liamnilsson Posted November 20, 2019 Posted November 20, 2019 Please tell me how to install linux onto an android tv box. Also, i recently purchased purevpn since theres an 82% off on it. Would it work for me on the linux OS? If not then please provide alternatives
Tido Posted November 20, 2019 Posted November 20, 2019 Hi Liam, You must read the first post, before you start: https://forum.armbian.com/topic/7930-armbian-for-amlogic-s9xxx-kernel-5x/ hold on, when you read the first post here DO NOT START. Now you read this first post, this will save you a lot of time and explain you the steps: https://forum.armbian.com/topic/2419-armbian-for-amlogic-s905-and-s905x-ver-544/ I hope this helps.
DiegoB Posted June 8, 2020 Posted June 8, 2020 Hello folks, any luck with the T95 4GB 32GB model? I've tried with some USB stick + armbian with both "update aml_...-zip file" and burning the iso on it... No luck. Using the update procedure, the systems says the .zip file is not valid It has no "hard reset button" and it appears not to be booting from USB. Any hint?
