guidol Posted June 1, 2020 Posted June 1, 2020 If you know the movie "Wargames" then you may know the computer of "David Lightman" a IMSAI 8080 Udo Munk did create the software z80pack (last version from 2017 v1.36 at https://www.autometer.de/unix4fun/z80pack/ ) which does include - IMSAI 8080 - Altair - Cromemco Z1 and - cpmsim Emulation. Against the text based cpmsim emulation the other features a graphical frontpanel with "blinken lights" Yesterday I did try to compile/start my favourite IMSAI 8080. I did follow the instructions - which I collect and wrote for me - see attached to this message. But yesterdy I only got limited success (after many "bad" compiles with missing dependencies) in starting the IMSAI 8080 emulation. I did get the graphical frontend *yeah* - but after POWERON/RUN the computer I didnt get any terminal-output After MANY retries I did give up Today I did the same compile-session on a PC with Ubuntu MATE 20.04LTS and it did work in the first try At first I got no idea what wasnt working....but then I discovered that - when moving the graphical frontpanel - the terminal-output was written VERY SLOWLY to the terminal-screen *Aha* Because the garphical frontpanel seem to work perfectly (and did also compile very well) I searched inside the directorys of imsaisim and found in the "conf"-directory the file system.conf There in system.conf is a line where the FPS-rate of the frontpanel as default is configured to 60 FPS (Frames per second). While taking a look at htop the NanoPi A64 (where my armbian buster Desktop does run) the cpu-utilization is near 90% So my gut instinct did tell me thats to much and the NanoPi has to much work with the frontpanel than writing to the terminal. I changed the framerate in - for the IMSAI 8080: ~/z80pack-1.36/imsaisim/conf/systemconf - for the Altair: ~/z80pack-1.36/altairsim/conf/systemconf - for the Cromemco Z1: ~/z80pack-1.36/cromemcosim/conf/systemconf to # front panel framerate fp_fps 10 After that change all 3 emulators with graphical frontend did startup and give output on the terminal I contacted Udo Munk via email about this topic and he already knew it He wrote that he had implemented the FPS option, because some lower-spec systems had problems to achieve the power for producing a framerate of 60 FPS for the frontpanel. Here my write-up / documentation how I did compile / successfully start the IMSAI 8080 emulation: (many thanks to John Kennedy from the FB-Group Altair 8800 for double-checking my instructions!) ====================================================================== My normal evironment for compiling source: ====================================================================== apt install gcc libncurses5-dev liblua5.3-dev git make zip unzip -y ====================================================================== Getting z80pack-source: ====================================================================== cd ~ wget https://www.autometer.de/unix4fun/z80pack/ftp/z80pack-1.36.tgz tar -xvf z80pack-1.36.tgz cd ~/z80pack-1.36/ ====================================================================== Dependencies named by z80pack: ====================================================================== libjpeg X11 OpenGL c++ compiler (g++) libpthread ====================================================================== Packages for the z80pack-dpendencies: ------------------------------------- apt install libjpeg-dev x11-common libpthread-stubs0-dev libxmu-dev apt install mesa-common-dev z80asm libglu1-mesa-dev freeglut3-dev ====================================================================== ==> <== ==> I built all packages of z80pack in the following order: <== ==> <== ==> ATTENTION: for some commands you may have to use sudo <== ====================================================================== 1.) FRONTPANEL ====================================================================== cd ~/z80pack-1.36/frontpanel/ make -f Makefile.linux NOTE: Be sure to copy libfrontpanel.so to a shared library path! NOTE: cp ~/z80pack-1.36/frontpanel/libfrontpanel.so /usr/lib make -f Makefile.linux clean ====================================================================== 2.) CPMSIM ====================================================================== cd ~/z80pack-1.36/cpmsim/srcsim/ make -f Makefile.linux make -f Makefile.linux clean ====================================================================== 3.) CPMSIM-TOOLS ====================================================================== if you are user root: mkdir /root/bin if you are user pi: mkdir /home/pi/bin cd ~/z80pack-1.36/cpmsim/srctools make make install NOTE: (does install in /root/bin/) NOTE: Tools installed in /root/bin, make sure it is NOTE: included in the systems search PATH NOTE: export PATH=$PATH:/root/bin NOTE: or NOTE: export PATH=$PATH:/home/pi/bin make clean ====================================================================== 4.) ALTAIRSIM ====================================================================== cd ~/z80pack-1.36/altairsim/srcsim/ make -f Makefile.linux make -f Makefile.linux clean NOTE: change framerate to "fp_fps 10" in NOTE: ~/z80pack-1.36/altairsim/conf/system.conf ====================================================================== 5.) CROMEMCOSIM ====================================================================== cd ~/z80pack-1.36/cromemcosim/srcsim/ make -f Makefile.linux make -f Makefile.linux clean NOTE: change framerate to "fp_fps 10" in NOTE: ~/z80pack-1.36/cromemcosim/conf/system.conf ====================================================================== 6.) IMSAISIM ====================================================================== cd ~/z80pack-1.36/imsaisim/srcsim/ make -f Makefile.linux make -f Makefile.linux clean NOTE: change framerate to "fp_fps 10" in NOTE: ~/z80pack-1.36/imsaisim/conf/system.conf ====================================================================== PREPARE 1st start of imsaisim; ====================================================================== cp ~/z80pack-1.36/frontpanel/libfrontpanel.so /usr/lib cd ~/z80pack-1.36/imsaisim rm conf ln -s conf_2d conf export PATH=$PATH:/root/bin NOTE: maybe add the export-command to your ~/.bashrc ====================================================================== START of IMSAI 8080 CPM v2.2 from the x-terminal on the desktop (needs to be a "x-terminal) for connecting to the X-Server for creating the graphical frontpanel: ====================================================================== ./cpm22 NOTE: maybe root has to give access-rights: NOTE: chmod -R 666 ~/z80pack-1.36/imsaisim/disks NOTE: on the x-terminal root and the to the desktop logged in user can NOTE :start the application and connect to the X-server on a NOTE: SSH-terminal ONLY the to the desktop logged in user can start the NOTE: application and connect to the X-server to give root access to NOTE: the X-server from a SSH-terminal the he to the desktop logged NOTE: in user has to give root access via the xhost command: NOTE: xhost SI:localuser:root ====================================================================== POWER-UP the IMSAI 8080 in the graphical frontpanel ====================================================================== Press "POWER ON " upper part on the first switch on the right side (POWER ON / POWER OFF) Press "RUN" upper part of the third (red) switch (RUN/STOP) ====================================================================== Exit the IMSAI 8080 ====================================================================== Enter "bye" on the CP/M-commandline OR press "POWER OFF " lower part on the first switch on the right side (POWER ON / POWER OFF) OR close the graphical frontpanel with the close button X (Window-Manager-close) Pictures (screenshots are done with Mirage as you can see) of my "success" 2
guidol Posted June 2, 2020 Author Posted June 2, 2020 Here an additional write-up for using/starting imsaisim not only from the x-term, but also from a text-based SSH-console where you may have to give some additional access-right for accessing the x-server where the graphical frontpanel should be displayed: using/starting imsaisim - from the graphical x-terminal - from the via SSH connected text.based terminal ====================================================================== from the graphical x-terminal: ====================================================================== imsaisim could be started from the graphical x-terminal with the user guido (here in my example) because Iam logged in with the user guido and on this x-terminal also with the user root with the following commands: cd ~/z80pack-1.36/imsaisim ./cpm22 This will work because the variable DISPLAY is already set to :.0,0 NOTE: echo $DISPLAY NOTE: :0.0 Normally the user guido (when logged in to the Desktop) has to allow root to use the - under the user guido started - x-server. ====================================================================== from