Seasalt Posted June 24, 2016 Posted June 24, 2016 I have searched the forum and the internet and am having a lot of trouble finding a guide on how to covert the OTG on my OrangePi One to a USB port. (I am assuming it is possible to do.) I believe the current configuration for the OrangePi One is one usb and a OTG. I would also Like to be able to use the OTG as a USB port when I run OpenElec as I would like the second USB to plug in the new Optional Bluetooth dongle. Seasalt
rodolfo Posted June 24, 2016 Posted June 24, 2016 So far USB OTG port has been defined in host mode, the same as the regular USB port. To change this behaviour and use it in gadget (device) mode see http://forum.armbian.com/index.php/topic/1417-testers-wanted-g-ether-driver-h3-device-as-ethernet-dongle/ 1
Seasalt Posted June 24, 2016 Author Posted June 24, 2016 So far USB OTG port has been defined in host mode, the same as the regular USB port. To change this behaviour and use it in gadget (device) mode see http://forum.armbian.com/index.php/topic/1417-testers-wanted-g-ether-driver-h3-device-as-ethernet-dongle/ After reading the link I went back to my Orange Pi One and inserted the OTG cable and then the wireless mouse adapter it did not work. BUT when I did a reboot it worked perfectly. The same thing happened in Openelec. Thanks for your help.
