[SOLVED][Odroid C2] Wifi AR9271 causes kernel crash after upgrade
I am using up to date Armbian Buster.
TP-Link TL-WN722N V1 USB WiFi dongle causes system crashes after kernel upgrade to 5.4.12-meson64 #19.11.8 SMP PREEMPT Thu Jan 16 20:12:23 CET 2020 aarch64 GNU/Linux.
Before updating the kernel, I had no such problem.
Feb 12 20:17:15 xxx systemd[1]: Found device AR9271 802.11n.
Feb 12 20:17:15 xxx systemd[1]: Started ifup for wlx54e6fc8d208e.
Feb 12 20:17:15 xxx wpa_supplicant[2360]: Successfully initialized wpa_supplicant
Feb 12 20:17:15 xxx sh[2344]: wlx54e6fc8d208e=wlx54e6fc8d208e
Feb 12 20:17:17 xxx wpa_supplicant[2361]: Using interface wlx54e6fc8d208e with hwaddr 54:e6:fc:8d:20:8e and ssid "mynetwork"
Feb 12 20:17:17 xxx wpa_supplicant[2361]: wlx54e6fc8d208e: interface state UNINITIALIZED->ENABLED
Feb 12 20:17:17 xxx wpa_supplicant[2361]: wlx54e6fc8d208e: AP-ENABLED
Feb 12 20:17:17 xxx wpa_supplicant[2361]: wlx54e6fc8d208e: CTRL-EVENT-CONNECTED - Connection to 54:e6:fc:8d:20:8e completed [id=0 id_str=]
Feb 12 20:17:20 xxx systemd[1]: systemd-rfkill.service: Succeeded.
Feb 12 20:17:41 xxx wpa_supplicant[2361]: wlx54e6fc8d208e: AP-STA-CONNECTED 2c:d0:5a:38:bd:3b
Feb 12 20:18:00 xxx sshd[2403]: Accepted password for myuser from 10.0.0.5 port 22 ssh2
Feb 12 20:18:00 xxx sshd[2403]: pam_unix(sshd:session): session opened for user myuser by (uid=0)
Feb 12 20:18:00 xxx systemd[1]: Created slice User Slice of UID 1001.
Feb 12 20:18:00 xxx systemd[1]: Starting User Runtime Directory /run/user/1001...
Feb 12 20:18:00 xxx systemd-logind[1584]: New session 7 of user myuser.
Feb 12 20:18:00 xxx systemd[1]: Started User Runtime Directory /run/user/1001.
Feb 12 20:18:00 xxx systemd[1]: Starting User Manager for UID 1001...
Feb 12 20:18:00 xxx systemd[2406]: pam_unix(systemd-user:session): session opened for user myuser by (uid=0)
Feb 12 20:18:00 xxx systemd[2406]: Reached target Paths.
Feb 12 20:18:00 xxx systemd[2406]: Reached target Sockets.
Feb 12 20:18:00 xxx systemd[2406]: Reached target Timers.
Feb 12 20:18:00 xxx systemd[2406]: Reached target Basic System.
Feb 12 20:18:00 xxx systemd[2406]: Reached target Default.
Feb 12 20:18:00 xxx systemd[2406]: Startup finished in 123ms.
Feb 12 20:18:00 xxx systemd[1]: Started User Manager for UID 1001.
Feb 12 20:18:00 xxx systemd[1]: Started Session 7 of user myuser.
Feb 12 20:18:48 xxx sshd[2505]: Received disconnect from 10.0.0.5 port 22:11: disconnected by user
Feb 12 20:18:48 xxx sshd[2505]: Disconnected from user myuser 10.0.0.5 port 22
Feb 12 20:18:48 xxx sshd[2403]: pam_unix(sshd:session): session closed for user myuser
Feb 12 20:18:48 xxx systemd[1]: session-7.scope: Succeeded.
Feb 12 20:18:48 xxx systemd-logind[1584]: Session 7 logged out. Waiting for processes to exit.
Feb 12 20:18:48 xxx systemd-logind[1584]: Removed session 7.
Feb 12 20:18:54 xxx wpa_supplicant[2361]: wlx54e6fc8d208e: AP-STA-DISCONNECTED 2c:d0:5a:38:bd:3b
Feb 12 20:18:56 xxx kernel: ath: phy0: Unable to remove station entry for: 2c:d0:5a:38:bd:3b
Message from syslogd@localhost at Feb 12 20:18:59 ...
 kernel:[  571.404886] Internal error: Oops: 96000004 [#1] PREEMPT SMP
 kernel:[  571.612865] Code: d5384101 b9402262 b9401020 11000400 (f8626a99)
 kernel:[  571.623551] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
Second one:
Feb 12 20:23:08 xxx wpa_supplicant[2125]: Using interface wlx54e6fc8d208e with hwaddr 54:e6:fc:8d:20:8e and ssid "mynetwork"
Feb 12 20:23:08 xxx wpa_supplicant[2125]: wlx54e6fc8d208e: interface state UNINITIALIZED->ENABLED
Feb 12 20:23:08 xxx wpa_supplicant[2125]: wlx54e6fc8d208e: AP-ENABLED
Feb 12 20:23:08 xxx wpa_supplicant[2125]: wlx54e6fc8d208e: CTRL-EVENT-CONNECTED - Connection to 54:e6:fc:8d:20:8e completed [id=0 id_str=]
Feb 12 20:23:11 xxx systemd[1]: systemd-rfkill.service: Succeeded.
