deb2016 Posted October 3, 2019 Posted October 3, 2019 Hello, There are many leds on the clearfogpro that I would like to switch off. But /sys/class/leds only has "mmc0::". Is there a way to access other leds ? namely those of the ethernet ports ? Regards deb2016
Heisath Posted October 6, 2019 Posted October 6, 2019 Problem is the LEDs are partly directly connected to the ethernet switch 88E6176 (see also schematics of clearfogpro). I don't think you can tell the switch to enable/disable them. Maybe check in the driver or datasheet. Wouldn't it be easier to just put some tape over them?
