I have a Beelink Mini MXIII. I successfully installed Armbian on an SDCard, and booted from it then I used the  "Armbian configuration utility" to install onto eMMC.
Now the box is bricked, there is no signal to hdmi.
I tried to use the "USB Burning tool" method, and tried to burn the firmware on an SD card, but with no success when booting.
What should I do from here  ?
Who wants to have a good laugh ... My HDMI Cable was not plugged properly.
The box is fine, I now have to reinstall Armbian on SD card, and then try to copy it to eMMC
It might be that the Install.sh was working fine
I used "USB Burning tool" to restore the box, then I burn "Armbian_5.98_Aml-g12_Debian_buster_default_5.3.0_20191002.img" using Rufus
I changed DTD to "meson-gxbb-vega-s95-meta.dtb" in those files
  • boot.ini
  • uEnv.ini
  • extlinux/extlinux.conf
Then I used armbian-config, to update & upgrade firmware, and used the Install function.
Then sudo shutdown -h now
Remove sd card
Reboot and then blank screen.
Did forget to do something?
I did a sudo nand-sata-install, Here is the log. Everything seem fine (see 1rst log below), but reboot did not work
Then, I did a restore using USB burning tool, and then executed /root/install.sh, there are some errors (see 2nd log below)
Please advise
Start script create MBR and filesystem
/dev/mmcblk1
Start backup u-boot default
4+0 records in
4+0 records out
4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.05425 s, 77.3 MB/s
Start create MBR and partittion
Start restore u-boot
442+0 records in
442+0 records out
442 bytes copied, 0.00314161 s, 141 kB/s
8191+0 records in
8191+0 records out
4193792 bytes (4.2 MB, 4.0 MiB) copied, 0.601275 s, 7.0 MB/s
Done
Start copy system for eMMC.
Formatting BOOT partition...mkfs.fat 4.1 (2017-01-24)
done.
Cppying BOOT...done.
Edit init config...done.
Formatting ROOT partition...
e2fsck 1.44.5 (15-Dec-2018)
ROOT_EMMC: clean, 11/897600 files, 82980/3586304 blocks
done.
Copying ROOTFS.
Copy BIN
Create DEV
Copy ETC
Copy HOME
Copy LIB
Create MEDIA
Create MNT
Copy OPT
Create PROC
Copy ROOT
Create RUN
Copy SBIN
Copy SELINUX
Copy SRV
Create SYS
Create TMP
Copy USR
Copy VAR
Copy fstab
Complete copy OS to eMMC
/dev/mmcblk1
4+0 records in
4+0 records out
4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.0876638 s, 47.8 MB/s
./install.sh: 55: ./install.sh: parted: not found
./install.sh: 56: ./install.sh: parted: not found
./install.sh: 57: ./install.sh: parted: not found
442+0 records in
442+0 records out
442 bytes copied, 0.00296424 s, 149 kB/s
8191+0 records in
8191+0 records out
4193792 bytes (4.2 MB, 4.0 MiB) copied, 0.501448 s, 8.4 MB/s
Done
Formatting BOOT partition..../install.sh: 87: ./install.sh: mkfs.vfat: not found
done.
mount: /ddbr/install: special device /dev/mmcblk1p1 does not exist.
umount: /ddbr/install: not mounted.
./install.sh: 112: ./install.sh: mke2fs: not found
./install.sh: 113: ./install.sh: e2fsck: not found
done.
Copying ROOTFS.
mount: /ddbr/install: special device /dev/mmcblk1p2 does not exist.
Copy BIN
Create DEV
Copy ETC
Copy HOME
Copy LIB
Create MEDIA
Create MNT
Copy OPT
Create PROC
Copy ROOT
Create RUN
Copy SBIN
Copy SELINUX
Copy SRV
Create SYS
Create TMP
Copy USR
Copy VAR
Copy fstab
  • Werner locked this topic
