linux baba Posted April 6, 2020 Posted April 6, 2020 Hello, I am getting following error when compilining https://github.com/superna9999/meson_gx_mali_450/tree/DX910-SW-99002-r9p0-01rel0_meson_gx KDIR=/usr/src/linux-source-4.19.57-meson64/ ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- ./build.sh make: Entering directory '/root/mali/meson_gx_mali_450/driver/src/devicedrv/mali' make ARCH=arm64 -C /usr/src/linux-source-4.19.57-meson64/ M=/root/mali/meson_gx_mali_450/driver/src/devicedrv/mali modules make[1]: Entering directory '/usr/src/linux-source-4.19.57-meson64' CC [M] /root/mali/meson_gx_mali_450/driver/src/devicedrv/mali/linux/mali_osk_atomics.o /bin/sh: 1: scripts/basic/fixdep: Exec format error scripts/Makefile.build:303: recipe for target '/root/mali/meson_gx_mali_450/driver/src/devicedrv/mali/linux/mali_osk_atomics.o' failed make[2]: *** [/root/mali/meson_gx_mali_450/driver/src/devicedrv/mali/linux/mali_osk_atomics.o] Error 2 make[2]: *** Deleting file '/root/mali/meson_gx_mali_450/driver/src/devicedrv/mali/linux/mali_osk_atomics.o' Makefile:1517: recipe for target '_module_/root/mali/meson_gx_mali_450/driver/src/devicedrv/mali' failed make[1]: *** [_module_/root/mali/meson_gx_mali_450/driver/src/devicedrv/mali] Error 2 make[1]: Leaving directory '/usr/src/linux-source-4.19.57-meson64' Makefile:191: recipe for target 'all' failed make: *** [all] Error 2 make: Leaving directory '/root/mali/meson_gx_mali_450/driver/src/devicedrv/mali' cp: cannot stat '/root/mali/meson_gx_mali_450/driver/src/devicedrv/mali//mali.ko': No such file or directory uname Linux lepotato 4.19.57-meson64 #5.90 SMP PREEMPT Sat Jul 6 15:54:33 CEST 2019 aarch64 GNU/Linux I am compiling it to enable GPU to be used with mpv.
ning Posted April 26, 2020 Posted April 26, 2020 1, armbian kernel may still has issue in build external modules. due to cross build. you can rebuild armbian kernel natively. 2, this driver should never be used. use mainline lima instead.
linux baba Posted May 25, 2020 Author Posted May 25, 2020 Thank you ning and sorry fo the late reply!
