punk45rock Posted May 23, 2015 Share Posted May 23, 2015 I was trying to plug my Arduino uno into my Udoo quad but it does not appear to be assigned to a serial port, which i believe should appear as ttyACM*. when searching the kernel github page i see these relults https://github.com/patrykk/linux-udoo/search?utf8=%E2%9C%93&q=ACM. Is it possible to get these devices supported in your next kernel release? Link to comment Share on other sites More sharing options...
Igor Posted May 24, 2015 Share Posted May 24, 2015 I hope adding this is enough?https://github.com/igorpecovnik/lib/commit/3fb1e9f94b0366f77366dc4bc310978395e6eee2 Try to re-compile kernel by yourself, I won't be rebuilding soon. Link to comment Share on other sites More sharing options...
remsnet Posted June 20, 2015 Share Posted June 20, 2015 that needs lib #66 as weell https://github.com/igorpecovnik/lib/issues/66 Link to comment Share on other sites More sharing options...
Igor Posted June 20, 2015 Share Posted June 20, 2015 Added that to, thanks Horst. https://github.com/igorpecovnik/lib/commit/282fac50d704a02621f04471cc46c69f2612dc10 Link to comment Share on other sites More sharing options...
Eystorhaf Posted November 5, 2015 Share Posted November 5, 2015 Hey guys, facing a similar problem. I'm trying to configure the TI CC2531 dongle with the TI Z-Stack Linux Gateway to manage a Zigbee network. I have different boards running armbian: - lamobo-r1, armbian jessie with mainline kernel - cubietruck, armbian jessie with mainline kernel If I plug den CC2531 dongle into the lamobo-r1 it is recognized and created as /dev/ttyACM0, ls -ld /dev/ttyA* : crw-rw---- 1 root dialout 166, 0 /dev/ttyACM0 I can connect to it and configure it. On my preferred board the cubietruck, it wont work as intended: -rw-rw---- 1 root /dev/ttyACM0 The missing c* already indicates that I wont be able to talk to the device via uart, thus also the Z-Stack communication failed. But if I try running the legacy kernel on the cubietruck it works like a charm. I also tested an Arduino out of curiosity,this some how works on the vanilla and the legacy kernel. Might a recompile of the kernel help e.g. identifying a missing module or might this be related to an incompatibility of the vanilla kernel with the cubietruck hardware? Best Regards, Eyst Link to comment Share on other sites More sharing options...