the via SSH connected text.based terminal: ====================================================================== As default only user guido is allowed to use the x-server (because he is logged in the desktop): NOTE: when root it logged into the desktop-environment only root has NOTE: access to the x-server NOTE: because when logged in via SSH the variable DISPLAY isnt set guido@npi-a64$ export DISPLAY=:0.0 guido@npi-a64$ xhost ==> access control enabled, only authorized clients can connect ==> SI:localuser:guido ----------------------------------------------------------------------- user guido can ALLOW/ADD root the access to the x-server with the following command ----------------------------------------------------------------------- guido@npi-a64$ xhost SI:localuser:root ==> localuser:root being added to access control list ----------------------------------------------------------------------- or user guido can DISALLOW/REMOVE root the access to the x-server with the following command ----------------------------------------------------------------------- guido@npi-a64$ xhost -SI:localuser:root ==> localuser:root being removed from access control list ----------------------------------------------------------------------- to REVIEW the actual state just give the following command: ----------------------------------------------------------------------- guido@npi-a64$ export DISPLAY=:0.0 guido@npi-a64$ xhost ==> access control enabled, only authorized clients can connect ==> SI:localuser:root ==> SI:localuser:guido NOTE: setting this via xhost is a TEMPORARY setting Now after allowing/setting the access rights the user guido and the user root can access the x-server. Now when giving the commands cd ~/z80pack-1.36/imsaisim ./cpm22 ----------------------------------------------------------------------- ##### ### ##### ### ##### ### # # # # # # # # # # # # # ## ## # # # # # # # # # # # # # # ##### # # ##### # # ##### ##### # # # # # # # # # # # # # # # # # # # # # # # # # # # # # ##### ### ##### ### ##### ### # # Release 1.36, Copyright (C) 1987-2017 by Udo Munk IMSAI 8080 Simulation Release 1.17, Copyright (C) 2008-2017 by Udo Munk CPU speed is 2 MHz RAM size is 54 KB Loader statistics for file bootrom.hex: START : d800H END : df7fH LOADED: 0780H (1920) FrontPanel Simulator v2.1 Copyright (C) 2007-2015 by John Kichury ----------------------------------------------------------------------- NOTE: the graphical frontpanel will start at the desktop-screen, NOTE: BUT the normal terminal-output would be displayed at the NOTE: text-based SSH-console from where you logged in to the computer NOTE: who is holding the imsaisim-directory - which will give you much NOTE: more space for the frontpanel and the text-based terminal also NOTE: has more space at the SSH-console - maybe for a bigger font ;)
guidol Posted June 8, 2020 Author Posted June 8, 2020 armbian focal bad and armbian buster good for compiling/using z80pack v1.36? While trying to reproduce the compilation-process I did observe a problem AFTER all packages were compiled: On my armbian-systems with armbian ubuntu focal and dev-kernel 5.6.15 I could start ./cpm22 from imsaisim and do get the graphical frontpanel BUT when I do switch on the IMSAI with the frontpanel I do get a segmentation fault This did happen on a NanoPi K1 Plus and a Orange Pi PC2 where the armbian focal dev-image was/is installed Welcome to Armbian Focal with Linux 5.6.15-sunxi64 package bsp-kernel[20.05.2] u-boot[20.05.2] dtb [20.05.2] firmware [20.05.2] config[20.05.2] branch[dev] Linux npi-k1-plus 5.6.15-sunxi64 #20.05.2 SMP Tue Jun 2 17:33:03 CEST 2020 aarch64 aarch64 aarch64 GNU/Linux Because my NanoPi A64 with armbian buster and dev-kernel 5.6.13-sunxi64 didnt got the problem I did compile a armbian buster with dev-kernel for my Orange Pi PC2 which did show the segmentation fault while using armbian focal. After finishing the image-compile I ended up with Welcome to Armbian buster with Linux 5.6.16-sunxi64 package bsp-kernel[20.08.0-trunk] u-boot[20.08.0-trunk] dtb [20.08.0-trunk] firmware [20.08.0-trunk] config[20.08.0-trunk] branch[dev] Linux opi-pc2 5.6.16-sunxi64 #trunk SMP Mon Jun 8 17:23:54 +03 2020 aarch64 GNU/Linux After that I did go through the z80pack-compile-process and happily after pushing the Power-Button on the frontpanel I didnt get the segmentation fault from the terminal and the emulation is useable without problems!
