Hello! I am a beginner here. Prompt please as to establish me gstreamer0.10?
Board: Orange PI PC
Distributor ID: Debian
Description: Debian GNU/Linux 8.4 (jessie)
Release: 8.4
Codename: jessie
> apt-get install gstreamer0.10
Reading package lists... Done
Building dependency tree
Note, selecting 'gstreamer0.10-plugins-base-doc' for regex 'gstreamer0.10'
Note, selecting 'libgstreamer0.10-0' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-qapt' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-esd' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-ugly-multiverse' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-schroedinger' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-bad' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-good-doc' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-pulseaudio' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-audiosource' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-doc' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-ugly' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-videosink' for regex 'gstreamer0.10'
Note, selecting 'libgstreamer0.10-dev' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-gnonlin-dbg' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-gnonlin' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-audiosink' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-good' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-gnomevfs' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-bad-dbg' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-tools' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-x264' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-ugly-dbg' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-farsight' for regex 'gstreamer0.10'
Note, selecting 'libgstreamer0.10-cil-dev' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-hplugins' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-packagekit' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-bad-multiverse' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-gnonlin-doc' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-ffmpeg' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-nice' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-visualization' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-lame' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-pocketsphinx' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-gconf' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-ugly-doc' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-x' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-dvswitch' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-videosource' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-really-bad' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-fluendo-mp3' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-base' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-base-dbg' for regex 'gstreamer0.10'
Note, selecting 'libgstreamer0.10-0-dbg' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-alsa' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-good-dbg' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-chromaprint' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-xvid' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-base-apps' for regex 'gstreamer0.10'
Note, selecting 'gstreamer0.10-plugins-bad' instead of 'gstreamer0.10-plugins-farsight'
Note, selecting 'gstreamer0.10-plugins-bad' instead of 'gstreamer0.10-schroedinger'
gstreamer0.10-plugins-bad is already the newest version.
gstreamer0.10-plugins-bad set to manually installed.
gstreamer0.10-alsa is already the newest version.
gstreamer0.10-alsa set to manually installed.
gstreamer0.10-plugins-base is already the newest version.
gstreamer0.10-plugins-base set to manually installed.
gstreamer0.10-gconf is already the newest version.
gstreamer0.10-gconf set to manually installed.
gstreamer0.10-plugins-good is already the newest version.
gstreamer0.10-plugins-good set to manually installed.
gstreamer0.10-plugins-ugly is already the newest version.
gstreamer0.10-plugins-ugly set to manually installed.
libgstreamer0.10-0 is already the newest version.
libgstreamer0.10-0 set to manually installed.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libgstreamer0.10-cil-dev : Depends: libgstreamer0.9-cil (< 0.9.2.1~) but it is not installable
                            Depends: libgstreamer0.9-cil (>= 0.9.2) but it is not installable
E: Unable to correct problems, you have held broken packages.
 dpkg --list | grep gst
ii  gstreamer0.10-alsa:armhf              0.10.36-2                                       armhf        GStreamer plugin for ALSA
ii  gstreamer0.10-gconf:armhf             0.10.31-3+nmu4+b1                               armhf        GStreamer plugin for getting the sink/source information from GConf
ii  gstreamer0.10-plugins-bad:armhf       0.10.23-7.4                                     armhf        GStreamer plugins from the "bad" set
ii  gstreamer0.10-plugins-base:armhf      0.10.36-2                                       armhf        GStreamer plugins from the "base" set
ii  gstreamer0.10-plugins-good:armhf      0.10.31-3+nmu4+b1                               armhf        GStreamer plugins from the "good" set
ii  gstreamer0.10-plugins-ugly:armhf      0.10.19-2.1                                     armhf        GStreamer plugins from the "ugly" set
ii  libgstreamer-plugins-bad0.10-0:armhf  0.10.23-7.4                                     armhf        GStreamer development files for libraries from the "bad" set
ii  libgstreamer-plugins-base0.10-0:armhf 0.10.36-2                                       armhf        GStreamer libraries from the "base" set
ii  libgstreamer0.10-0:armhf              0.10.36-1.5                                     armhf        Core GStreamer libraries and elements
ii  python-gst0.10                        0.10.22-3                                       armhf        generic media-playing framework (Python bindings)
Actually, except python there is nothing. An image of system from here. The system is just established. I ask to excuse me for my bad English
