3.4.107 Wheezy for Olinuxino Micro HDMI issue
Nguyen Huu
//Update2: is there anyone have sunxi_cedar_mod.ko module for 3.4.107 kernel?
//Update1: I've changed and recompiled script.bin file and now screen turn on, great!  :)
Hi, I tried 3.4.107 wheezy on my Micro with HDMI screen. It show some image and message at boot, and then there's no signal to display. I also tried to change display resolution in "boot.scr" file, and tried "a10disp changehdmimodeforce 4"  command, and ssh terminal show:
sunxi disp kernel module version is 1.0
Cannot change HDMI mode because HDMI is not enabled.
i don't understand,
how i can "//Update1: I've changed and recompiled script.bin file and now screen turn on, great!" ?
how i see the device? i don't get the terminal.
EDIT:
ok, with ssh i can login, now i try to see the device.
i don't understand,
EDIT:
if you use Windows, you could use winscp along with putty to make changes to system
i don't see /dev/cedar_dev . Where do i add memory for cedar?
Yes, thanks, now with putty i can login with ssh.
but i don't see anything on monitor after boot.
download this file, extract and use winscp to replace file in "boot" folder, and reboot.
https://onedrive.live.com/redir?resid=91CD9585C0907EF6!46503&authkey=!AIDixu3SllA5LbQ&ithint=file%2crar
is it possible to change the resolution?
i have a 7" hdmi display with 1024x600 screen, but when it's connected with the micro seems that is set to 1280x720.
 If i try to change settings with xfce settings panel, i don't find 1024x600 but only 1280x720
