Marko Buršič Posted December 2, 2019 Posted December 2, 2019 (edited) I am struggling to make an external RTC work. "i2cdetect -y 7" reports that RTC at address 68 is alive. I have added in the following lines: echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-7/new_device hwclock -f /dev/rtc -s Could be a possible reason that hwclock is already linked with internal RTC? Is it possible that DS1307 is not recognised? If I do "modprobe ds-1307" I got the answer: "modprobe: FATAL: Module rtc-ds1307 not found in directory /lib/modules/5.3.11-rockchip64" Could this be the reason? The driver for ds-1307 doesn't exist? How can I get it? P.S. : The OS is Armbian Buster with Linux 5.3.11-rockchip64 Before getting the /dev/i2c-7 I had to modify /boot/armbianEnv.txt and add: overlays=spi-spidev i2c7 param_spidev_spi_bus=1 I had tested both I2C7 and SPI1.0 works as expected. Edited December 2, 2019 by Marko Buršič added post scriptum
martinayotte Posted December 2, 2019 Posted December 2, 2019 39 minutes ago, Marko Buršič said: "modprobe: FATAL: Module rtc-ds1307 not found in directory /lib/modules/5.3.11-rockchip64" Rockchip64 kernel config doesn't enable DS1307 currently. You can confirm with "grep DS13 /boot/config*". Feel free to do custom build with this enabled, and if working correctly, submit PR for future builds...
Marko Buršič Posted December 2, 2019 Author Posted December 2, 2019 "grep DS13 /boot/config" as well "grep DS1307 /boot/config" as well "grep ds1307 /boot/config" gives "No such file or directory". Also there is no config file in the directory /boot, rather /boot/config-5.3.11-rockchip64. # I2C RTC drivers # # CONFIG_RTC_DRV_ABB5ZES3 is not set # CONFIG_RTC_DRV_ABEOZ9 is not set # CONFIG_RTC_DRV_ABX80X is not set# CONFIG_RTC_DRV_DS1307 is not set # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set # CONFIG_RTC_DRV_HYM8563 is not set # CONFIG_RTC_DRV_MAX6900 is not setCONFIG_RTC_DRV_MAX77686=y CONFIG_RTC_DRV_RK808=y # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set CONFIG_RTC_DRV_ISL12026=m # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8523 is not set # CONFIG_RTC_DRV_PCF85063 is not set # CONFIG_RTC_DRV_PCF85363 is not set # CONFIG_RTC_DRV_PCF8563 is not set # CONFIG_RTC_DRV_PCF8583 is not set # CONFIG_RTC_DRV_M41T80 is not set # CONFIG_RTC_DRV_BD70528 is not set # CONFIG_RTC_DRV_BQ32K is not set # CONFIG_RTC_DRV_S35390A is not set # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8010 is not set # CONFIG_RTC_DRV_RX8581 is not set # CONFIG_RTC_DRV_RX8025 is not set # CONFIG_RTC_DRV_EM3027 is not set CONFIG_RTC_DRV_RV3028=m # CONFIG_RTC_DRV_RV8803 is not set CONFIG_RTC_DRV_S5M=y CONFIG_RTC_DRV_SD3078=m changed to # I2C RTC drivers # # CONFIG_RTC_DRV_ABB5ZES3 is not set # CONFIG_RTC_DRV_ABEOZ9 is not set # CONFIG_RTC_DRV_ABX80X is not set CONFIG_RTC_DRV_DS1307=y # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set # CONFIG_RTC_DRV_HYM8563 is not set # CONFIG_RTC_DRV_MAX6900 is not set# CONFIG_RTC_DRV_MAX77686=y CONFIG_RTC_DRV_RK808=y # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set CONFIG_RTC_DRV_ISL12026=m # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8523 is not set # CONFIG_RTC_DRV_PCF85063 is not set # CONFIG_RTC_DRV_PCF85363 is not set # CONFIG_RTC_DRV_PCF8563 is not set # CONFIG_RTC_DRV_PCF8583 is not set # CONFIG_RTC_DRV_M41T80 is not set # CONFIG_RTC_DRV_BD70528 is not set # CONFIG_RTC_DRV_BQ32K is not set # CONFIG_RTC_DRV_S35390A is not set # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8010 is not set # CONFIG_RTC_DRV_RX8581 is not set # CONFIG_RTC_DRV_RX8025 is not set # CONFIG_RTC_DRV_EM3027 is not set CONFIG_RTC_DRV_RV3028=m # CONFIG_RTC_DRV_RV8803 is not set CONFIG_RTC_DRV_S5M=y CONFIG_RTC_DRV_SD3078=m but no change.
martinayotte Posted December 2, 2019 Posted December 2, 2019 25 minutes ago, Marko Buršič said: "grep ds1307 /boot/config" That is because you didn't put the star * on "/boot/config*" So, if you change do custom build with those change and get it tested, you can submit a PullRequest ...
Marko Buršič Posted December 2, 2019 Author Posted December 2, 2019 5 hours ago, martinayotte said: That is because you didn't put the star * on "/boot/config*" grep DS13 /boot/config* CONFIG_RTC_DRV_DS1307=y # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1302 is not set # CONFIG_RTC_DRV_DS1305 is not set # CONFIG_RTC_DRV_DS1343 is not set # CONFIG_RTC_DRV_DS1347 is not set # CONFIG_RTC_DRV_DS1390 is not set Sorry, I didn't see the star, this is the result after I have changed the conifg_xxxx file. 5 hours ago, martinayotte said: So, if you change do custom build with those change and get it tested, you can submit a PullRequest ... You mean I have to build a kernel on my own?
martinayotte Posted December 2, 2019 Posted December 2, 2019 13 minutes ago, Marko Buršič said: You mean I have to build a kernel on my own? Yes ! Otherwise, you will need somebody else to do the job, and it could take weeks/months. Check this guide, it is pretty easy to build custom images : https://docs.armbian.com/Developer-Guide_Build-Preparation/
Marko Buršič Posted December 3, 2019 Author Posted December 3, 2019 I had tried, but it doesn't show the interactive window when executing ./compile.sh . The main.sh runs without getting directives, so it quits with error. I think it has to do with interactive shell, somehow it's blocked. https://github.com/armbian/build/issues/1658
martinayotte Posted December 3, 2019 Posted December 3, 2019 1 hour ago, Marko Buršič said: but it doesn't show the interactive window As said in the issue, this is because "dialog" tool is missing. Install it using "apt-get install dialog" ...
Marko Buršič Posted December 3, 2019 Author Posted December 3, 2019 5 hours ago, martinayotte said: As said in the issue, this is because "dialog" tool is missing. Install it using "apt-get install dialog" ... Yes, it works now. I had to "apt-get update" before doing "apt-get install dialog". Perhaps I am going to make it, we'll see. Thank you for your help, I don't know how would I find this missing step by myself, really helpful.
Marko Buršič Posted December 3, 2019 Author Posted December 3, 2019 I ran out of disk error. I did the "vagrant plugin install vagrant-disksize", as mentione in the tutotial, but nowhere is mentioned that you also have to edit file Vargantfile and add: config.disksize.size = '25GB' I put 25GB as minimal requirement from tutorial, we'll see, it seems consuming lots of CPU and memory to build this OS.
