This overlays settings worked well until I have compiled my own .dtbo file and call it with overlay=..xyz... , after that all yet working overlays stopped working, even if I removed them. The boot process now skips this overlay settings.
After examination, I have found file "/boot/boot.scr" and "/boot/dtb-5.4.44-rockchip64/rockchip/overlay/rockchip-fixup.scr" had some garbage characters at beginning. I didn't change anything, neither I did open them before, those files simply got garbage.
After deleting the garbage chars, it won't boot anymore. Before I had tried also spi-spidev and spi-nor
Expand
You should not having touched the "garbage" chars, they are binary header of compiled script.
To revert it as before, use this command :
mkimage -C none -A arm -T script -d rockchip-fixup.scr-without-garbage-chars rockchip-fixup.scr
Also, looking at your first screenshot of /boot/armbianEnv.txt, the "overlay_prefix=rockchip" should be on a single line, not the same line as "verbosity=1" ...
Thank you @martinayotte, you saved me days of pain. The problem was that single line, while editing in putty terminal window, the numeric keypad doesn't work properly, so I have messed the file by myself.
I find difficult to debug my .dtbo file, something is not accepted and it is reverted back, so overlays do work now just until I add my .dtbo. Does this verbosity setting may help to adjust the debug level while booting? I can't see any debug text of the overlay sequence, so I don't know where exactly goes wrong.
Expand
DTBO loaded by U-Boot is always difficult to debug. Maybe you leave it out from U-Boot and try to load it dynamically using /sys/kernel/config/device-tree/overlays/ ?
mkdir /sys/kernel/config/device-tree/overlays/myoverlay
cat myoverlay.dtbo > /sys/kernel/config/device-tree/overlays/myoverlay/dtbo
Then check any errors in "dmesg" ...
Expand
"verbosity=7" would help, but only for kernel errors, not U-Boot errors ...
