abyss02 Posted June 2, 2016 Posted June 2, 2016 Hi there, i want to stick to the 4.4 kernel an tried to compile kernel 4.4.12 (cubietruck) via: apt-get -y install git git clone https://github.com/igorpecovnik/lib--depth 1cp lib/compile.sh .chmod +x compile.sh./compile.sh after that, i built the following directory and file: mkdir userpatches vi userpatches/lib.config and added: KERNELBRANCH="v4.4.12" (also tried KERNELBRANCH="v4.5.6") as described here: http://forum.armbian...est-kernel-447/ Whenn running ./compile, i get the following messages: │ LD [M] drivers/media/v4l2-core/tuner.o │ │ LD drivers/media/v4l2-core/built-in.o │ │ LD drivers/media/built-in.o │ │ make: *** [drivers] Error 2 │ └────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────┘ [ error ] ERROR in function compile_kernel [ common.sh:176 ] [ error ] Kernel was not built [ @host ] [ o.k. ] Process terminated # Any hints? Regards, A.
Igor Posted June 2, 2016 Posted June 2, 2016 Yes, you will need to add patches which were removed with this commit: https://github.com/igorpecovnik/lib/commit/c788fc379d4fabd5453cc490fb03865c67fe71fa At least for 4.5.6 ... for others you might need to remove certain patches.
abyss02 Posted June 2, 2016 Author Posted June 2, 2016 Thxx for the quick reply - but its just too complicated for me I will move to 4.6.1 ...
Guest SkilsiMet Posted June 3, 2016 Posted June 3, 2016 Is it possible to compile a custom kernel in a virtual machine, and transfer it over to replace the current kernel in my real my machine? If so, how can i make it happen?
nopnop2002 Posted June 7, 2016 Posted June 7, 2016 I changed compile.sh.FORCE_CHECKOUT="no" I tried, but it was the following error.[ error ] ERROR in function compile_kernel [ common.sh:176 ][ error ] Kernel was not built [ @host ][ o.k. ] Process terminated # Is this the same cause?
