c93 h261 adpcm_ea_r3 cavs h263 adpcm_ea_xas ccaption h263i adpcm_g722 cdgraphics h263p adpcm_g726 cdxl h264 adpcm_g726le cfhd h264_vdpau adpcm_ima_amv cinepak hap adpcm_ima_apc cljr hevc adpcm_ima_dat4 cllc hnm4_video adpcm_ima_dk3 comfortnoise hq_hqa adpcm_ima_dk4 cook hqx adpcm_ima_ea_eacs cpia huffyuv adpcm_ima_ea_sead cscd iac adpcm_ima_iss cyuv idcin adpcm_ima_oki dca idf adpcm_ima_qt dds iff_ilbm adpcm_ima_rad dfa imc adpcm_ima_smjpeg dirac indeo2 adpcm_ima_wav dnxhd indeo3 adpcm_ima_ws dpx indeo4 adpcm_ms dsd_lsbf indeo5 adpcm_mtaf dsd_lsbf_planar interplay_acm adpcm_psx dsd_msbf interplay_dpcm adpcm_sbpro_2 dsd_msbf_planar interplay_video adpcm_sbpro_3 dsicinaudio jacosub adpcm_sbpro_4 dsicinvideo jpeg2000 adpcm_swf dss_sp jpegls adpcm_thp dst jv adpcm_thp_le dvaudio kgv1 adpcm_vima dvbsub kmvc adpcm_xa dvdsub lagarith adpcm_yamaha dvvideo libgsm aic dxa libgsm_ms alac dxtory libopus alias_pix dxv libspeex als eac3 libvorbis amrnb eacmv libvpx_vp8 amrwb eamad libvpx_vp9 amv eatgq libzvbi_teletext anm eatgv loco ansi eatqi m101 ape eightbps mace3 apng eightsvx_exp mace6 ass eightsvx_fib magicyuv asv1 escape124 mdec asv2 escape130 metasound atrac1 evrc microdvd atrac3 exr mimic atrac3p ffv1 mjpeg aura ffvhuff mjpegb aura2 ffwavesynth mlp mmvideo pcm_s8_planar svq1 motionpixels pcm_u16be svq3 movtext pcm_u16le tak mp1 pcm_u24be targa mp1float pcm_u24le targa_y216 mp2 pcm_u32be tdsc mp2float pcm_u32le text mp3 pcm_u8 theora mp3adu pcm_zork thp mp3adufloat pcx tiertexseqvideo mp3float pgm tiff mp3on4 pgmyuv tmv mp3on4float pgssub truehd mpc7 pictor truemotion1 mpc8 pjs truemotion2 mpeg1_vdpau png truemotion2rt mpeg1video ppm truespeech mpeg2video prores tscc mpeg4 prores_lgpl tscc2 mpeg4_vdpau ptx tta mpeg_vdpau qcelp twinvq mpeg_xvmc qdm2 txd mpegvideo qdraw ulti mpl2 qpeg utvideo msa1 qtrle v210 msmpeg4v1 r10k v210x msmpeg4v2 r210 v308 msmpeg4v3 ra_144 v408 msrle ra_288 v410 mss1 ralf vb mss2 rawvideo vble msvideo1 realtext vc1 mszh rl2 vc1_vdpau mts2 roq vc1image mvc1 roq_dpcm vcr1 mvc2 rpza vmdaudio mxpeg rscc vmdvideo nellymoser rv10 vmnc nuv rv20 vorbis on2avc rv30 vp3 opus rv40 vp5 paf_audio s302m vp6 paf_video sami vp6a pam sanm vp6f pbm screenpresso vp7 pcm_alaw sdx2_dpcm vp8 pcm_bluray sgi vp9 pcm_dvd sgirle vplayer pcm_f32be sheervideo vqa pcm_f32le shorten wavpack pcm_f64be sipr webp pcm_f64le smackaud webvtt pcm_lxf smacker wmalossless pcm_mulaw smc wmapro pcm_s16be smvjpeg wmav1 pcm_s16be_planar snow wmav2 pcm_s16le sol_dpcm wmavoice pcm_s16le_planar sonic wmv1 pcm_s24be sp5x wmv2 pcm_s24daud srt wmv3 pcm_s24le ssa wmv3_vdpau pcm_s24le_planar stl wmv3image pcm_s32be subrip wnv1 pcm_s32le subviewer ws_snd1 pcm_s32le_planar subviewer1 xan_dpcm pcm_s8 sunrast xan_wc3 xan_wc4 xma2 yuv4 xbin xsub zero12v xbm xwd zerocodec xface y41p zlib xl ylc zmbv xma1 yop Enabled encoders: a64multi libopus pcm_u8 a64multi5 libschroedinger pcx aac libshine pgm ac3 libspeex pgmyuv ac3_fixed libtheora png adpcm_adx libtwolame ppm adpcm_g722 libvorbis prores adpcm_g726 libvpx_vp8 prores_aw adpcm_ima_qt libvpx_vp9 prores_ks adpcm_ima_wav libwavpack qtrle adpcm_ms libwebp r10k adpcm_swf libx264 r210 adpcm_yamaha libx264rgb ra_144 alac libx265 rawvideo alias_pix libxvid roq amv ljpeg roq_dpcm apng mjpeg rv10 ass movtext