Hello, (i opened a new thread because the other one had another topic...)
At the moment im stuck in updating my linux image...
When i run apt-get install linux-image-current-rockchip64
Then i get:
The following packages will be upgraded:
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 38.2 MB of archives.
After this operation, 97.2 MB of additional disk space will be used.
Get:1 https://apt.armbian.com buster/main arm64 linux-image-current-rockchip64 arm64 20.05.7 [38.2 MB]
Fetched 38.2 MB in 3s (14.4 MB/s)
(Reading database ... 128592 files and directories currently installed.)
Preparing to unpack .../linux-image-current-rockchip64_20.05.7_arm64.deb ...
Unpacking linux-image-current-rockchip64 (20.05.7) over (20.02.11) ...
Kernel configuration : earlyprintk console=ttyFIQ0,1500000n8 rw init=/sbin/init rootfstype=ext4 rootwait root=PARTUUID=B921B045-1DF0-41C3-AF44-4C6F280D3F
Creating new extlinux.conf...
cp: cannot stat '/usr/lib/linux-image-5.4.49-rockchip64': No such file or directory
run-parts: /etc/kernel/postrm.d/zz-update-extlinux exited with return code 1
dpkg: warning: old linux-image-current-rockchip64 package post-removal script subprocess returned error exit status 1
dpkg: trying script from the new package instead ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-current-rockchip64_20.05.7_arm64.deb (--unpack):
 new linux-image-current-rockchip64 package post-removal script subprocess returned error exit status 1
Installing new extlinux.conf...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Does someone have a solution for this? I can also do a full reinstall as i have an image of my eMMC but this might be more work
very odd.. shouldn't be any extlinux hooks
please provide log url from
armbianmonitor -u
Hmm something seems really amiss with your install.. Even the logs seemed to be missing things.... IMHO re-installing is new image download is probably best.
