OFFTOP Android TV/Libreelec/Media center on CubieTruck (A20)
Hi! It seems http://www.cubieforums.com/ is dead (can't sign up), so may I ask here.
Is anybody tried to install Android TV on a CubieTruck? I have armbian booting from Sd Card, so I want to have similar SD Card (128Gb), but with Android TV. So - is this possible? What version of Android TV we can use? links appreciated!
Ok, I found replacement for android (I just want to use CubieTruck with TV)  https://forum.libreelec.tv/thread/17565-nightly-images-for-a20-a64-h3-and-h6-boards/?pageNo=1 , but can't get it work. My thread started from here  https://forum.libreelec.tv/thread/17565-nightly-images-for-a20-a64-h3-and-h6-boards/?postID=134052#post134052
Please! Anyone who have Cubietruck - can you please try to create bootable Libreelec and check it works on your device!
Hey I try 2 images - stable and nightly (LibreELEC-A20.arm-9.80-devel-20191230203035-9d103bd-cubietruck.img.gz and LibreELEC-A20.arm-9.80-nightly-20200201-a869d6c-cubietruck.img.gz), but after SD card resizing it is coming nothing on the display, seems I have the same error as you described on other forum. Currently I have no cable to connect to the SSH and try to solve it. Sad, but it does not really work out of the box with Cubietruck.
I finally created SDCard with android 4.2.2 with PhoenixCard from here and android image from here . It's old but it works. One problem is mounting an internal SD card.  Android detects SDCARD as external with a, b c partitions. I tried to change fstab to mount partition 3 from sdcard , but no success (works only via terminal like #mount /dev/block/mmc /sdcard/ .