Message from syslogd@localhost at Feb 12 20:23:25 ...
 kernel:[   77.921372] Internal error: Oops: 96000004 [#1] PREEMPT SMP
 kernel:[   78.152254] Code: d5384101 b9402262 b9401020 11000400 (f8626a99)
Feb 12 20:23:25 xxx kernel: Unable to handle kernel paging request at virtual address 0005001700000048
Feb 12 20:23:25 xxx kernel: Mem abort info:
Feb 12 20:23:25 xxx kernel:   ESR = 0x96000004
Feb 12 20:23:25 xxx kernel:   EC = 0x25: DABT (current EL), IL = 32 bits
Feb 12 20:23:25 xxx kernel:   SET = 0, FnV = 0
Feb 12 20:23:25 xxx kernel:   EA = 0, S1PTW = 0
Feb 12 20:23:25 xxx kernel: Data abort info:
Feb 12 20:23:25 xxx kernel:   ISV = 0, ISS = 0x00000004
Feb 12 20:23:25 xxx kernel:   CM = 0, WnR = 0
Feb 12 20:23:25 xxx kernel: [0005001700000048] address between user and kernel address ranges
Feb 12 20:23:25 xxx kernel: Internal error: Oops: 96000004 [#1] PREEMPT SMP
Feb 12 20:23:25 xxx kernel: Modules linked in: ath9k_htc ath9k_common ath9k_hw mac80211 ath cfg80211 rfkill libarc4 cdc_ether usbnet uas nf_log_ipv4 nf_log_common nft_limit cpufreq_powersave cpufreq_conservative xt_tcpudp xt_multiport xt_LOG xt_limit xt_conntrack nft_counter nft_chain_nat xt_MASQUERADE nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nft_compat nf_tables nfnetlink meson_rng rng_core meson_gxbb_wdt scpi_hwmon ip_tables x_tables dwmac_generic realtek dwmac_meson8b
Feb 12 20:23:25 xxx kernel: CPU: 1 PID: 2125 Comm: wpa_supplicant Not tainted 5.4.12-meson64 #19.11.8
Feb 12 20:23:25 xxx kernel: Hardware name: Hardkernel ODROID-C2 (DT)
Feb 12 20:23:25 xxx kernel: pstate: 60000005 (nZCv daif -PAN -UAO)
Feb 12 20:23:25 xxx kernel: pc : __kmalloc_node_track_caller+0x150/0x288
Feb 12 20:23:25 xxx kernel: lr : __kmalloc_node_track_caller+0x4c/0x288
Feb 12 20:23:25 xxx kernel: sp : ffff800010603710
Feb 12 20:23:25 xxx kernel: x29: ffff800010603710 x28: 0000000000000014
Feb 12 20:23:25 xxx kernel: x27: ffff80001249d3c0 x26: ffff000042d90d00
Feb 12 20:23:25 xxx kernel: x25: 00000000ffffffff x24: 0000000000159801
Feb 12 20:23:25 xxx kernel: x23: ffff800011c67510 x22: 00000000ffffffff
Feb 12 20:23:25 xxx kernel: x21: 00000000000928c0 x20: 0005001700000048
Feb 12 20:23:25 xxx kernel: x19: ffff000007303800 x18: 0000000000000000
Feb 12 20:23:25 xxx kernel: x17: 0000000000000000 x16: 0000000000000000
Feb 12 20:23:25 xxx kernel: x15: 0000000000000000 x14: 85a901e7583f6960
Feb 12 20:23:25 xxx kernel: x13: 3c82001b6c5b05ca x12: 32d0f6c2e6c1b305
Feb 12 20:23:25 xxx kernel: x11: ed25b09923fa1d1c x10: 32b5a2a8b0fc50fa
Feb 12 20:23:25 xxx kernel: x9 : 0000000000000000 x8 : ffff00003c5a1020
Feb 12 20:23:25 xxx kernel: x7 : 0000000000000000 x6 : ffff00003c5a1020
Feb 12 20:23:25 xxx kernel: x5 : 0000000000000020 x4 : 0000000000000000
Feb 12 20:23:25 xxx kernel: x3 : 0000000000159801 x2 : 0000000000000000
Feb 12 20:23:25 xxx kernel: x1 : ffff00003c56aac0 x0 : 0000000000000001
Feb 12 20:23:25 xxx kernel: Call trace:
Feb 12 20:23:25 xxx kernel:  __kmalloc_node_track_caller+0x150/0x288
Feb 12 20:23:25 xxx kernel:  __kmalloc_reserve.isra.56+0x44/0xa0
Feb 12 20:23:25 xxx kernel:  pskb_expand_head+0x70/0x2d0
Feb 12 20:23:25 xxx kernel:  netlink_trim+0xa0/0xe0
Feb 12 20:23:25 xxx kernel:  netlink_unicast+0x54/0x1f8
Feb 12 20:23:25 xxx kernel:  nl80211_tx_mgmt+0x32c/0x370 [cfg80211]
Feb 12 20:23:25 xxx kernel:  genl_family_rcv_msg+0x1dc/0x3b0
Feb 12 20:23:25 xxx kernel:  genl_rcv_msg+0x58/0xd0
