Hello, I have app (in attachment) from Rasbian and I have problem when I try to install this app on Armbian.
Is it possible to run this app on Armbian?
root@mps-box-000:/home/username/Downloads# sudo dpkg -i EERaspbian_1.0.1.0.deb
(Reading database ... 113955 files and directories currently installed.)
Preparing to unpack EERaspbian_1.0.1.0.deb ...
Unpacking eelinux:armhf (1.0.1.0) over (1.0.1.0) ...
Setting up eelinux:armhf (1.0.1.0) ...
Job for eelinux.service failed because the control process exited with error code.
See "systemctl status eelinux.service" and "journalctl -xe" for details.
dpkg: error processing package eelinux:armhf (--install):
 installed eelinux:armhf package post-installation script subprocess returned error exit status 1
Processing triggers for desktop-file-utils (0.23-4) ...
Processing triggers for mime-support (3.62) ...
Errors were encountered while processing:
 eelinux:armhf
root@mps-box-000:~# systemctl status eelinux.service
● eelinux.service - EELinux device monitoring daemon
   Loaded: loaded (/lib/systemd/system/eelinux.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Mon 2020-03-23 14:14:12 CET; 15min ago
  Process: 3588 ExecStart=/opt/eelinux/stUp.sh start (code=exited, status=127)
Mar 23 14:14:12 mps-box-000 systemd[1]: Starting EELinux device monitoring daemon...
Mar 23 14:14:12 mps-box-000 stUp.sh[3588]: service starting...
Mar 23 14:14:12 mps-box-000 stUp.sh[3588]: /opt/eelinux/stUp.sh: 19: /opt/eelinux/stUp.sh: /opt/eelinux/ExplorerE: not found
Mar 23 14:14:12 mps-box-000 systemd[1]: eelinux.service: Control process exited, code=exited, status=127/n/a
Mar 23 14:14:12 mps-box-000 systemd[1]: eelinux.service: Failed with result 'exit-code'.
Mar 23 14:14:12 mps-box-000 systemd[1]: Failed to start EELinux device monitoring daemon.
