KSat2_Roach2 Posted November 18, 2019 Posted November 18, 2019 Hi, I want to use g_ether on NanoPi Neo Plus2. For Neo Air, I have already figured out how to do this and I can see usb0 in config. But with armbian 5.85 (4.19.38-sunxi64), the same instructions fail at sudo ifconfig usb0 up with the message "usb0: ERROR while getting interface flags: No such device". Could somebody tell me how to activate USB OTG on NanoPi Neo Plus2 and then use g_ether. I think the same holds true for g_serial. This could be an alternative, but I would prever ethernet connection. My target: Connect NanoPi Neo Plus2 with NanoPi Neo Air via Ethernet Thank you for your help! Steps I followed for g_ether: Quote Required OS: Armbian 5.75 (FA OS 4.14 misses g_ether module) Armbian has g_serial for OTG USB as standard. So disable g_serial through rmmod g_serial. Then configure g_ether: 1. Go to /etc/ and create (if not existing) the file modules 2. Add the following lines to this file: dwc2 g_ether 3. Go to /etc/modprobe.d/ and create the file g_ether.conf 4. Add the following lines to this file: options g_ether hostaddr=00:11:22:33:44:55 5. Go to /etc/network/interfaces.d/ and create the file usb0 6. Add the following lines to this file (replace with the desired IP address, e.g: 192.168.100.100): auto usb0 iface usb0 inet static address XXX.XXX.XXX.YYY netmask 255.255.255.0 gateway XXX.XXX.XXX.1 7. Go to /etc/ and editing rc.local 8. Add the following lines to this file: sudo ifconfig usb0 up sudo ifconfig usb0 XXX.XXX.XXX.YYY 9. Check with ifconfig, you shoud see usb0 with the configured IP address Expand
ChrisO2 Posted July 23, 2020 Posted July 23, 2020 Hi KSat2_Roach2, You mentioned you had worked out how to get USB OTG g_ether to work on NanoPi Neo Air in above post. Was it the steps you outlined above also ? I would like to do the same thing. Thanks for any help with this. Chris
