did anyone succeed in installing realtek wifi usb driver?
Do I need to install drivers? wlan0 is not recognized at all
sudo ifconfig wlan0 up
wlan0: ERROR while getting interface flags: No such device
/etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
auto wlan0
iface wlan0 inet dhcp
    wpa-psk 5b2c993635440b195b2635ee344e1c5fdf9b19ce64d338a9153146816dcfd9f8
    wpa-ssid segoly
    wireless-channel auto
You do not provide a lot of information. Guessing is hard.
with lsusb you can see what is your device. please show this.
with lsmod you can see what modules are loaded. please show this also.
what is in your /etc/modules-load.d/modules.conf ?
thanks, gnasch
here it is
cat /etc/modules-load.d/modules.conf
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
#gpio_sunxi
#w1-sunxi
#w1-gpio
#w1-therm
#gc2035
8192cu
lsmod
Module                  Size  Used by
mali_drm                2732  1
drm                   178255  2 mali_drm
mali                  123208  0
ump                    29379  3 mali
8188eu                908230  0
8192cu                624560  0
Well I see a difference to my working config.
I do not have 8188eu loaded, just 8192cu. But these are present too:
rtlwifi                45784  0
rtl8192c_common        33420  0
mac80211              358429  2 rtlwifi,rtl8192c_common
8192cu                627893  0
they get loaded automatically when 8192cu is loaded,
This is my lsusb with the dongle outwardly looking the same as yours. Please verify the USB ID and report back
root@poisson:~# lsusb
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 05e3:0606 Genesys Logic, Inc. USB 2.0 Hub / D-Link DUB-H4 USB 2.0 Hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@poisson:~#
This is an orange pi pc. What is your board?
I have done proper driver compilation
http://askubuntu.com/questions/246236/compile-and-install-rtl8192cu-driver
My lsmod
8188eu                908230  0
mali_drm                2732  1
mali                  123208  0
ump                    29379  3 mali
8192cu                626997  0
I have three different usb devices
Only one works the other give error message
I could not find any clue in log files
lsusb
the one that works
Bus 002 Device 007: ID 0bda:8179 Realtek Semiconductor Corp.
The two that does not work
Bus 002 Device 009: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 002 Device 008: ID 0bda:8179 Realtek Semiconductor Corp.
The 0bda:8176 one seems identical to mine. Please try fresh unaltered armbian image for orangepi one. No need to compile module, as this is already included.
The 0bda:8179 one I know nothing about.
Why is 8188eu loaded?
a step forward new issues
1. I installed from scratch newest image
2. 8188eu was there already
3. Inserted my wifi adapter and could start wlan0, no error
4. I tried using same package I use on Raspberry python wifi
5. Installed OK
6. Scanned OK
7. Added SSID OK
8. Tried to connect, display filled with some output and machine freezes
9. Restarted. /etc/network/interface is corrupted
10. Python Wifi package is not available any more (removed?)
OK, fine, wonderful !!!! Why invent further problems when there are none whatsoever ?
