A while ago I did create  a armbian-package-information for at the motd of the login:
Now the line for the kernel does show 2 versions because there are "Version:" and "Config -Version:"
root@npi-neo2-24(192.168.6.24):~# dpkg -s linux-image-$BRANCH-$LINUXFAMILY|grep Version
Version: 5.96
Config-Version: 5.96
root@npi-neo2-24(192.168.6.24):~# dpkg -s linux-image-$BRANCH-$LINUXFAMILY|grep Version|cut -f 2 -d ' '
5.96
5.96
So I had to find another way/command to get the information once ;)
I did go back from "dpkg -s" to "dpkg -l" and greped there the version-info:
root@npi-neo2-24(192.168.6.24):~# dpkg -l | awk -v env_var="linux-image-$BRANCH-$LINUXFAMILY" '$2==env_var { print $3 }'
5.96
# end-part of /etc/update-motd.d/10-armbian-header
# NEW version
ARMBIAN_bsp=$(more /etc/armbian-release|grep VERSION|cut -f 2 -d '=')
ARMBIAN_kernel=$(dpkg -l | awk -v env_var="linux-image-$BRANCH-$LINUXFAMILY" '$2==env_var { print $3 }')
ARMBIAN_uboot=$(dpkg -l | awk -v env_var="linux-u-boot-$BOARD-$BRANCH" '$2==env_var { print $3 }')
ARMBIAN_dtb=$(dpkg -l | awk -v env_var="linux-dtb-$BRANCH-$LINUXFAMILY" '$2==env_var { print $3 }')
ARMBIAN_firmware=$(dpkg -l | awk -v env_var="armbian-firmware" '$2==env_var { print $3 }')
ARMBIAN_config=$(dpkg -l | awk -v env_var="armbian-config" '$2==env_var { print $3 }')
printf 'package bsp-kernel[\e[0;91m%s\x1B[0m] u-boot[\e[0;91m%s\x1B[0m] dtb[\e[0;91m%s\x1B[0m] firmware[\e[0;91m%s\x1B[0m] config[\e[0;91m%s\x1B[0m]\n' "$ARMBIAN_kernel" "$ARMBIAN_uboot" "$ARMBIAN_dtb" "$ARMBIAN_firmware" "$ARMBIAN_config"
printf '\n'
After successfully getting the kernel-version only once- I edited the other commands to the "dpkg -l" version - and the result is clear as before :)
 _   _ ____  _   _   _              ____
| \ | |  _ \(_) | \ | | ___  ___   |___ \
|  \| | |_) | | |  \| |/ _ \/ _ \    __) |
| |\  |  __/| | | |\  |  __/ (_) |  / __/
|_| \_|_|   |_| |_| \_|\___|\___/  |_____|
Welcome to Debian Buster with Armbian Linux 5.3.3-sunxi64
package bsp-kernel[5.98.191003] u-boot[5.96] dtb[5.98.191003] firmware[5.96] config[5.96]
The only drawback is, when you use a dev-kernel/-dtb on a next-installation (using other kernel via armbian-config) then $BRANCH is next and your kernel is dev :(
root@npi-neo2-24(192.168.6.24):~# dpkg -l|grep image
ii  linux-image-dev-sunxi64           5.98.191003                         arm64        Linux kernel, version 5.3.3-sunxi64
rc  linux-image-next-sunxi64          5.96                                arm64        Linux kernel, version 4.19.71-sunxi64
root@npi-neo2-24(192.168.6.24):~# dpkg -l|grep dtb
ii  linux-dtb-dev-sunxi64             5.98.191003                         arm64        Linux DTB, version 5.3.3-sunxi64
# ARMBIAN_kernel=$(dpkg -l | awk -v env_var="linux-image-$BRANCH-$LINUXFAMILY" '$2==env_var { print $3 }')
ARMBIAN_kernel=$(dpkg -l | awk -v env_var="linux-image-dev-$LINUXFAMILY" '$2==env_var { print $3 }')
# ARMBIAN_dtb=$(dpkg -l | awk -v env_var="linux-dtb-$BRANCH-$LINUXFAMILY" '$2==env_var { print $3 }')
ARMBIAN_dtb=$(dpkg -l | awk -v env_var="linux-dtb-dev-$LINUXFAMILY" '$2==env_var { print $3 }')
PS: I also did try - before this - the package apt-show-versions (lists available package versions with distribution)
but this takes much too long to resolve and needs this additionally package :(