rv20 asv1 mp2 s302m asv2 mp2fixed sgi avrp mpeg1video snow avui mpeg2video sonic ayuv mpeg4 sonic_ls bmp msmpeg4v2 srt cinepak msmpeg4v3 ssa cljr msvideo1 subrip comfortnoise nellymoser sunrast dca pam svq1 dnxhd pbm targa dpx pcm_alaw text dvbsub pcm_f32be tiff dvdsub pcm_f32le tta dvvideo pcm_f64be utvideo eac3 pcm_f64le v210 ffv1 pcm_mulaw v308 ffvhuff pcm_s16be v408 flac pcm_s16be_planar v410 flashsv pcm_s16le vc2 flashsv2 pcm_s16le_planar vorbis flv pcm_s24be wavpack g723_1 pcm_s24daud webvtt gif pcm_s24le wmav1 h261 pcm_s24le_planar wmav2 h263 pcm_s32be wmv1 h263p pcm_s32le wmv2 h264_vaapi pcm_s32le_planar wrapped_avframe hap pcm_s8 xbm huffyuv pcm_s8_planar xface jpeg2000 pcm_u16be xsub jpegls pcm_u16le xwd libgsm pcm_u24be y41p libgsm_ms pcm_u24le yuv4 libmp3lame pcm_u32be zlib libopenjpeg pcm_u32le zmbv Enabled hwaccels: h263_vaapi mpeg2_vaapi vc1_vaapi h264_vaapi mpeg2_vdpau vc1_vdpau h264_vdpau mpeg2_xvmc wmv3_vaapi mpeg1_vdpau mpeg4_vaapi wmv3_vdpau mpeg1_xvmc mpeg4_vdpau Enabled parsers: aac dvd_nav mpegvideo aac_latm dvdsub opus ac3 flac png adx g729 pnm bmp gsm rv30 cavsvideo h261 rv40 cook h263 tak dca h264 vc1 dirac hevc vorbis dnxhd mjpeg vp3 dpx mlp vp8 dvaudio mpeg4video vp9 dvbsub mpegaudio Enabled demuxers: aa flac matroska aac flic mgsts ac3 flv microdvd acm fourxm mjpeg act frm mlp adf fsb mlv adp g722 mm ads g723_1 mmf adx g729 mov aea genh mp3 afc gif mpc aiff gsm mpc8 aix gxf mpegps amr h261 mpegts anm h263 mpegtsraw apc h264 mpegvideo ape hevc mpjpeg apng hls mpl2 aqtitle hnm mpsub asf ico msf asf_o idcin msnwc_tcp ass idf mtaf ast iff mtv au ilbc musx avi image2 mv avisynth image2_alias_pix mvi avr image2_brender_pix mxf avs image2pipe mxg bethsoftvid image_bmp_pipe nc bfi image_dds_pipe nistsphere bfstm image_dpx_pipe nsv bink image_exr_pipe nut bintext image_j2k_pipe nuv bit image_jpeg_pipe ogg bmv image_jpegls_pipe oma boa image_pam_pipe paf brstm image_pbm_pipe pcm_alaw c93 image_pcx_pipe pcm_f32be caf image_pgm_pipe pcm_f32le cavsvideo image_pgmyuv_pipe pcm_f64be cdg image_pictor_pipe pcm_f64le cdxl image_png_pipe pcm_mulaw cine image_ppm_pipe pcm_s16be concat image_qdraw_pipe pcm_s16le data image_sgi_pipe pcm_s24be daud image_sunrast_pipe pcm_s24le dcstr image_tiff_pipe pcm_s32be dfa image_webp_pipe pcm_s32le dirac ingenient pcm_s8 dnxhd ipmovie pcm_u16be dsf ircam pcm_u16le dsicin iss pcm_u24be dss iv8 pcm_u24le dts ivf pcm_u32be dtshd ivr pcm_u32le dv jacosub pcm_u8 dvbsub jv pjs dvbtxt libgme pmp dxa libmodplug pva ea live_flv pvf ea_cdata lmlm4 qcp eac3 loas r3d epaf lrc rawvideo ffm lvf realtext ffmetadata lxf redspark filmstrip m4v rl2 rm str vobsub roq subviewer voc rpl subviewer1 vpk rsd sup vplayer rso svag vqf rtp swf w64 rtsp tak wav sami tedcaptions wc3 sap thp webm_dash_manifest sbg threedostr webvtt sdp tiertexseq wsaud sdr2 tmv wsd segafilm truehd wsvqa shorten tta wtv siff tty wv sln txd wve smacker v210 xa smjpeg v210x xbin smush vag xmv sol vc1 xvag sox vc1t xwma spdif vivo yop srt vmd yuv4mpegpipe stl Enabled muxers: a64 image2 pcm_s24le ac3 image2pipe pcm_s32be adts ipod pcm_s32le adx ircam pcm_s8 aiff ismv pcm_u16be amr ivf pcm_u16le apng jacosub pcm_u24be asf latm pcm_u24le asf_stream lrc pcm_u32be ass m4v pcm_u32le ast matroska pcm_u8 au matroska_audio