Feb 12 20:23:25 xxx kernel:  netlink_rcv_skb+0x58/0x118
Feb 12 20:23:25 xxx kernel:  genl_rcv+0x34/0x48
Feb 12 20:23:25 xxx kernel:  netlink_unicast+0x180/0x1f8
Feb 12 20:23:25 xxx kernel:  netlink_sendmsg+0x198/0x338
Feb 12 20:23:25 xxx kernel:  sock_sendmsg+0x44/0x50
Feb 12 20:23:25 xxx kernel:  ____sys_sendmsg+0x250/0x290
Feb 12 20:23:25 xxx kernel:  ___sys_sendmsg+0x80/0xc0
Feb 12 20:23:25 xxx kernel:  __sys_sendmsg+0x68/0xb8
Feb 12 20:23:25 xxx kernel:  __arm64_sys_sendmsg+0x20/0x28
Feb 12 20:23:25 xxx kernel:  el0_svc_common.constprop.2+0x88/0x150
Feb 12 20:23:25 xxx kernel:  el0_svc_handler+0x20/0x80
Feb 12 20:23:25 xxx kernel:  el0_svc+0x8/0xc
Feb 12 20:23:25 xxx kernel: Code: d5384101 b9402262 b9401020 11000400 (f8626a99)
Feb 12 20:23:25 xxx kernel: ---[ end trace 7b6592514db85574 ]---
Message from syslogd@localhost at Feb 12 20:23:26 ...
 kernel:[   78.799696] Internal error: Oops: 96000004 [#2] PREEMPT SMP
 kernel:[   79.010560] Code: d5384101 b9402262 b9401020 11000400 (f8626a99)
Feb 12 20:23:26 xxx kernel: Unable to handle kernel paging request at virtual address 0005001700000048
Feb 12 20:23:26 xxx kernel: Mem abort info:
Feb 12 20:23:26 xxx kernel:   ESR = 0x96000004
Feb 12 20:23:26 xxx kernel:   EC = 0x25: DABT (current EL), IL = 32 bits
Feb 12 20:23:26 xxx kernel:   SET = 0, FnV = 0
Feb 12 20:23:26 xxx kernel:   EA = 0, S1PTW = 0
Feb 12 20:23:26 xxx kernel: Data abort info:
Feb 12 20:23:26 xxx kernel:   ISV = 0, ISS = 0x00000004
Feb 12 20:23:26 xxx kernel:   CM = 0, WnR = 0
Feb 12 20:23:26 xxx kernel: [0005001700000048] address between user and kernel address ranges
Feb 12 20:23:26 xxx kernel: Internal error: Oops: 96000004 [#2] PREEMPT SMP
Feb 12 20:23:26 xxx kernel: Modules linked in: ath9k_htc ath9k_common ath9k_hw mac80211 ath cfg80211 rfkill libarc4 cdc_ether usbnet uas nf_log_ipv4 nf_log_common nft_limit cpufreq_powersave cpufreq_conservative xt_tcpudp xt_multiport xt_LOG xt_limit xt_conntrack nft_counter nft_chain_nat xt_MASQUERADE nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nft_compat nf_tables nfnetlink meson_rng rng_core meson_gxbb_wdt scpi_hwmon ip_tables x_tables dwmac_generic realtek dwmac_meson8b
Feb 12 20:23:26 xxx kernel: CPU: 1 PID: 7 Comm: kworker/u8:0 Tainted: G      D           5.4.12-meson64 #19.11.8
Feb 12 20:23:26 xxx kernel: Hardware name: Hardkernel ODROID-C2 (DT)
Feb 12 20:23:26 xxx kernel: Workqueue: phy0 ath9k_led_work [ath9k_htc]
Feb 12 20:23:26 xxx kernel: pstate: 60000005 (nZCv daif -PAN -UAO)
Feb 12 20:23:26 xxx kernel: pc : __kmalloc_node_track_caller+0x150/0x288
Feb 12 20:23:26 xxx kernel: lr : __kmalloc_node_track_caller+0x4c/0x288
Feb 12 20:23:26 xxx kernel: sp : ffff80001005bbe0
Feb 12 20:23:26 xxx kernel: x29: ffff80001005bbe0 x28: 0000000000000000
Feb 12 20:23:26 xxx kernel: x27: ffff00000735a0b8 x26: ffff80001005bd70
Feb 12 20:23:26 xxx kernel: x25: 00000000ffffffff x24: 0000000000159801
Feb 12 20:23:26 xxx kernel: x23: ffff800011c62c54 x22: 00000000ffffffff
Feb 12 20:23:26 xxx kernel: x21: 0000000000082a20 x20: 0005001700000048
Feb 12 20:23:26 xxx kernel: x19: ffff000007303800 x18: 0000000000000010
Feb 12 20:23:26 xxx kernel: x17: 0000000000000000 x16: 0000000000000000
Feb 12 20:23:26 xxx kernel: x15: 0000000000000000 x14: 3239353662372065
Feb 12 20:23:26 xxx kernel: x13: 0000000000000000 x12: 0000000000000001
Feb 12 20:23:26 xxx kernel: x11: 0000000000000000 x10: 00000000000009f0
Feb 12 20:23:26 xxx kernel: x9 : ffff80001005bd60 x8 : fefefefefefefeff
