On 1/7/2020 at 12:48 PM, menthorul said:
Hi there,
Minix Neo X8-h plus any tutorial or similar cpu?
I think it's aprox like s802 or s812... not sure
05-31-2017, 09:50
Updated images Armbian 20170531. Changes to scripts activate the multi-boot and run system from external media. In the new version of the scripts allow to start the system from any USB socket (if the is connected other USB media). Back support "nodm", now in the images is used in common with the main branch Armbian authorization system. If you want you can install the package "lightdm" in version Mate-that-be to have a graphical authentication when you log into the system (just don't forget together with the installation of lightdm, remove the nodm package, otherwise they will interfere with each other). Other changes see the description of changes to main branch Armbian (replacement browser on Chromium, etc.).
New scripts activate the multi-boot and system start-up can be found here. You can download them and use for old images. To reactivate the multi-boot again.
https://yadi.sk/d/cEPIULGW3Jgpee
https://yadi.sk/d/QCGU0PIv3G5kEa
New script to activate the multi-boot on the Minix models H8x and H8x plus.
https://yadi.sk/d/BU_pyfHW3JgpEP
https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s812-aa/tronsmart-aa/620898-linux-for-amlogic-s802-s812/page3
Is there a step by step guide to install on the mini neo x8-h plus?
I keep getting an "unauthorised" error message right at the beginning.
Cheers
  • Werner locked this topic
