Greetings,
  I haven't built a new image for awhile.  But, I wanted to refresh the process.  In the meanwhile, the only change I've made is upgrading my host.
  My build platform is a VM.   I have no idea if that matters, but it was a change.
I now have some weird errors/warning and I want to troubleshoot them.  How can I enter into the environment to run just the customize script and commands?
I'd like to dig into them, but not sure how.
Thanks!
  On 4/26/2020 at 5:35 PM, Igor said:
Show them.
Expand
I understand, but they are not specific to Armbian so I did not want to engage with the team with troubleshooting.
But, since I use BananaPi, I want t upgrade the firmware, So I use
/usr/local/bin/bpi-update -c bpi-pkg-bpi-wiringpi.conf
To install some software for GPIO.
I get this:
Unsupported setsockopt level=270 optname=3
sudo: Account or password is expired, reset your password and try again
sudo: no tty present and no askpass program specified
sudo: unable to change expired password: Authentication token manipulation error
Which is something inside the script.  But I can't troubleshoot what specifically until I can get into that environment.
Then when I try to run a configure script for some software I see a whole lot of this:
config.status: creating Makefile
qemu: Unsupported syscall: 382
config.status: creating include/Makefile
config.status: creating lib/Makefile
config.status: creating tools/Makefile
config.status: creating tests/Makefile
Expand
Why don't you build an image and debug on board?
Expand
It never happened on the board.  I built this using that method and after I upgraded my VM host these popped up.
It would be a whole lot faster to be able to "get into" the environment during the build and see what programs are causing these warnings/errors.
Expand
This is usually safe to ignore
Expand
While this you need to debug. It probably checks some hardware functions.
Expand
Agreed!  I previously debugged this and have written an image with it successfully.
It used to work fine.  Now it doesn't.  So if I can drop into the environment to debug it on the build platform, that would be great.
Is it possible to get into the build environment?
Well, I stuck a 'bash' in the customize script and I can get into the build env.
Turns out 'sudo' is a problem.
#sudo ls
Unknown host QEMU_IFLA type: 47
Unknown host QEMU_IFLA type: 48
Unknown host QEMU_IFLA type: 43
Changing password for root.