Feb 12 20:23:26 xxx kernel: x7 : 0000000000000001 x6 : 0000000000000064
Feb 12 20:23:26 xxx kernel: x5 : 000000000000000c x4 : 0000000000000000
Feb 12 20:23:26 xxx kernel: x3 : 0000000000159801 x2 : 0000000000000000
Feb 12 20:23:26 xxx kernel: x1 : ffff000007395580 x0 : 0000000000000001
Feb 12 20:23:26 xxx kernel: Call trace:
Feb 12 20:23:26 xxx kernel:  __kmalloc_node_track_caller+0x150/0x288
Feb 12 20:23:26 xxx kernel:  __kmalloc_reserve.isra.56+0x44/0xa0
Feb 12 20:23:26 xxx kernel:  __alloc_skb+0x84/0x198
Feb 12 20:23:26 xxx kernel:  ath9k_wmi_cmd+0x6c/0x1c8 [ath9k_htc]
Feb 12 20:23:26 xxx kernel:  ath9k_reg_rmw+0x7c/0x170 [ath9k_htc]
Feb 12 20:23:26 xxx kernel:  ath9k_hw_set_gpio+0xa8/0xf0 [ath9k_hw]
Feb 12 20:23:26 xxx kernel:  ath9k_led_work+0x28/0x30 [ath9k_htc]
Feb 12 20:23:26 xxx kernel:  process_one_work+0x1e0/0x338
Feb 12 20:23:26 xxx kernel:  worker_thread+0x40/0x440
Feb 12 20:23:26 xxx kernel:  kthread+0x120/0x128
Feb 12 20:23:26 xxx kernel:  ret_from_fork+0x10/0x18
Feb 12 20:23:26 xxx kernel: Code: d5384101 b9402262 b9401020 11000400 (f8626a99)
Feb 12 20:23:26 xxx kernel: ---[ end trace 7b6592514db85575 ]---
Message from syslogd@localhost at Feb 12 20:23:47 ...
 kernel:[   99.419758] Internal error: Oops: 96000004 [#3] PREEMPT SMP
 kernel:[   99.642872] Code: d5384101 b9402262 b9401020 11000400 (f8626a99)
Feb 12 20:23:46 xxx kernel: Unable to handle kernel paging request at virtual address 0005001700000048
Feb 12 20:23:46 xxx kernel: Mem abort info:
Feb 12 20:23:46 xxx kernel:   ESR = 0x96000004
Feb 12 20:23:46 xxx kernel:   EC = 0x25: DABT (current EL), IL = 32 bits
Feb 12 20:23:46 xxx kernel:   SET = 0, FnV = 0
Feb 12 20:23:46 xxx kernel:   EA = 0, S1PTW = 0
Feb 12 20:23:46 xxx kernel: Data abort info:
Feb 12 20:23:46 xxx kernel:   ISV = 0, ISS = 0x00000004
Feb 12 20:23:46 xxx kernel:   CM = 0, WnR = 0
Feb 12 20:23:46 xxx kernel: [0005001700000048] address between user and kernel address ranges
Feb 12 20:23:47 xxx kernel: Internal error: Oops: 96000004 [#3] PREEMPT SMP
Feb 12 20:23:47 xxx kernel: Modules linked in: ath9k_htc ath9k_common ath9k_hw mac80211 ath cfg80211 rfkill libarc4 cdc_ether usbnet uas nf_log_ipv4 nf_log_common nft_limit cpufreq_powersave cpufreq_conservative xt_tcpudp xt_multiport xt_LOG xt_limit xt_conntrack nft_counter nft_chain_nat xt_MASQUERADE nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nft_compat nf_tables nfnetlink meson_rng rng_core meson_gxbb_wdt scpi_hwmon ip_tables x_tables dwmac_generic realtek dwmac_meson8b
Feb 12 20:23:47 xxx kernel: CPU: 1 PID: 1557 Comm: systemd-timesyn Tainted: G      D           5.4.12-meson64 #19.11.8
Feb 12 20:23:47 xxx kernel: Hardware name: Hardkernel ODROID-C2 (DT)
Feb 12 20:23:47 xxx kernel: pstate: 60000005 (nZCv daif -PAN -UAO)
Feb 12 20:23:47 xxx kernel: pc : __kmalloc_node_track_caller+0x150/0x288
Feb 12 20:23:47 xxx kernel: lr : __kmalloc_node_track_caller+0x4c/0x288
Feb 12 20:23:47 xxx kernel: sp : ffff8000105f37c0
Feb 12 20:23:47 xxx kernel: x29: ffff8000105f37c0 x28: 0000000000000000
Feb 12 20:23:47 xxx kernel: x27: 0000000000000cc0 x26: 0000000000000000
Feb 12 20:23:47 xxx kernel: x25: 00000000ffffffff x24: 0000000000159801
Feb 12 20:23:47 xxx kernel: x23: ffff800011c62c54 x22: 00000000ffffffff
Feb 12 20:23:47 xxx kernel: x21: 0000000000082cc0 x20: 0005001700000048
Feb 12 20:23:47 xxx kernel: x19: ffff000007303800 x18: 0000000000000000
