Hi everybody,
I have a problem with this version: Armbian_20.05.2_Rockpro64_buster_legacy_4.4.213.img
I don't see my disk that is plugged on the PCIe To SATA Marvell 88SE9230 in the system.
I've create the file /etc/udev/rules.d/99-marvell.rules with the following line on it:
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x1b4b", ATTR{device}=="0x9230", RUN+="/bin/bash -c 'echo %k > /sys/bus/pci/drivers/ahci/bind'"
If I do the same thing with this version: Armbian_20.05.4_Rockpro64_focal_current_5.4.46.img, I see my disk after creating the file.
But, there's two problem with this version: first the fan always running and, more important, second I can't install OpenMediaVault on it.
My question is, do I have to do something on the kernel? If so, could someone tell me what I have to activate to see my disk ?
I don't have a lot of knowledge about kernels but I'm ready to jump it if someone could tell me where to check.
Thank you all in advance.
Myself has a bunch of Marvell chipset sata cards. And almost sure all of them work on kernel 5.7.12 - Try it out and let me know.
I did notice months back probs in OMV with that type of cards. I run kernel 5.7.12 with simpnas and works like charm.
it doesn't work even on a newest kernel:
user@rockpro64:~$ uname -r
6.6.16-current-rockchip64
user@rockpro64:~$ sudo cat /etc/armbian-release |egrep -i "version|branch|board"
BOARD=rockpro64
BOARD_NAME="RockPro 64"
BOARDFAMILY=rockchip64
BOARD_TYPE=conf
VERSION=24.2.1
BRANCH=current
user@rockpro64:~$ sudo lspci -v -s 01:00.0
01:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9230 PCIe 2.0 x2 4-port SATA 6 Gb/s RAID Controller (rev 11) (prog-if 01 [AHCI 1.0])
    Subsystem: Marvell Technology Group Ltd. 88SE9230 PCIe 2.0 x2 4-port SATA 6 Gb/s RAID Controller
    Flags: fast devsel, IRQ 59
    Memory at fa040000 (32-bit, non-prefetchable) [size=2K]
    Expansion ROM at fa000000 [size=256K]
    Capabilities: [40] Power Management version 3
    Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit-
    Capabilities: [70] Express Legacy Endpoint, MSI 00
    Capabilities: [e0] SATA HBA v0.0
    Capabilities: [100] Advanced Error Reporting
After initiating it appeared with the disks connected:
user@rockpro64:~$ echo "0000:01:00.0" | sudo tee /sys/bus/pci/drivers/ahci/bind
0000:01:00.0
    Flags: bus master, fast devsel, latency 0, IRQ 95
    Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit-
    Kernel driver in use: ahci
Thus the workaround with udev rules still needs to be applied.
https://forum.pine64.org/showthread.php?tid=7453 was helpful
Edited by AndrewCo
