no boot after upgrade && activate hdmi output
Guest Guest
Hi all,
got a hummingboard i4-pro installed with armbian debian vanilla.
After
apt-get update && apt-get upgrade
system won't come up again. Anybody else?
How to activate hdmi output for debugging? Am I the only one?
Even more:
Got a BlueBeach mini PCI-e SATA 2-ports controller, recognized as:
  01:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02) (prog-if 01 [AHCI 1.0])Subsystem: ASMedia Technology Inc. Device 1060
but my attached harddrive (2,5", separate psu) will not be assigned as /dev/sdX
Any idea where to start to troubleshoot?
Thanks a lot guys
Vanilla kernels does not have HDMI output, only serial console. It's written in bold @download section under bugs and limitations.
Why mPCI does not work is hard to say but one is for sure - only PCI based devices are supported so if this uses mSATA it won't work.
me too. I have Orange Pi One. Yesterday try "apt-get update && apt-get upgrade" from desktop version Armbian 5.10.
After I type reboot in console Orange turn off and when I plug adapter it doesnt boot, on board light up only diods in RJ45 connector
today I try new image 5.13, it work, but when it booting there was errors: buffer I/O error and emmc(somethink text) error
  Quote
That indicates some troubles with media, possible hardware failure. Please check your SD card for errors - you can do with armbianmonitor
Guest Guest
Ok I understand that the half-size mini-PCI-E port is only for pci-based cards.
At the back/bottom the mSATA port is working with my mSATA 32GB SSD.
Now I got another 2-port MiniPCIE card fitting into the bottom mSATA port, which is described as a MiniPCIE card. It's not working too, obviously because the other way round the mSATA port does not understand miniPCIE cards. https://www.amazon.de/gp/product/B00ORXQY2E/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Ain't there any mSATA or miniPCIE card with 2-SATA ports that work on hummingboard?
I just wanted to connect 2 SATA hard disks and do mdraid.
And still, Armbian_5.10_Cubox-i_Debian_jessie_4.5.2 will not boot after
apt-get-update && apt-get upgrade
I can't be the only one ?? It's 100% reproducable.
  Quote
I found out what is happening but don't know where exactly is a problem yet. MMC0 become MMC1 and if you correct boot parameters and fstab it will boot.
  Quote
In theory this or similar in the top mini PCI slot:
http://www.dx.com/p/iocrest-io-mpce1061-2i-mini-pci-express-sata-3-0-controller-card-green-383391#.V1Mjh_l97AQ
Guest Silvio
I FINALLY FOUND   :o   :lol:
For all who are looking for a Dual-SATA Mini PCI-E adapter for attaching two harddisks to the Hummingboard i4-pro, THIS adapter is the ONLY one (out of ~8 tested adapters) WHICH WORKS:
I'm german, so I got no english/international amazon link.
Unfortunately the product has no "real name" - even the driver cd nor the manual tells a brand name.
But if the amazon link will die someday, here's the lspci -v output:
Flags: bus master, fast devsel, latency 0, IRQ 155
I/O ports at 1020 [size=8]
I/O ports at 1030 [size=4]
I/O ports at 1028 [size=8]
I/O ports at 1034 [size=4]
I/O ports at 1000 [size=32]
Memory at 01100000 (32-bit, non-prefetchable) [size=512]
[virtual] Expansion ROM at 01200000 [disabled] [size=64K]
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Legacy Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Kernel driver in use: ahci
currently running armbian jessie legacy. I will try it on vanilla too.
Damn am I happy , just wanted to share :D