Feb 12 20:23:47 xxx kernel: x17: 0000000000000000 x16: 0000000000000000
Feb 12 20:23:47 xxx kernel: x15: 0000000000000000 x14: 0000000000000000
Feb 12 20:23:47 xxx kernel: x13: 0000000000000001 x12: 0000000000000000
Feb 12 20:23:47 xxx kernel: x11: 0000000000000000 x10: 0000000000000000
Feb 12 20:23:47 xxx kernel: x9 : 0000000000000000 x8 : 00000000000005c8
Feb 12 20:23:47 xxx kernel: x7 : 0000000000000014 x6 : 0000000000000000
Feb 12 20:23:47 xxx kernel: x5 : ffff000042d90e00 x4 : ffff00007fbb42f0
Feb 12 20:23:47 xxx kernel: x3 : 0000000000159801 x2 : 0000000000000000
Feb 12 20:23:47 xxx kernel: x1 : ffff00007ef4e3c0 x0 : 0000000000000001
Feb 12 20:23:47 xxx kernel: Call trace:
Feb 12 20:23:47 xxx kernel:  __kmalloc_node_track_caller+0x150/0x288
Feb 12 20:23:47 xxx kernel:  __kmalloc_reserve.isra.56+0x44/0xa0
Feb 12 20:23:47 xxx kernel:  __alloc_skb+0x84/0x198
Feb 12 20:23:47 xxx kernel:  alloc_skb_with_frags+0x50/0x1e0
Feb 12 20:23:47 xxx kernel:  sock_alloc_send_pskb+0x200/0x238
Feb 12 20:23:47 xxx kernel:  sock_alloc_send_skb+0x1c/0x28
Feb 12 20:23:47 xxx kernel:  __ip_append_data.isra.59+0x770/0xc10
Feb 12 20:23:47 xxx kernel:  ip_make_skb+0xe8/0x140
Feb 12 20:23:47 xxx kernel:  udp_sendmsg+0x794/0xa10
Feb 12 20:23:47 xxx kernel:  inet_sendmsg+0x40/0x68
Feb 12 20:23:47 xxx kernel:  sock_sendmsg+0x44/0x50
Feb 12 20:23:47 xxx kernel:  __sys_sendto+0xcc/0x130
Feb 12 20:23:47 xxx kernel:  __arm64_sys_sendto+0x24/0x30
Feb 12 20:23:47 xxx kernel:  el0_svc_common.constprop.2+0x88/0x150
Feb 12 20:23:47 xxx kernel:  el0_svc_handler+0x20/0x80
Feb 12 20:23:47 xxx kernel:  el0_svc+0x8/0xc
Feb 12 20:23:47 xxx kernel: Code: d5384101 b9402262 b9401020 11000400 (f8626a99)
Feb 12 20:23:47 xxx kernel: ---[ end trace 7b6592514db85576 ]---
New bugs(kernel crash - odroid reboot) arrived after upgrade to 5.4.13-meson64 #20.02.2 SMP PREEMPT Mon Feb 17 23:18:02 CET 2020 aarch64 GNU/Linux !
After connect TP-Link TL-WN722N V1 USB WiFi dongle:
Feb 18 15:05:08 rou2 kernel: usb 1-1.1: new high-speed USB device number 5 using dwc2
Feb 18 15:05:08 rou2 kernel: usb 1-1.1: New USB device found, idVendor=0cf3, idProduct=9271, bcdDevice= 1.08
Feb 18 15:05:08 rou2 kernel: usb 1-1.1: New USB device strings: Mfr=16, Product=32, SerialNumber=48
Feb 18 15:05:08 rou2 kernel: usb 1-1.1: Product: USB2.0 WLAN
Feb 18 15:05:08 rou2 kernel: usb 1-1.1: Manufacturer: ATHEROS
Feb 18 15:05:08 rou2 kernel: usb 1-1.1: SerialNumber: 12345
Feb 18 15:05:08 rou2 kernel: usb 1-1.1: ath9k_htc: Firmware ath9k_htc/htc_9271-1.4.0.fw requested
Feb 18 15:05:08 rou2 kernel: usb 1-1.1: ath9k_htc: Transferred FW: ath9k_htc/htc_9271-1.4.0.fw, size: 51008
Feb 18 15:05:09 rou2 kernel: ath9k_htc 1-1.1:1.0: ath9k_htc: HTC initialized with 33 credits
Feb 18 15:05:09 rou2 kernel: ath9k_htc 1-1.1:1.0: ath9k_htc: FW Version: 1.4
Feb 18 15:05:09 rou2 kernel: ath9k_htc 1-1.1:1.0: FW RMW support: On
Feb 18 15:05:09 rou2 kernel: ath: EEPROM regdomain: 0x809c
Feb 18 15:05:09 rou2 kernel: ath: EEPROM indicates we should expect a country code
Feb 18 15:05:09 rou2 kernel: ath: doing EEPROM country->regdmn map search
Feb 18 15:05:09 rou2 kernel: ath: country maps to regdmn code: 0x52
Feb 18 15:05:09 rou2 kernel: ath: Country alpha2 being used: CN
Feb 18 15:05:09 rou2 kernel: ath: Regpair used: 0x52
Feb 18 15:05:09 rou2 kernel: ieee80211 phy1: Atheros AR9271 Rev:1
Feb 18 15:05:09 rou2 systemd-udevd[2227]: Using default interface naming scheme 'v240'.