psp avi md5 rawvideo avm2 microdvd rm bit mjpeg roq caf mkvtimestamp_v2 rso cavsvideo mlp rtp crc mmf rtp_mpegts dash mov rtsp data mp2 sap daud mp3 segment dirac mp4 singlejpeg dnxhd mpeg1system smjpeg dts mpeg1vcd smoothstreaming dv mpeg1video sox eac3 mpeg2dvd spdif f4v mpeg2svcd spx ffm mpeg2video srt ffmetadata mpeg2vob stream_segment filmstrip mpegts swf flac mpjpeg tee flv mxf tg2 framecrc mxf_d10 tgp framehash mxf_opatom truehd framemd5 null uncodedframecrc g722 nut vc1 g723_1 oga vc1t gif ogg voc gsm oma w64 gxf opus wav h261 pcm_alaw webm h263 pcm_f32be webm_chunk h264 pcm_f32le webm_dash_manifest hash pcm_f64be webp hds pcm_f64le webvtt hevc pcm_mulaw wtv hls pcm_s16be wv ico pcm_s16le yuv4mpegpipe ilbc pcm_s24be Enabled protocols: async httpproxy mmst bluray https pipe cache icecast rtp concat librtmp sctp crypto librtmpe srtp data librtmps subfile file librtmpt tcp ftp librtmpte tls_gnutls gopher libssh udp hls md5 udplite http mmsh unix Enabled filters: abench bwdif frei0r_src acompressor cellauto fspp acrossfade channelmap geq adelay channelsplit gradfun adrawgraph chorus haldclut aecho chromakey haldclutsrc aemphasis ciescope hdcd aeval codecview hflip aevalsrc color highpass afade colorbalance histeq afftfilt colorchannelmixer histogram aformat colorkey hqdn3d agate colorlevels hqx ahistogram colormatrix hstack ainterleave colorspace hue alimiter compand hwdownload allpass compensationdelay hwupload allrgb concat idet allyuv convolution il aloop copy inflate alphaextract cover_rect interlace alphamerge crop interleave amerge cropdetect join ametadata curves kerndeint amix datascope ladspa amovie dcshift lenscorrection anequalizer dctdnoiz life anoisesrc deband loop anull decimate lowpass anullsink deflate lut anullsrc dejudder lut3d apad delogo lutrgb aperms deshake lutyuv aphasemeter detelecine mandelbrot aphaser dilation maskedmerge apulsator displace mcdeint arealtime drawbox mergeplanes aresample drawgraph metadata areverse drawgrid movie aselect drawtext mpdecimate asendcmd dynaudnorm mptestsrc asetnsamples earwax negate asetpts ebur128 nnedi asetrate edgedetect noformat asettb elbg noise ashowinfo eq null asplit equalizer nullsink ass erosion nullsrc astats extractplanes ocv astreamselect extrastereo overlay asyncts fade owdenoise atadenoise fftfilt pad atempo field palettegen atrim fieldhint paletteuse avectorscope fieldmatch pan bandpass fieldorder perms bandreject find_rect perspective bass firequalizer phase bbox flanger pixdesctest bench flite pp biquad format pp7 blackdetect fps psnr blackframe framepack pullup blend framerate qp boxblur framestep random bs2b frei0r readvitc realtime showspectrum swapuv remap showspectrumpic tblend removegrain showvolume telecine removelogo showwaves testsrc repeatfields showwavespic testsrc2 replaygain shuffleframes thumbnail resample shuffleplanes tile reverse sidechaincompress tinterlace rgbtestsrc sidechaingate transpose rotate signalstats treble sab silencedetect tremolo scale silenceremove trim scale2ref sine unsharp scale_vaapi smartblur uspp select smptebars vectorscope selectivecolor smptehdbars vflip sendcmd spectrumsynth vibrato separatefields split vignette setdar spp volume setfield ssim volumedetect setpts stereo3d vstack setsar stereotools