there are invalid references inside sun50i-h5-fixup.scr, I think.
I use NANOPINEO2, myself compiled linux-*-current-sunxi64_20.05.0-trunk_arm64.deb, kernel  5.4.28-sunxi64 #trunk SMP PREEMPT.
amrbianEnv.txt (reduced):
        overlay_prefix=sun50i-h5
        overlays=i2c0 uart1 uart2 usbhost1 usbhost2 usbhost3
        param_uart1_rtscts=1
        param_uart2_rtscts=1
For example, the row param_uart2_rtscts=1 leads to use following rows of sun50i-h5-fixup.scr:
        fdt get value tmp_phandle1 /soc/pinctrl@1c20800/uart2 phandle
        fdt get value tmp_phandle2 /soc/pinctrl@1c20800/uart2_rts_cts phandle
        fdt set /soc/serial@1c28800 pinctrl-names "default" "default"
        fdt set /soc/serial@1c28800 pinctrl-0 "<${tmp_phandle1}>"
        fdt set /soc/serial@1c28800 pinctrl-1 "<${tmp_phandle2}>"
        env delete tmp_phandle1 tmp_phandle2
There are some error messages during boot:
        Applying kernel provided DT fixup script (sun50i-h5-fixup.scr)
        ## Executing script at 44000000
        tmp_bank=A
        tmp_pin=21
        libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
        10046717 bytes read in 505 ms (19 MiB/s)
As a result, the RTS/CTS handshaking for UART2 is unfunctional. May be for UART1 and UART3 is the same?
I think the reason is that there are no paths /soc/pinctrl@1c20800/uart2 and /soc/pinctrl@1c20800/uart2_rts_cts inside the device tree specified by sun50i-h5-nanopi-neo2-v1.1.dtb file.
The right paths are /soc/pinctrl@1c20800/uart2-pins and /soc/pinctrl@1c20800/uart2-rts-cts-pins, I think.
Am I right? I've tried easy modification of SCR script - handshaking is now functional, but CRC is bad.
If I am right, what is the right way to correct this? Script change (how properly?), DTB change, DTBO creation, ...?
Moreover, look at this reduced listing of /sys/firmware/devicetree/base/soc/pinctrl@1c20800:
        csi-pins
        emac-rgmii-pins
        i2c0-pins
        i2c1-pins
        i2c2-pins
        i2s0-pins
        i2s1-pins
        mmc0-pins
        mmc1-pins
        mmc2-8bit-pins
        spi0-pins
        spi1-pins
        uart0-pa-pins
        uart1-pins
        uart1-rts-cts-pins
        uart2-pins
        uart2_rts_cts
        uart2-rts-cts-pins
        uart3-pins
        uart3-rts-cts-pins
        w1_pins
Why are somewhere dashes "-" and somewhere underscores "_" ?
Thank you.
10 hours ago, Java475 said:
Nobody knows what is the right way to correct this issue?
Right ! Good catch ! I seems that dashes/underscores issue appeared when we switched from 4.20.y to 5.0.y and still unfixed in 5.5.y .
I will try to fix that in the following days ...
Do I have to create my own DTBO?
In the meantime, Yes, you need to fix the overlay along the fixup script ...
EDIT: During a second look, it seems that /proc/device-tree/__symbols__/ has underscores. So, maybe both are working. I will try to figure out ...
EDIT2: Here is the commit : https://github.com/armbian/build/commit/281c8546954c7e6ec993c03632d701490464c36f
