I have checked that the GPIO Interruptions are very slow.
If i receive a wave in a GPIO with  IRQ edge enable, for a frequency of 100Hz, all IRQs detected are right (100 interruptions received)
However if i increase the frequency of the wave up to 500Hz, i can't detect all the IRQs received, (50 interruptions received more or less)
Well, i think maybe, the solution is to change the following kernel parameter:     CONFIG_HZ=1000 instead CONFIG_HZ=250 (default)
What do you think ??
Is there other solution??
Thanks a lot in advance
After more checks, the problem is about the pulse width. I mean, i am receiving a pulse wave in GPIO IRQ pin.
If the width of the pulse is big, no problem ... all IRQs are right, but if the pulse width is very little, a lot of IRQ are not detected.
The pulse with that i need to receive is only 20 useg
So it is not a problem of frequency