w3fdif settb stereowiden waveform showcqt streamselect xbr showfreqs subtitles yadif showinfo super2xsai zoompan showpalette swaprect Enabled bsfs: aac_adtstoasc imx_dump_header mpeg4_unpack_bframes chomp mjpeg2jpeg noise dca_core mjpega_dump_header remove_extradata dump_extradata mov2textsub text2movsub h264_mp4toannexb mp3_header_decompress vp9_superframe hevc_mp4toannexb Enabled indevs: alsa lavfi oss dv1394 libcdio pulse fbdev libdc1394 v4l2 iec61883 openal x11grab_xcb jack Enabled outdevs: alsa opengl sdl caca oss v4l2 fbdev pulse xv Is there anything that can be disabled safely? Or is anything missing?
Sp0T Posted June 30, 2016 Author Posted June 30, 2016 @rella After i installed everything i got the following error: mpv: error while loading shared libraries: libavutil.so.55: cannot open shared object file: No such file or directory Than ldd ffmpeg: libavdevice.so.57 => not found libavfilter.so.6 => not found libavformat.so.57 => not found libavcodec.so.57 => not found libswresample.so.2 => not found libswscale.so.4 => not found libavutil.so.55 => not found libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xb6f36000) libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0xb6f13000) libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6e23000) /lib/ld-linux-armhf.so.3 (0xb6fab000) After this i curios if this file is missing or not so i checked the library /usr/local/lib and all the files where there. Can you help me in this? Thanks, Sp0T
zador.blood.stained Posted June 30, 2016 Posted June 30, 2016 @Sp0T After this i curios if this file is missing or not so i checked the library /usr/local/lib and all the files where there. Probably /usr/loca/lib in not in the library search path or you didn't run "ldconfig" after installation.
rellla Posted June 30, 2016 Posted June 30, 2016 @zador.blood.stained: This was my configure: ./configure --enable-shared --prefix=/usr/local Because i installed libvdpau first, it should be enabled during configure. So I suppose addind the vdpau flag should be safe. I didn't try to skip other packages... You have to care about ffmpeg depending on libvdpau then and care about the version, too. It's worth a try... @Sp0T: if the files are there and you have no other old files from another ffmpeg or libav version lying elsewhere, e.g. /use/lib , I just have the same suggestion as zador (<- I shortened your nick )
zador.blood.stained Posted June 30, 2016 Posted June 30, 2016 @zador.blood.stained: This was my configure: ./configure --enable-shared --prefix=/usr/local Yep, I saw that on https://linux-sunxi.org/User:Rellla/Armbian I just used default "debianization" files from Ubuntu, but I wonder if stuff like OpenAL, OpenGL, OpenCL, X11Grab is completely useless on Allwinner/Mali hardware. Because i installed libvdpau first, it should be enabled during configure. So I suppose addind the vdpau flag should be safe. I didn't try to skip other packages... You have to care about ffmpeg depending on libvdpau then and care about the version, too. It's worth a try... It won't hurt to enable it explicitly. And I don't have to care about dependencies because dpkg-shlibdeps does that automatically during build process. It's a try worth 3 hours of compilation time, but it should work.
