On newer armbian-build it seems that the codec-analog is disabled  by default :(
I activated analog-codec in armbian-config ==> System ==> Hardware
like in older builds.
aplay -l  did show the device, but could play.
So I did decompile the .dtb with:
dtc -I dtb -O dts /boot/dtb/sun8i-h2-plus-orangepi-r1.dtb -o /boot/dtb/sun8i-h2-plus-orangepi-r1.dts
Edited the allwinner,sun8i-h3-codec status from disabled to okay:
                codec@1c22c00 {
                        #sound-dai-cells = < 0x00 >;
                        compatible = "allwinner,sun8i-h3-codec";
                        reg = < 0x1c22c00 0x400 >;
                        interrupts = < 0x00 0x1d 0x04 >;
                        clocks = < 0x03 0x34 0x03 0x6d >;
                        clock-names = "apb\0codec";
                        resets = < 0x03 0x28 >;
                        dmas = < 0x14 0x0f 0x14 0x0f >;
                        dma-names = "rx\0tx";
                        allwinner,codec-analog-controls = < 0x19 >;
                        status = "okay";
                        phandle = < 0x58 >;
Then I compiled the .dts back to .dtb:
dtc -I dts -O dtb /boot/dtb/sun8i-h2-plus-orangepi-r1.dts -o /boot/dtb/sun8i-h2-plus-orangepi-r1.dtb
In armbian-config ==> System ==> Hardware I enabled also usbhost2 & usbhost3
(because no USB-device was recognized at the USB-ports of the NAS-board)
and I disabled cir and spi-jedec-nor which I had enabled for a test.
After a reboot the soundcard
Debian Buster with Armbian Linux 5.3.7-sunxi
package bsp-kernel[5.98.191026] u-boot[5.98] dtb[5.98.191026] firmware[5.98] config[5.98]
root@opi-r1(192.168.6.101):~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 [CDC PCM Codec-0]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
is working again like in older builds :)
The 2nd Ethernet Port Bus 003 Device 002: ID 0bda:8152 Realtek Semiconductor Corp. RTL8152 Fast Ethernet Adapter
is also connected via USB, but is allways in the lsusb-list - even when usbhost0-usbhost3 is disabled.
