Cool Games Posted December 2, 2019 Posted December 2, 2019 (edited) The devil is in the details. Armbian was partially working so I started over to study the process more closely ! It seems Geek Buying is NOT the same Wifi as WiFi Chip: RTL8189 on Gear Best in the X96 Mini. iComm SV8051P is not working with Linux and actually not very good on Android 7.1.2 as delivered. HDMI Audio on 5.4 is WIP as Linux Meson discloses. Edited December 3, 2019 by Cool Games Noob learning to start over with WIP 5.4 on X96 mini clone.
Cool Games Posted December 3, 2019 Author Posted December 3, 2019 (edited) X96_mini is from Geek Buying in 2018. Great job with this latest image ! For other noobs here is my initial and latest activity. I started over with new image Armbian_5.98_Aml-g12_Ubuntu_disco_dev_5.4.0-rc4_desktop_20191025.img.xz but may have forgotten something. I had saved with dtb_name "/dtb/amlogic/meson-gxl-s905w-p281.dtb" boot.ini armbian_first_run.txt uEnv.ini extlinux/extlinux.conf Etcher flashed Copied above files Ran armbian-config for timezone and hostname test.mp4 audio is soft and distorted from HDTV speaker. volume control shows built in stereo and no HDMI as I see on my Ubuntu laptop. dmesg has these initial lines with last one often appearing root@coolx96:~# dmesg | grep audio [ 7.642965] debugfs: Directory 'c1105400.audio' with parent 'regmap' already present! [ 24.333589] hdmi-audio-codec hdmi-audio-codec.2.auto: hdmi_codec_hw_params() width 16 rate 44100 channels 2 Synaptic only works from terminal not menu. I find it faster to ssh in with root and use apt-cache search packagename and dpkg -l | grep installed_pkgname apt install, update, upgrade Again great job. Now trying to get HDMI audio to sound right. Edited December 3, 2019 by Cool Games Started install over so made it work before commenting here.
