armbian-config: install bootloader to SPI flash not working
I am using an Orange pi win plus (Allwinner A64, 2GB ram), running Armbian Bionic with Linux 5.3.9-sunxi64
The board has an 2MB on-board spi flash and I want to flash bootloader in it.
The spi flash can be correctly detected in the system (showing /dev/mtdblock0).
But the "install" tool in armbian-config can't install the bootloader into the flash.
When I selected "Install/Update the bootloader on SPI Flash" and confirmed the warning notice, the tool printed "OK" immidiately and there is actually nothing written to the flash.
After using "sudo bash -x armbian-config", I found the tool executed a command:
dd if=/usr/lib/linux-u-boot-dev-orangepiwin_19.11.3_arm64/u-boot.flash of=/dev/mtdblock0 status=noxfer
But there isn't a file named "u-boot.flash" in the directory.
Inside the directory "/usr/lib/linux-u-boot-dev-orangepiwin_19.11.3_arm64/", there are only two files named "sunxi-spl.bin" and "u-boot.itb".
So..
If it is a bug in armbian-config or flashing bootloader to flash is simply not supported?
If supported, Where can I find the u-boot.flash image?
(armbianconfig -u give me this URL: http://ix.io/237r , may be useful for debugging)
You should do the following :
cat /usr/lib/linux-u-boot-dev-orangepiwin_19.11.3_arm64/sunxi-spl.bin > /usr/lib/linux-u-boot-dev-orangepiwin_19.11.3_arm64/u-boot-with-spl.bin
cat /usr/lib/linux-u-boot-dev-orangepiwin_19.11.3_arm64/u-boot.itb >> /usr/lib/linux-u-boot-dev-orangepiwin_19.11.3_arm64/u-boot-with-spl.bin
flashcp /usr/lib/linux-u-boot-dev-orangepiwin_19.11.3_arm64/u-boot-with-spl.bin /dev/mtd0