Feb 18 15:05:09 rou2 systemd[1]: Starting Load/Save RF Kill Switch Status...
Feb 18 15:05:09 rou2 systemd-udevd[2227]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Feb 18 15:05:09 rou2 kernel: ath9k_htc 1-1.1:1.0 wlx54e6fc8d208e: renamed from wlan0
Feb 18 15:05:09 rou2 systemd[1]: Started Load/Save RF Kill Switch Status.
Feb 18 15:05:09 rou2 systemd-udevd[2227]: Process '/sbin/iwconfig wlan0 power off' failed with exit code 250.
Feb 18 15:05:09 rou2 systemd-udevd[2245]: Using default interface naming scheme 'v240'.
Feb 18 15:05:09 rou2 systemd[1]: Found device AR9271 802.11n.
Feb 18 15:05:09 rou2 systemd[1]: Started ifup for wlx54e6fc8d208e.
Message from syslogd@localhost at Feb 18 15:05:10 ...
 kernel:[  153.101849] Internal error: Oops: 96000004 [#1] PREEMPT SMP
 kernel:[  153.291728] Code: b4000d56 b9402262 b9401020 11000400 (f8626ad8)
Feb 18 15:05:09 rou2 wpa_supplicant[2262]: Successfully initialized wpa_supplicant
Feb 18 15:05:10 rou2 kernel: Unable to handle kernel paging request at virtual address 00000010000002c0
Feb 18 15:05:10 rou2 kernel: Mem abort info:
Feb 18 15:05:10 rou2 kernel:   ESR = 0x96000004
Feb 18 15:05:10 rou2 kernel:   EC = 0x25: DABT (current EL), IL = 32 bits
Feb 18 15:05:10 rou2 kernel:   SET = 0, FnV = 0
Feb 18 15:05:10 rou2 kernel:   EA = 0, S1PTW = 0
Feb 18 15:05:10 rou2 kernel: Data abort info:
Feb 18 15:05:10 rou2 kernel:   ISV = 0, ISS = 0x00000004
Feb 18 15:05:10 rou2 kernel:   CM = 0, WnR = 0
Feb 18 15:05:10 rou2 kernel: user pgtable: 4k pages, 48-bit VAs, pgdp=000000003ca51000
Feb 18 15:05:10 rou2 kernel: [00000010000002c0] pgd=0000000000000000
Feb 18 15:05:10 rou2 kernel: Internal error: Oops: 96000004 [#1] PREEMPT SMP
Feb 18 15:05:10 rou2 kernel: Modules linked in: ath9k_htc ath9k_common ath9k_hw mac80211 ath cfg80211 rfkill libarc4 option huawei_cdc_ncm cdc_wdm usb_wwan cdc_ncm usbserial usbnet nf_log_ipv4 nf_log_common nft_limit cpufreq_powersave cpufreq_conservative xt_tcpudp xt_multiport xt_LOG xt_limit xt_conntrack nft_counter nft_chain_nat xt_MASQUERADE nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nft_compat nf_tables nfnetlink scpi_hwmon meson_rng rng_core meson_gxbb_wdt ip_tables x_tables dwmac_generic realtek dwmac_meson8b
Feb 18 15:05:10 rou2 kernel: CPU: 2 PID: 2262 Comm: wpa_supplicant Not tainted 5.4.13-meson64 #20.02.2
Feb 18 15:05:10 rou2 kernel: Hardware name: Hardkernel ODROID-C2 (DT)
Feb 18 15:05:10 rou2 kernel: pstate: 60000005 (nZCv daif -PAN -UAO)
Feb 18 15:05:10 rou2 kernel: pc : __kmalloc+0xc0/0x278
Feb 18 15:05:10 rou2 kernel: lr : __kmalloc+0x44/0x278
Feb 18 15:05:10 rou2 kernel: sp : ffff800011b73cb0
Feb 18 15:05:10 rou2 kernel: x29: ffff800011b73cb0 x28: ffff00003cae3900
Feb 18 15:05:10 rou2 kernel: x27: ffff800010f8d270 x26: ffff800011b73e50
Feb 18 15:05:10 rou2 kernel: x25: ffff80001149cec0 x24: 0000000000000000
Feb 18 15:05:10 rou2 kernel: x23: 0000000000021502 x22: 00000010000002c0
Feb 18 15:05:10 rou2 kernel: x21: ffff800010c5efe4 x20: 0000000000000dc0
Feb 18 15:05:10 rou2 kernel: x19: ffff000005303400 x18: 0000000000000000
Feb 18 15:05:10 rou2 kernel: x17: 0000000000000000 x16: 0000000000000000
Feb 18 15:05:10 rou2 kernel: x15: 0000000000000000 x14: 0000000000000000
Feb 18 15:05:10 rou2 kernel: x13: 0000000000000000 x12: 0000000000000000
