anuj9122 Posted September 12, 2019 Posted September 12, 2019 A fatal error has been detected by the Java Runtime Environment: # # SIGILL (0x4) at pc=0xb40aba7c, pid=320, tid=327 # # JRE version: OpenJDK Runtime Environment (11.0.4+11) (build 11.0.4+11-post-Ubuntu-1ubuntu218.04.3) # Java VM: OpenJDK Server VM (11.0.4+11-post-Ubuntu-1ubuntu218.04.3, mixed mode, serial gc, linux-) # Problematic frame: # J 28 c2 java.lang.StringUTF16.toLowerCase(Ljava/lang/String;[BLjava/util/Locale;)Ljava/lang/String; java.base@11.0.4 (296 bytes) @ 0xb40aba7c [0xb40ab880+0x000001fc] # # No core dump will be written. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again # # An error report file with more information is saved as: # //hs_err_pid320.log Could not load hsdis-arm.so; library not loadable; PrintAssembly is disabled # # If you would like to submit a bug report, please visit: # https://bugs.launchpad.net/ubuntu/+source/openjdk-lts # /var/lib/dpkg/info/ca-certificates-java.postinst: line 76: 318 Done find /etc/ssl/certs -name \*.pem 319 | while read filename; do alias=$(basename $filename .pem | tr A-Z a-z | tr -cs a-z0-9 _); alias=${alias%*_}; if [ -n "$FIXOLD" ]; then echo "-${alias}"; echo "-${alias}_pem"; fi; echo "+${filename}"; done 320 Aborted | java -Xmx64m -jar $JAR -storepass "$storepass" dpkg: error processing package ca-certificates-java (--configure): installed ca-certificates-java package post-installation script subprocess returned error exit status 134 dpkg: dependency problems prevent configuration of openjdk-11-jre-headless:armhf: openjdk-11-jre-headless:armhf depends on ca-certificates-java; however: Package ca-certificates-java is not configured yet. dpkg: error processing package openjdk-11-jre-headless:armhf (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of openjdk-11-jdk-headless:armhf: openjdk-11-jdk-headless:armhf depends on openjdk-11-jre-headless (= 11.0.4+11-1ubuntu2~18.04.3); however: Package openjdk-11-jre-headless:armhf is not configured yet. dpkg: error processing package openjdk-11-jdk-headless:armhf (--configure): dependency problems - leaving unconfigured Setting up libio-socket-ssl-perl (2.060-3~ubuntu18.04.1) ... dpkg: dependency problems prevent configuration of openjdk-11-jdk:armhf: openjdk-11-jdk:armhf depends on openjdk-11-jdk-headless (= 11.0.4+11-1ubuntu2~18.04.3); however: Package openjdk-11-jdk-headless:armhf is not configured yet. dpkg: error processing package openjdk-11-jdk:armhf (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of default-jdk: default-jdk depends on openjdk-11-jdk; however: Package openjdk-11-jdk:armhf is not configured yet. dpkg: error processing package default-jdk (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of default-jdk-headless: default-jdk-headless depends on openjdk-11-jdk-headless; however: Package openjdk-11-jdk-headless:armhf is not configured yet. dpkg: error processing package default-jdk-headless (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of openjdk-11-jre:armhf: openjdk-11-jre:armhf depends on openjdk-11-jre-headless (= 11.0.4+11-1ubuntu2~18.04.3); however: Package openjdk-11-jre-headless:armhf is not configured yet. dpkg: error processing package openjdk-11-jre:armhf (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of default-jre: default-jre depends on openjdk-11-jre; however: Package openjdk-11-jre:armhf is not configured yet. dpkg: error processing package default-jre (--configure): dependency problems - leaving unconfigured Processing triggers for man-db (2.8.3-2ubuntu0.1) ... Processing triggers for ca-certificates (20180409) ... Updating certificates in /etc/ssl/certs... 0 added, 0 removed; done. Running hooks in /etc/ca-certificates/update.d... done. done. Errors were encountered while processing: ca-certificates-java openjdk-11-jre-headless:armhf openjdk-11-jdk-headless:armhf openjdk-11-jdk:armhf default-jdk default-jdk-headless openjdk-11-jre:armhf default-jre E: Sub-process /usr/bin/dpkg returned an error code (1)
goose Posted April 12, 2020 Posted April 12, 2020 I came across this crash on Debian 10 "buster" and this is the only other post with this exact error that I can find on the internet, so here's some background for the next person: OpenJDK has a bug on single core ARM CPUs, the JIT compiler generates an instruction which isn't supported on a non-multicore and causes SIGILL: https://bugs.openjdk.java.net/browse/JDK-8222825 Most Java programs can crash this way. This seems to be fixed in openjdk upstream but not updated in Debian yet. You can hack around it by passing "-XX:-AssumeMP" option when running java. To fix most Java programs, set this as a default java command line option in in /etc/profile or /etc/profile.d/ with this line: export JAVA_TOOL_OPTIONS="-XX:-AssumeMP" Unfortunately that doesn't fix the crashing ca-certificates-java package setup. I hacked around this in a nasty way by editing /var/lib/dpkg/info/ca-certificates-java.postinst and changing the two instances of "java -Xmx64m" to "java -Xmx64m -XX:-AssumeMP" and then running "apt-get -f install" to retry. This is real ugly but it fixed the broken package.