Sp0T Posted June 30, 2016 Author Posted June 30, 2016 Yes that was the problem...i'm just tired. One question if i change libvdpau-sunxi (upstream) from dev to master do i have to rebuild mpv? Cause i got segmentation error with vdpau vo...With software decoding(x11) it works.
rellla Posted June 30, 2016 Posted June 30, 2016 No, you don't have to rebuild MPV. Only if your ffmpeg/libav version and corresponding headers changed. You have to build MPV against the headers of the corresponding ffmpeg version you will use the binary file of later... Maybe you messed up sth with libav/ffmpeg debs, headers, old versions, whatever. If a segfault occurs and you feel like having done everything right, a back trace may help. It's not sure, that there is some bug in libvdpau-sunxi though it's unlikely with the master branch. A great mess is, when different ffmpeg and/or libav versions are mixed up on the same system... It's a common thing I also often did already ... Did you really do everything from scratch from a clean server image without installing these media packages via apt?
Sp0T Posted June 30, 2016 Author Posted June 30, 2016 Yes, even my MATE desktop is only a core version, only thing i changed was the version of the mpv and ffmpeg i used the latest ones MPV: 0.18.0 FFMPEG: 3.1 I don't have any other media package installed only the suggested ones. Regards, Sp0T
rellla Posted June 30, 2016 Posted June 30, 2016 Hm, I have no clue so far. If upstream master does not work with MPV, I'm clueless. I have to do this from scratch myself, but at earliest next week. In the meantime you can get a backtrace
Sp0T Posted June 30, 2016 Author Posted June 30, 2016 Ok, i found the problem it was chmod i set it to 0660. Now i changed it to 777 and no segmentation fail...but we are back to black screen
rellla Posted June 30, 2016 Posted June 30, 2016 Bad. Dropping all my thoughts.... Are you using the right display? In the third post I read sth about :1.0 Shouldn't thus be :0.0 instead? Trying export DISPLAY=:0.0 ? Can you post your dmesg, too? If issue still remains, I'll give you special logging version tomorrow, to see where vdpau-sunxi is executed. Though I don't think anymore, that it's libvdpau-sunxi related...
Sp0T Posted June 30, 2016 Author Posted June 30, 2016 Display export not worked. dmesg [ 2780.989007] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2781.022238] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2781.105662] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2781.122407] [DISP] not supported image0 pixel sequence:208 in img_sw_para_to_reg [ 2781.172402] [DISP] not supported image0 pixel sequence:192 in img_sw_para_to_reg [ 2781.222392] [DISP] not supported image0 pixel sequence:192 in img_sw_para_to_reg [ 2781.255731] [DISP] not supported image0 pixel sequence:128 in img_sw_para_to_reg [ 2781.289105] [DISP] not supported image0 pixel sequence:232 in img_sw_para_to_reg [ 2781.355635] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2781.422395] [DISP] not supported image0 pixel sequence:135 in img_sw_para_to_reg [ 2781.455723] [DISP] not supported image0 pixel sequence:188 in img_sw_para_to_reg [ 2781.472240] [DISP] not supported image0 pixel sequence:8 in img_sw_para_to_reg [ 2781.489194] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2781.505738] [DISP] not supported image0 pixel sequence:196 in img_sw_para_to_reg [ 2781.572387] [DISP] not supported image0 pixel sequence:232 in img_sw_para_to_reg [ 2781.589065] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2781.622396] [DISP] not supported image0 pixel sequence:128 in img_sw_para_to_reg [ 2781.672395] [DISP] not supported image0 pixel sequence:188 in img_sw_para_to_reg [ 2781.789227] [DISP] not supported image0 pixel sequence:232 in img_sw_para_to_reg [ 2781.805752] [DISP] not supported image0 pixel sequence:216 in img_sw_para_to_reg [ 2781.939065] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2781.955758] [DISP] not supported image0 pixel sequence:232 in img_sw_para_to_reg [ 2782.005648] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2782.038983] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2782.055752] [DISP] not supported image0 pixel sequence:132 in img_sw_para_to_reg [ 2782.105729] [DISP] not supported image0 pixel sequence:112 in img_sw_para_to_reg [ 2782.189066] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2782.222401] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2782.272323] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2782.305693] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2782.405737] [DISP] not supported image0 pixel sequence:255 in img_sw_para_to_reg [ 2782.422438] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2782.457148] [DISP] request scaler fail [ 2782.460486] [DISP] request scaler layer fail! [ 2782.505645] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2782.605734] [DISP] not supported image0 pixel sequence:232 in img_sw_para_to_reg [ 2782.622309] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2782.672397] [DISP] not supported image0 pixel sequence:236 in img_sw_para_to_reg [ 2782.755735] [DISP] not supported image0 pixel sequence:236 in img_sw_para_to_reg [ 2783.022302] [DISP] not supported image0 pixel sequence:96 