spinarr Posted May 19, 2020 Posted May 19, 2020 Hello, this may be related to: https://forum.armbian.com/topic/8819-where-to-report-a-bug-etcinitdarmhwinfo-corrupts-bootarmbianenvtxt-when-followed-by-powerfailure/ https://github.com/armbian/config/issues/33 cat /boot/armbianEnv.txt /var/log.hdd/alternatives.log { monthly rotate 12 compress delaycompress missingok notifempty create 644 root root }usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Would there be any advice so that we can prevent this from happening? Many thanks for any pointer. Regards Rostislav
richardk Posted May 20, 2020 Posted May 20, 2020 I had tried setting armbianEnv.txt mode 0444, but that failed. The corrupted armbianEnv.txt file still had mode 0444. I am now trying modified /usr/lib/armbian/armbian-hardware-optimization and armbian-firstrun scripts, with lines that modify armbianEnv.txt commented-out. So far so good.
