I generated SD images for A20-OLinuXino-Lime2-eMMC boards.
Kernel is 4.6.2, Debian wheezy, u-boot 2016.05
On my last two images (generated with slight differences in u-boot configuration), the first time I booted, everything worked fine.
After that, I installed a booting system on the eMMC of the card.
After few boots, (on the same board) the first SD card hanged  (several minutes) just after displaying:
random: nonblocking pool is initialized
The other card continued to work (booting did not hang).
A few hours later, I copied several files into a /data directory (.deb files).
Trying to boot that second card, it ran in the same blocked status: "random: nonblocking pool is initialized".
The first card: same thing.
I already waited for an hour once without success.
Booting from eMMC does does not hang
Any clue on what could avoid this problem ? And what causes it ?
Thank you,
I think I found why it did not work: without Ethernet cable connected, the boot process hangs. With the Ethernet cable connected, it works.
So I think that the random pool was not enough random without the cable connection.
So good news: my SD card is fine ! :)
Thank you,
Good job :) and thanks as you give a clue to another thread.
I still have the same problem on some SD cards (even with network connected).
Here is another lead I have not time yet to follow:
http://blog.jamesrhall.com/2014/04/ubuntu-server-1404-fun.html
Apparently, the kernel switches to a video mode that is not seen through serial link. So adding nomodeset could avoid this blocking.
I am interested in the link of the other thread you talked about :)