in img_sw_para_to_reg [ 2783.072394] [DISP] not supported image0 pixel sequence:255 in img_sw_para_to_reg [ 2783.122306] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2783.205643] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2783.255639] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2783.272311] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2783.322410] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2783.338986] [DISP] not supported image0 pixel sequence:48 in img_sw_para_to_reg [ 2783.355676] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2783.372313] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2783.455648] [DISP] not supported image0 pixel sequence:68 in img_sw_para_to_reg [ 2783.522313] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2783.555641] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2783.605635] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2783.689070] [DISP] not supported image0 pixel sequence:136 in img_sw_para_to_reg [ 2783.738977] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2783.755665] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2783.789069] [DISP] not supported image0 pixel sequence:236 in img_sw_para_to_reg [ 2783.805658] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2783.855646] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2783.872354] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2783.889066] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2783.905759] [DISP] not supported image0 pixel sequence:196 in img_sw_para_to_reg [ 2783.922419] [DISP] not supported image0 pixel sequence:196 in img_sw_para_to_reg [ 2783.939061] [DISP] not supported image0 pixel sequence:112 in img_sw_para_to_reg [ 2783.955735] [DISP] not supported image0 pixel sequence:184 in img_sw_para_to_reg [ 2784.005653] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2784.039212] [DISP] not supported image0 pixel sequence:132 in img_sw_para_to_reg [ 2784.072324] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2784.105738] [DISP] not supported image0 pixel sequence:128 in img_sw_para_to_reg [ 2784.122226] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2784.138974] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2784.155746] [DISP] not supported image0 pixel sequence:240 in img_sw_para_to_reg [ 2784.172392] [DISP] not supported image0 pixel sequence:136 in img_sw_para_to_reg [ 2784.175464] [DISP] request scaler fail [ 2784.178798] [DISP] request scaler layer fail! [ 2784.239065] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2784.405726] [DISP] not supported image0 pixel sequence:232 in img_sw_para_to_reg [ 2784.505641] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2784.555638] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2784.605633] [DISP] not supported image0 pixel sequence:92 in img_sw_para_to_reg [ 2784.622219] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2784.672305] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2784.722309] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2784.755638] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2784.772400] [DISP] not supported image0 pixel sequence:104 in img_sw_para_to_reg [ 2784.855647] [DISP] not supported image0 pixel sequence:68 in img_sw_para_to_reg [ 2784.905641] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2784.955637] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2784.989068] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2785.022401] [DISP] not supported image0 pixel sequence:136 in img_sw_para_to_reg [ 2785.089381] [DISP] not supported image0 pixel sequence:232 in img_sw_para_to_reg [ 2785.138916] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2785.172311] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2785.205746] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2785.255643] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2785.272312] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2785.288976] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2785.438999] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2785.455567] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2785.472343] [DISP] not supported image0 pixel sequence:68 in img_sw_para_to_reg [ 2785.489077] [DISP] not supported image0 pixel sequence:196 in img_sw_para_to_reg [ 2785.539084] [DISP] not supported image0 pixel sequence:248 in img_sw_para_to_reg [ 2785.555737] [DISP] not supported image0 pixel sequence:164 in img_sw_para_to_reg [ 2785.572350] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2785.589085] [DISP] not supported image0 pixel sequence:192 in img_sw_para_to_reg [ 2785.622390] [DISP] not supported image0 pixel sequence:136 in img_sw_para_to_reg [ 2785.639067] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2785.655728] [DISP] not supported image0 pixel sequence:176 in img_sw_para_to_reg [ 2785.722395] [DISP] not supported image0 pixel sequence:128 in img_sw_para_to_reg [ 2785.772217] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2785.789063] [DISP] not supported image0 pixel sequence:128 in img_sw_para_to_reg [ 2785.805734] [DISP] not supported image0 pixel sequence:136 in img_sw_para_to_reg [ 2785.822222] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2785.872392] [DISP] not