Java475 Posted March 30, 2020 Share Posted March 30, 2020 Hi, there are invalid references inside sun50i-h5-fixup.scr, I think. I use NANOPINEO2, myself compiled linux-*-current-sunxi64_20.05.0-trunk_arm64.deb, kernel 5.4.28-sunxi64 #trunk SMP PREEMPT. amrbianEnv.txt (reduced): overlay_prefix=sun50i-h5 overlays=i2c0 uart1 uart2 usbhost1 usbhost2 usbhost3 param_uart1_rtscts=1 param_uart2_rtscts=1 For example, the row param_uart2_rtscts=1 leads to use following rows of sun50i-h5-fixup.scr: fdt get value tmp_phandle1 /soc/pinctrl@1c20800/uart2 phandle fdt get value tmp_phandle2 /soc/pinctrl@1c20800/uart2_rts_cts phandle fdt set /soc/serial@1c28800 pinctrl-names "default" "default" fdt set /soc/serial@1c28800 pinctrl-0 "<${tmp_phandle1}>" fdt set /soc/serial@1c28800 pinctrl-1 "<${tmp_phandle2}>" env delete tmp_phandle1 tmp_phandle2 There are some error messages during boot: Applying kernel provided DT fixup script (sun50i-h5-fixup.scr) ## Executing script at 44000000 tmp_bank=A tmp_pin=21 libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND 10046717 bytes read in 505 ms (19 MiB/s) As a result, the RTS/CTS handshaking for UART2 is unfunctional. May be for UART1 and UART3 is the same? I think the reason is that there are no paths /soc/pinctrl@1c20800/uart2 and /soc/pinctrl@1c20800/uart2_rts_cts inside the device tree specified by sun50i-h5-nanopi-neo2-v1.1.dtb file. The right paths are /soc/pinctrl@1c20800/uart2-pins and /soc/pinctrl@1c20800/uart2-rts-cts-pins, I think. Am I right? I've tried easy modification of SCR script - handshaking is now functional, but CRC is bad. If I am right, what is the right way to correct this? Script change (how properly?), DTB change, DTBO creation, ...? Moreover, look at this reduced listing of /sys/firmware/devicetree/base/soc/pinctrl@1c20800: csi-pins emac-rgmii-pins i2c0-pins i2c1-pins i2c2-pins i2s0-pins i2s1-pins mmc0-pins mmc1-pins mmc2-8bit-pins spi0-pins spi1-pins uart0-pa-pins uart1-pins uart1-rts-cts-pins uart2-pins uart2_rts_cts uart2-rts-cts-pins uart3-pins uart3-rts-cts-pins w1_pins Why are somewhere dashes "-" and somewhere underscores "_" ? Thank you. Link to comment Share on other sites More sharing options...
Java475 Posted April 1, 2020 Author Share Posted April 1, 2020 Nobody knows what is the right way to correct this issue? Do I have to create my own DTBO? Thank you. Link to comment Share on other sites More sharing options...
martinayotte Posted April 1, 2020 Share Posted April 1, 2020 10 hours ago, Java475 said: Nobody knows what is the right way to correct this issue? Right ! Good catch ! I seems that dashes/underscores issue appeared when we switched from 4.20.y to 5.0.y and still unfixed in 5.5.y . I will try to fix that in the following days ... 10 hours ago, Java475 said: Do I have to create my own DTBO? In the meantime, Yes, you need to fix the overlay along the fixup script ... EDIT: During a second look, it seems that /proc/device-tree/__symbols__/ has underscores. So, maybe both are working. I will try to figure out ... EDIT2: Here is the commit : https://github.com/armbian/build/commit/281c8546954c7e6ec993c03632d701490464c36f Link to comment Share on other sites More sharing options...
Java475 Posted April 3, 2020 Author Share Posted April 3, 2020 After "git pull" and recompilation it works! Great, thank you. Link to comment Share on other sites More sharing options...
