Hi, Just as my last post. I want to know if it is possible to  wakeup opi3 after I switch its state to "mem" or "disk" using gpio on CON12.
I have doing some reasch but I don't know if it is right: PL/PM port can be used as wakeup source. PF/G/H/L/M port support interrupt event. PC/D didn't support interrupt.
But when I try to write a device tree file, but it just report some error with error code -22.
My device three is like this:
/dts-v1/;
/plugin/;
	compatible = "allwinner,sun50i-h6";
	 * This fragment is needed only for the internal pull-up activation,
	 * external pull-up resistor is highly recommended if using long wires
	fragment@0 {
		target = <&r_pio>;
		__overlay__ {
			gpio_key_wakeup: gpio_key_wakeup {
				pins = "PL8";
				function = "gpio_in";
				bias-pull-up;
	fragment@1 {
		target-path = "/";
		__overlay__ {
			gpio-keys-user {
				 * Use "gpio-keys" for EINT capable pins, "gpio-keys-polled" for other pins
				 * add "poll-interval" property if using "gpio-keys-polled"
				compatible = "gpio-keys";
           autorepeat;
				pinctrl-names = "default";
				pinctrl-0 = <&gpio_key_wakeup>;
				key_wakeup{
					label = "GPIO KEY_WAKEUP";
					linux,code = <143>; /* KEY_WAKEUP, see include/uapi/linux/input-event-codes.h */
					gpios = <&r_pio 0 8 1>; /* PL8 GPIO_ACTIVE_LOW */
   I am still a newbie and I don't know  enough thing about how to write the right DTS file. Please give me some help. Thanks
(I have tested KEY_POWER it seems everything OK. I don't know what is the error part about KEY_WAKEUP)
Finally, I fulfill it now.
dts is like this:
one pin for sleep:
/dts-v1/;
/plugin/;
	fragment@0 {
		target = <&pio>;
		__overlay__ {
			gpio_but_sleep: gpio_but_sleep {
				pins = "PH3";
				bias-pull-up;
	fragment@1 {
		target-path = "/";
		__overlay__ {
			gpio-keys-user {
				autorepeat;
				pinctrl-0 = <&gpio_but_sleep>;
				sleep_button {
					label = "KEY_SLEEP";
					linux,code = <142>; /* KEY_SLEEP, see include/uapi/linux/input-event-codes.h */
					linux,input-type = <1>;     // EV_KEY
					gpios = <&pio 7 3 1>; /* PD15 GPIO_ACTIVE_LOW */
					gpio-key;
one pin for wakeup:
/dts-v1/;
/plugin/;
	compatible = "allwinner,sun8i-h3";
	fragment@0 {
		target = <&pio>;
		__overlay__ {
			poweroff_pins:poweroff_pins {
        		allwinner,pins = "PA13";
        		allwinner,function = "gpio_out";
	fragment@1 {
		target-path = "/";
        	__overlay__ {
            		poweroff: poweroff {
                	compatible = "gpio-poweroff";
                	gpios = <&pio 0 13 1>;
But some weird things happend: after I wakeup again. I can connect to opi3 via debug port(uart0). But can not connect it from ssh again. Even after I setup a new  static ip for it.
And when I test "who", I find it still connect with the old ssh. But when I try to ping gatway "ping 192.168.1.1":
it show: From 192.168.1.108 icmp_seq=1 Destination Host Unreachable
 It is so wried.
Edited by John Henry
Hi John Henry,
did you manage to solve the ssh connection issue?
im trying to create a dts file to suspend and wake my nanopi neo, i found this thread that talks about using GPIO to inform of system shutdown :
GPIO inform of shutdown
but it has the same code you have used for "wakeup"..?
just curious if you can confirm that your "wakeup" code does indeed wake up the device from sleep/suspend?
Thank you