supported image0 pixel sequence:255 in img_sw_para_to_reg [ 2785.889184] [DISP] not supported image0 pixel sequence:232 in img_sw_para_to_reg [ 2785.905553] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2785.922326] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2785.972227] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2786.022403] [DISP] not supported image0 pixel sequence:196 in img_sw_para_to_reg [ 2786.072396] [DISP] not supported image0 pixel sequence:116 in img_sw_para_to_reg [ 2786.105640] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2786.139146] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2786.155664] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2786.205632] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2786.305735] [DISP] not supported image0 pixel sequence:196 in img_sw_para_to_reg [ 2786.322308] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2786.372393] [DISP] not supported image0 pixel sequence:128 in img_sw_para_to_reg [ 2786.388972] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2786.405732] [DISP] not supported image0 pixel sequence:196 in img_sw_para_to_reg [ 2786.439065] [DISP] not supported image0 pixel sequence:128 in img_sw_para_to_reg [ 2786.455630] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2786.489068] [DISP] not supported image0 pixel sequence:128 in img_sw_para_to_reg [ 2786.505658] [DISP] not supported image0 pixel sequence:52 in img_sw_para_to_reg [ 2786.522403] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2786.689096] [DISP] not supported image0 pixel sequence:116 in img_sw_para_to_reg [ 2786.705743] [DISP] not supported image0 pixel sequence:212 in img_sw_para_to_reg [ 2786.738997] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2786.755658] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2786.888998] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2786.922226] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2786.955645] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2786.989070] [DISP] not supported image0 pixel sequence:164 in img_sw_para_to_reg [ 2787.039072] [DISP] not supported image0 pixel sequence:152 in img_sw_para_to_reg [ 2787.055735] [DISP] not supported image0 pixel sequence:112 in img_sw_para_to_reg [ 2787.072316] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2787.089001] [DISP] not supported image0 pixel sequence:34 in img_sw_para_to_reg [ 2787.105645] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2787.139095] [DISP] not supported image0 pixel sequence:240 in img_sw_para_to_reg [ 2787.222407] [DISP] not supported image0 pixel sequence:200 in img_sw_para_to_reg [ 2787.238995] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2787.305649] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2787.488980] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2787.522320] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2787.655646] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2787.705736] [DISP] not supported image0 pixel sequence:192 in img_sw_para_to_reg [ 2787.722324] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2787.755747] [DISP] not supported image0 pixel sequence:137 in img_sw_para_to_reg [ 2787.772324] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2787.822316] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2787.839002] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2787.939291] [DISP] not supported image0 pixel sequence:255 in img_sw_para_to_reg [ 2787.989298] [DISP] not supported image0 pixel sequence:232 in img_sw_para_to_reg [ 2788.022311] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2788.088980] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2788.105646] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2788.205647] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2788.222402] [DISP] not supported image0 pixel sequence:204 in img_sw_para_to_reg [ 2788.238948] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2788.255754] [DISP] not supported image0 pixel sequence:137 in img_sw_para_to_reg [ 2788.372402] [DISP] not supported image0 pixel sequence:116 in img_sw_para_to_reg [ 2788.455646] [DISP] not supported image0 pixel sequence:68 in img_sw_para_to_reg [ 2788.505653] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2788.522326] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2788.555748] [DISP] not supported image0 pixel sequence:164 in img_sw_para_to_reg [ 2788.605744] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2788.622306] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2788.655728] [DISP] not supported image0 pixel sequence:137 in img_sw_para_to_reg [ 2788.672406] [DISP] not supported image0 pixel sequence:232 in img_sw_para_to_reg [ 2788.722406] [DISP] not supported image0 pixel sequence:112 in img_sw_para_to_reg [ 2788.772321] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2788.805650] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2788.872224] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2788.905653] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2789.055652] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2789.072411] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2789.138893] [DISP] not supported