Scandinav21 Posted April 9, 2020 Posted April 9, 2020 Armbianmonitor: http://ix.io/2hls Hi everyone. I almost gave up while reading tons of forums:( I bought CO2 sensor MH-Z19 from aliexpress. As I figured out this sensor used by RPi without any problems. Manual I found here: https://www.circuits.dk/testing-mh-z19-ndir-co2-sensor-module/ I connected module as mentioned: Vin - 2 pin gpio GND - 9 pin Tx - 13 pin Rx - 11 pin Module was blinking when I powered on my OPi, but when I tried to send data to UART nothing happened. I got timeout. I tried to connect Tx and Rx (11 and 13 pin) by cable, then sent bytes and immediatley got answer, UART work, as I understood. I checked uart in armbian-config menu and all (1,2,3) was enabled. Orange PI PC Plus Linux orangepipcplus 5.4.30-sunxi #20.02.9 SMP Mon Apr 6 19:46:24 CEST 2020 armv7l GNU/Linux Can somebody help me, please? Spoiler import serial import time import subprocess import getrpimodel serial_dev = '/dev/ttyS2' stop_getty = 'sudo systemctl stop serial-getty@ttyS0.service' start_getty = 'sudo systemctl start serial-getty@ttyS0.service' def mh_z19(): ser = serial.Serial(serial_dev, baudrate=9600, bytesize=serial.EIGHTBITS, parity=serial.PARITY_NONE, stopbits=serial.STOPBITS_ONE, timeout=1.0) while 1: s=ser.read(9) result=ser.write("\xff\x01\x86\x00\x00\x00\x00\x00\x79") s=ser.read(9) print(s) if len(s) >= 4 and s[0] == "\xff" and s[1] == "\x86": return {'co2': ord(s[2])*256 + ord(s[3])} break def read(): p = subprocess.call(stop_getty, stdout=subprocess.PIPE, shell=True) result = mh_z19() p = subprocess.call(start_getty, stdout=subprocess.PIPE, shell=True) if result is not None: return {'CO2': result["co2"]} if __name__ == '__main__': # value = mh_z19() # print "co2=", value["co2"] value = read() if value is not None: print "co2=", value["CO2"] else: print "None"
Scandinav21 Posted April 9, 2020 Author Posted April 9, 2020 Sorry, my fault, wrong gpio used. Apologise.
