funben Posted October 9, 2019 Posted October 9, 2019 On my Beelink Mini MXIII, I would like to run a home automation server (Jeedom) and many user based on RaspberryPI have issue with bad sector because SDCard cannot handle a lot of Read/Write cycles. I successfully run armbian from SDCard, but I would like to copy it to eMMC. and change DTD in boot.ini, uEnv.ini, extlinux/extlinux.conf and then did a sudo nand-sata-install (Below is the load result) I've been told that armbian kernel did not support this specitif eMMC controller (Brand FORESEE), I there a a to install drivers on armbian, or should I install armbian on a USBKey (how to boot from USB) Or should I buy a new box (android TV box, on something else) which one under 50$ that il well supported by armbian NAND-SATA-INSTALL result Reveal hidden contents Start script create MBR and filesystem /dev/mmcblk1 Start backup u-boot default 4+0 records in 4+0 records out 4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.05425 s, 77.3 MB/s Start create MBR and partittion Start restore u-boot 442+0 records in 442+0 records out 442 bytes copied, 0.00314161 s, 141 kB/s 8191+0 records in 8191+0 records out 4193792 bytes (4.2 MB, 4.0 MiB) copied, 0.601275 s, 7.0 MB/s Done Start copy system for eMMC. Formatting BOOT partition...mkfs.fat 4.1 (2017-01-24) done. Cppying BOOT...done. Edit init config...done. Formatting ROOT partition... e2fsck 1.44.5 (15-Dec-2018) ROOT_EMMC: clean, 11/897600 files, 82980/3586304 blocks done. Copying ROOTFS. Copy BIN Create DEV Copy ETC Copy HOME Copy LIB Create MEDIA Create MNT Copy OPT Create PROC Copy ROOT Create RUN Copy SBIN Copy SELINUX Copy SRV Create SYS Create TMP Copy USR Copy VAR Copy fstab ******************************************* Complete copy OS to eMMC ******************************************* DMESG result Reveal hidden contents [ 1.957663] mmcblk0: mmc0:aaaa SC16G 14.8 GiB [ 1.962035] usbhid: USB HID core driver [ 1.970510] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered [ 1.970613] mmcblk0: p1 p2 [...] [ 2.114821] mmc1: new HS200 MMC card at address 0001 [ 2.119816] mmcblk1: mmc1:0001 NCard 14.5 GiB [ 2.120535] mmcblk1boot0: mmc1:0001 NCard partition 1 4.00 MiB [ 2.125281] mmcblk1boot1: mmc1:0001 NCard partition 2 4.00 MiB [ 2.130574] mmcblk1rpmb: mmc1:0001 NCard partition 3 4.00 MiB, chardev (241:0) [...] PARTED result Reveal hidden contents Model: SD SC16G (sd/mmc) Disk /dev/mmcblk0: 15.9GB Sector size (logical/physical): 512B/512B Partition Table: msdos Disk Flags: Number Start End Size Type File system Flags 1 4194kB 138MB 134MB primary fat16 lba 2 138MB 15.8GB 15.6GB primary ext4 [...] Model: MMC NCard (sd/mmc) Disk /dev/mmcblk1: 15.5GB Sector size (logical/physical): 512B/512B Partition Table: unknown Disk Flags:
funben Posted October 14, 2019 Author Posted October 14, 2019 Anyone ? Where to find driver for a FORESEE eMMC in armbian ? How to install it ?
