I tried the latest image for my Orange Pi one, but that one doesn't boot. So I tried to build an image with the compile script, but that crashes with the following message:
  │   LD      drivers/gpio/built-in.o                                      │
  │   LD      drivers/sound/built-in.o                                     │
  │   LD      drivers/spmi/built-in.o                                      │
  │   LD      drivers/thermal/built-in.o                                   │
  │   LD      drivers/timer/built-in.o                                     │
  │   LD      drivers/tpm/built-in.o                                       │
  │   LD      drivers/twserial/built-in.o                                  │
  │   LD      drivers/watchdog/built-in.o                                  │
  │   LD      drivers/video/bridge/built-in.o                              │
  │   LD      drivers/video/built-in.o                                     │
  │   LD      drivers/built-in.o                                           │
[1]: *** [common/env_common.o] Error 1
                                      make: *** [common] Error 2
        make: *** Waiting for unfinished jobs....
[ error ] ERROR in function compile_uboot [ common.sh:89 ]
[ error ] U-boot file not found [ u-boot-sunxi-with-spl.bin ]
[ o.k. ] Process terminated
When I make an image for my A10-Olinuxino-Lime it finishes correctly and that image, when written to an SD, boots and works as it should.
Can someone help me with this problem.
