Marconi Posted September 7, 2020 Posted September 7, 2020 Hi, I have this box, R329Q_V8.0 RK3228A and when you turn on the word ANDROID and the following the 7 lines: E:failed to mount /cache (Invalid argument) E:failed to mount /cache (Invalid argument) E:failed to mount /metadata (Invalid argument) E:failed to mount /metadata (Invalid argument) Supported API: 3 E:failed to mount /cache (Invalid argument) E:Can ́t mount /cache/recovery/last_locale I've tried to upgrade with several ROM's but to no avail. Any ideas? Running rkDumper appears the message : Partition "system" (0x006000000) Filesystem file size is not equal partition size. Marconi
xwiggen Posted September 9, 2020 Posted September 9, 2020 On 9/7/2020 at 3:18 PM, Marconi said: Hi, I have this box, R329Q_V8.0 RK3228A and when you turn on the word ANDROID and the following the 7 lines: E:failed to mount /cache (Invalid argument) E:failed to mount /cache (Invalid argument) E:failed to mount /metadata (Invalid argument) E:failed to mount /metadata (Invalid argument) Supported API: 3 E:failed to mount /cache (Invalid argument) E:Can ́t mount /cache/recovery/last_locale I've tried to upgrade with several ROM's but to no avail. Any ideas? Running rkDumper appears the message : Partition "system" (0x006000000) Filesystem file size is not equal partition size. Marconi you can use multitool to reflash
Marconi Posted September 10, 2020 Author Posted September 10, 2020 Jock just a doubt. i downloaded the multitool file on my pc. how do I load on SD? is there any application to burn on SD or is it just a copy ?
jock Posted September 10, 2020 Posted September 10, 2020 7 hours ago, Marconi said: Jock just a doubt. i downloaded the multitool file on my pc. how do I load on SD? is there any application to burn on SD or is it just a copy ? First decompress it into a folder of your choice with any compression tool (gzip on linux, winrar on windows) Then you can use an image writer like balenaEtcher to write the multitool image on the sdcard. Once there, you should be able to access the MULTITOOL disk and put the firmware image for your box (or an armbian/libreelec image ) in the images folder of the sdcard. At last, plug the sdcard in the box and give power. More instructions are in the first post of the thread linked above by @xwiggen
Marconi Posted September 11, 2020 Author Posted September 11, 2020 Congratulations Jock and Xwiggen. I'm Brazilian and I thought it would be complicated the solution, but with the help of you everything was easier. Thank you very much and see you next time. bye.