Feb 18 15:05:10 rou2 kernel: x11: 0000000000000000 x10: 0000000000000000
Feb 18 15:05:10 rou2 kernel: x9 : 0000000000000000 x8 : 000000000002fb27
Feb 18 15:05:10 rou2 kernel: x7 : 0000000000000001 x6 : 0000000000000000
Feb 18 15:05:10 rou2 kernel: x5 : 0000000000000000 x4 : 0000000000000000
Feb 18 15:05:10 rou2 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Feb 18 15:05:10 rou2 kernel: x1 : ffff00003cae3900 x0 : 0000000000000001
Feb 18 15:05:10 rou2 kernel: Call trace:
Feb 18 15:05:10 rou2 kernel:  __kmalloc+0xc0/0x278
Feb 18 15:05:10 rou2 kernel:  sk_prot_alloc+0xa4/0x178
Feb 18 15:05:10 rou2 kernel:  sk_alloc+0x34/0x198
Feb 18 15:05:10 rou2 kernel:  packet_create+0x78/0x238
Feb 18 15:05:10 rou2 kernel:  __sock_create+0x148/0x210
Feb 18 15:05:10 rou2 kernel:  __sys_socket+0x5c/0xf0
Feb 18 15:05:10 rou2 kernel:  __arm64_sys_socket+0x1c/0x28
Feb 18 15:05:10 rou2 kernel:  el0_svc_common.constprop.2+0x88/0x150
Feb 18 15:05:10 rou2 kernel:  el0_svc_handler+0x20/0x80
Feb 18 15:05:10 rou2 kernel:  el0_svc+0x8/0xc
Feb 18 15:05:10 rou2 kernel: Code: b4000d56 b9402262 b9401020 11000400 (f8626ad8)
Feb 18 15:05:10 rou2 kernel: ---[ end trace 3d2076fdded0aff2 ]---
Feb 18 15:05:10 rou2 kernel: ------------[ cut here ]------------
Feb 18 15:05:10 rou2 kernel: kernel BUG at kernel/cgroup/cgroup.c:1421!
After disconnect TP-Link TL-WN722N V1 USB WiFi dongle:
Message from syslogd@localhost at Feb 18 15:02:21 ...
 kernel:[  587.522450] Internal error: Oops: 96000004 [#1] PREEMPT SMP
Feb 18 15:02:21 rou2 kernel: ------------[ cut here ]------------
Feb 18 15:02:21 rou2 kernel: refcount_t: underflow; use-after-free.
Feb 18 15:02:21 rou2 kernel: WARNING: CPU: 0 PID: 0 at lib/refcount.c:190 refcount_sub_and_test_checked+0xd8/0xe0
Feb 18 15:02:21 rou2 kernel: Modules linked in: ath9k_htc ath9k_common ath9k_hw mac80211 ath cfg80211 rfkill libarc4 huawei_cdc_ncm cdc_wdm cdc_ncm option usbnet usb_wwan usbserial cpufreq_powersave cpufreq_conservative nf_log_ipv4 nf_log_common nft_limit xt_tcpudp xt_multiport xt_LOG xt_limit xt_conntrack nft_counter nft_chain_nat xt_MASQUERADE nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nft_compat nf_tables nfnetlink meson_rng rng_core meson_gxbb_wdt scpi_hwmon ip_tables x_tables dwmac_generic realtek dwmac_meson8b
Feb 18 15:02:21 rou2 kernel: CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.13-meson64 #20.02.2
Feb 18 15:02:21 rou2 kernel: Hardware name: Hardkernel ODROID-C2 (DT)
Feb 18 15:02:21 rou2 kernel: pstate: 20000005 (nzCv daif -PAN -UAO)
Feb 18 15:02:21 rou2 kernel: pc : refcount_sub_and_test_checked+0xd8/0xe0
Feb 18 15:02:21 rou2 kernel: lr : refcount_sub_and_test_checked+0xd8/0xe0
Feb 18 15:02:21 rou2 kernel: sp : ffff800010003cc0
Feb 18 15:02:21 rou2 kernel: x29: ffff800010003cc0 x28: ffff8000113eb1c0
Feb 18 15:02:21 rou2 kernel: x27: ffff8000113be6c0 x26: ffff8000113e18c8
Feb 18 15:02:21 rou2 kernel: x25: 0000000000000060 x24: 0000000000000002
Feb 18 15:02:21 rou2 kernel: x23: ffff0000411f30ee x22: 0000000000000001
Feb 18 15:02:21 rou2 kernel: x21: ffff0000412e7200 x20: 0000000000000078
Feb 18 15:02:21 rou2 kernel: x19: 0000000000000000 x18: ffff8000113fd000
Feb 18 15:02:21 rou2 kernel: x17: 0000000000000000 x16: 0000000000000000
Feb 18 15:02:21 rou2 kernel: x15: 00000000fffffff0 x14: ffff80001150c100
