gounthar Posted July 7, 2020 Posted July 7, 2020 Hi, I had already compiled ffmpeg on a 32bits OS for my Orange Pi RK3399 when it ran the Orange Pi 32 bits Ubuntu without too much trouble, but now that I have Armbian on my 4B, I'd like to compile ffmpeg too. The issue I have is that gcc is started with bad options (I'm not sure of that, that's what I think I understood): mktemp -u XXXXXX ZgAQ9I test_ld cc test_cc BEGIN /tmp/ffconf.efsAigGe/test.c 1 int main(void){ return 0; } END /tmp/ffconf.efsAigGe/test.c gcc -mfpu=neon -c -o /tmp/ffconf.efsAigGe/test.o /tmp/ffconf.efsAigGe/test.c gcc: error: unrecognized command line option '-mfpu=neon' C compiler test failed. poddingue@orangepi4-armbian:~/ffmpeg_sources/FFMpeg-orig$ ./configure If gcc is a cross-compiler, use the --enable-cross-compile option. Only do this if you know what cross compiling means. C compiler test failed. If you think configure made a mistake, make sure you are using the latest version from Git. If the latest version fails, report the problem to the ffmpeg-user@ffmpeg.org mailing list or IRC #ffmpeg on irc.freenode.net. Include the log file "ffbuild/config.log" produced by configure as this will help solve the problem. gcc is unable to create an executable file. If gcc is a cross-compiler, use the --enable-cross-compile option. Only do this if you know what cross compiling means. C compiler test failed. My gcc version is : gcc -v Using built-in specs. COLLECT_GCC=gcc COLLECT_LTO_WRAPPER=/usr/lib/gcc/aarch64-linux-gnu/8/lto-wrapper Target: aarch64-linux-gnu Configured with: ../src/configure -v --with-pkgversion='Debian 8.3.0-6' --with-bugurl=file:///usr/share/doc/gcc-8/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-8 --program-prefix=aarch64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --disable-libphobos --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-checking=release --build=aarch64-linux-gnu --host=aarch64-linux-gnu --target=aarch64-linux-gnu Thread model: posix gcc version 8.3.0 (Debian 8.3.0-6) My machine is running Armbian buster with Linux 5.4.49-rockchip64Debian 10 buster with Kernel: aarch64 Linux 5.4.49-rockchip64. Is there anything I could do with configure so that it uses the right options? I have compiled tons of other sources on that machine, but ffmpeg and x264 really don't like it. Thanks.
Technicavolous Posted July 8, 2020 Posted July 8, 2020 On 7/7/2020 at 3:32 PM, gounthar said: gcc: error: unrecognized command line option '-mfpu=neon' Expand I am absolutely unqualified to give an answer here but out of curiosity I searched the error and found you may not have to specify an option to use neon? https://stackoverflow.com/questions/29851128/gcc-arm64-aarch64-unrecognized-command-line-option-mfpu-neon 1
gounthar Posted July 8, 2020 Author Posted July 8, 2020 I finally had to export CFLAGS= to get the configure script to work.