image0 pixel sequence:4 in img_sw_para_to_reg [ 2789.155570] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2789.205563] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2789.255647] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2789.272329] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2789.305749] [DISP] not supported image0 pixel sequence:192 in img_sw_para_to_reg [ 2789.389081] [DISP] not supported image0 pixel sequence:248 in img_sw_para_to_reg [ 2789.555646] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2789.722404] [DISP] not supported image0 pixel sequence:128 in img_sw_para_to_reg [ 2789.755648] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2789.872317] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2789.889083] [DISP] not supported image0 pixel sequence:128 in img_sw_para_to_reg [ 2789.972230] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2790.022330] [DISP] not supported image0 pixel sequence:48 in img_sw_para_to_reg [ 2790.039070] [DISP] not supported image0 pixel sequence:137 in img_sw_para_to_reg [ 2790.055732] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2790.138983] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2790.155757] [DISP] not supported image0 pixel sequence:240 in img_sw_para_to_reg [ 2790.189071] [DISP] not supported image0 pixel sequence:182 in img_sw_para_to_reg [ 2790.205655] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2790.255671] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2790.305651] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2790.322411] [DISP] not supported image0 pixel sequence:240 in img_sw_para_to_reg [ 2790.339066] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2790.405651] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2790.422321] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2790.438984] [DISP] not supported image0 pixel sequence:72 in img_sw_para_to_reg [ 2790.455651] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2790.472419] [DISP] not supported image0 pixel sequence:232 in img_sw_para_to_reg [ 2790.489067] [DISP] not supported image0 pixel sequence:112 in img_sw_para_to_reg [ 2790.505668] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2790.555646] [DISP] not supported image0 pixel sequence:68 in img_sw_para_to_reg [ 2790.605654] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2790.689000] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2790.722406] [DISP] not supported image0 pixel sequence:116 in img_sw_para_to_reg [ 2790.739011] [DISP] not supported image0 pixel sequence:68 in img_sw_para_to_reg [ 2790.788985] [DISP] not supported image0 pixel sequence:88 in img_sw_para_to_reg [ 2790.855558] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2790.888986] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2790.922325] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2790.938979] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2791.072317] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2791.105734] [DISP] not supported image0 pixel sequence:196 in img_sw_para_to_reg [ 2791.155637] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2791.255634] [DISP] not supported image0 pixel sequence:40 in img_sw_para_to_reg [ 2791.322308] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2791.355722] [DISP] not supported image0 pixel sequence:192 in img_sw_para_to_reg [ 2791.405646] [DISP] not supported image0 pixel sequence:48 in img_sw_para_to_reg [ 2791.489206] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2791.722238] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2791.755747] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2791.772313] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2791.872311] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2791.905650] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2791.955654] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2792.005653] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2792.155744] [DISP] not supported image0 pixel sequence:192 in img_sw_para_to_reg [ 2792.272412] [DISP] not supported image0 pixel sequence:116 in img_sw_para_to_reg [ 2792.305667] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2792.338905] [DISP] not supported image0 pixel sequence:1 in img_sw_para_to_reg [ 2792.355635] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2792.489076] [DISP] not supported image0 pixel sequence:102 in img_sw_para_to_reg [ 2792.505652] [DISP] not supported image0 pixel sequence:32 in img_sw_para_to_reg [ 2792.655658] [DISP] not supported image0 pixel sequence:12 in img_sw_para_to_reg [ 2792.738992] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2792.755672] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2792.788985] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2792.839060] [DISP] not supported image0 pixel sequence:144 in img_sw_para_to_reg [ 2792.855664] [DISP] not supported image0 pixel sequence:76 in img_sw_para_to_reg [ 2792.872334] [DISP] not supported image0 pixel sequence:64 in img_sw_para_to_reg [ 2792.888894] [DISP] not supported image0 pixel sequence:8 in img_sw_para_to_reg [ 2792.922399] [DISP] not supported image0 pixel sequence:104 in img_sw_para_to_reg [ 2792.957944] [DISP] layer released: 0,102