Feb 18 15:02:21 rou2 kernel: x13: 0000000000000000 x12: ffff80001150b000
Feb 18 15:02:21 rou2 kernel: x11: ffff8000113fd000 x10: ffff80001150b750
Feb 18 15:02:21 rou2 kernel: x9 : 0000000000000000 x8 : 0000000000000001
Feb 18 15:02:21 rou2 kernel: x7 : 000000000000016d x6 : ffff80001150b000
Feb 18 15:02:21 rou2 kernel: x5 : 0000000000000000 x4 : 0000000000000001
Feb 18 15:02:21 rou2 kernel: x3 : ffff8000113e4b50 x2 : 0000000000000004
Feb 18 15:02:21 rou2 kernel: x1 : b723429df7e70000 x0 : 0000000000000000
Feb 18 15:02:21 rou2 kernel: Call trace:
Feb 18 15:02:21 rou2 kernel:  refcount_sub_and_test_checked+0xd8/0xe0
Feb 18 15:02:21 rou2 kernel:  __sock_wfree+0x20/0x48
Feb 18 15:02:21 rou2 kernel:  skb_release_head_state+0x40/0xc0
Feb 18 15:02:21 rou2 kernel:  skb_release_all+0x14/0x30
Feb 18 15:02:21 rou2 kernel:  kfree_skb+0x2c/0x58
Feb 18 15:02:21 rou2 kernel:  ath9k_htc_txcompletion_cb+0xcc/0xd8 [ath9k_htc]
Feb 18 15:02:21 rou2 kernel:  hif_usb_regout_cb+0x44/0x80 [ath9k_htc]
Feb 18 15:02:21 rou2 kernel:  __usb_hcd_giveback_urb+0x80/0xf8
Feb 18 15:02:21 rou2 kernel:  usb_giveback_urb_bh+0xb0/0x108
Feb 18 15:02:21 rou2 kernel:  tasklet_action_common.isra.15+0xc4/0x188
Feb 18 15:02:21 rou2 kernel:  tasklet_hi_action+0x24/0x30
Feb 18 15:02:21 rou2 kernel:  __do_softirq+0x124/0x240
Feb 18 15:02:21 rou2 kernel:  irq_exit+0xb8/0xc8
Feb 18 15:02:21 rou2 kernel:  __handle_domain_irq+0x64/0xb8
Feb 18 15:02:21 rou2 kernel:  gic_handle_irq+0x50/0xa0
Feb 18 15:02:21 rou2 kernel:  el1_irq+0xb8/0x180
Feb 18 15:02:21 rou2 kernel:  arch_cpu_idle+0x10/0x18
Feb 18 15:02:21 rou2 kernel:  do_idle+0x204/0x290
Feb 18 15:02:21 rou2 kernel:  cpu_startup_entry+0x24/0x28
Feb 18 15:02:21 rou2 kernel:  rest_init+0xd4/0xe0
Feb 18 15:02:21 rou2 kernel:  arch_call_rest_init+0xc/0x14
Feb 18 15:02:21 rou2 kernel:  start_kernel+0x420/0x44c
Feb 18 15:02:21 rou2 kernel: ---[ end trace da7d1f37f9aaa781 ]---
Feb 18 15:02:21 rou2 kernel: usb 1-1.1: USB disconnect, device number 4
Feb 18 15:02:21 rou2 kernel: Unable to handle kernel NULL pointer dereference at virtual address 0000000000000200
Feb 18 15:02:21 rou2 kernel: Mem abort info:
Feb 18 15:02:21 rou2 kernel:   ESR = 0x96000004
Feb 18 15:02:21 rou2 kernel:   EC = 0x25: DABT (current EL), IL = 32 bits
Feb 18 15:02:21 rou2 kernel:   SET = 0, FnV = 0
Feb 18 15:02:21 rou2 kernel:   EA = 0, S1PTW = 0
Feb 18 15:02:21 rou2 kernel: Data abort info:
Feb 18 15:02:21 rou2 kernel:   ISV = 0, ISS = 0x00000004
Feb 18 15:02:21 rou2 kernel:   CM = 0, WnR = 0
Feb 18 15:02:21 rou2 kernel: user pgtable: 4k pages, 48-bit VAs, pgdp=0000000042ad3000
Feb 18 15:02:21 rou2 kernel: [0000000000000200] pgd=0000000000000000
Feb 18 15:02:21 rou2 kernel: Internal error: Oops: 96000004 [#1] PREEMPT SMP
Feb 18 15:02:21 rou2 kernel: CPU: 0 PID: 2544 Comm: kworker/0:0 Tainted: G        W         5.4.13-meson64 #20.02.2
Feb 18 15:02:21 rou2 kernel: Workqueue: usb_hub_wq hub_event
Feb 18 15:02:21 rou2 kernel: pstate: 40000005 (nZcv daif -PAN -UAO)
Feb 18 15:02:21 rou2 kernel: pc : skb_release_data+0x84/0x178
Feb 18 15:02:21 rou2 kernel: lr : skb_release_all+0x24/0x30
Feb 18 15:02:21 rou2 kernel: sp : ffff800010003d20
Feb 18 15:02:21 rou2 kernel: x29: ffff800010003d20 x28: ffff00007eec63c0
Feb 18 15:02:21 rou2 kernel: cpufreq: __target_index: Failed to change cpu frequency: -5
