Rock Pi 4c: no 3.5 jack audio on Armbian focal
Armbianmonitor:
My system has:
$uname -a
Linux rkpi 5.8.11-rockchip64 #20.08.4 SMP PREEMPT Wed Sep 23 17:51:13 CEST 2020 aarch64 aarch64 aarch64 GNU/Linux
Sound stack seems to be loaded, but alsa/pulseaudio sees only hdmi-output device (aplay log below). How to enable analog ouput on 3.5 mm jack?
$sudo aplay -lL
default
    Playback/recording through the PulseAudio sound server
null
    Discard all samples (playback) or generate zero samples (capture)
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pulse
    PulseAudio Sound Server
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
sysdefault:CARD=hdmisound
    hdmi-sound, ff8a0000.i2s-i2s-hifi i2s-hifi-0
    Default Audio Device
dmix:CARD=hdmisound,DEV=0
    Direct sample mixing device
dsnoop:CARD=hdmisound,DEV=0
    Direct sample snooping device
hw:CARD=hdmisound,DEV=0
    Direct hardware device without any conversions
plughw:CARD=hdmisound,DEV=0
    Hardware device with all software conversions
usbstream:CARD=hdmisound
    hdmi-sound
    USB Stream Output
**** List of PLAYBACK Hardware Devices ****
card 0: hdmisound [hdmi-sound], device 0: ff8a0000.i2s-i2s-hifi i2s-hifi-0 [ff8a0000.i2s-i2s-hifi i2s-hifi-0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
Hi
I have the same problem @
Linux rockpi-4c 5.8.13-rockchip64 #20.08.8 SMP PREEMPT Mon Oct 5 15:59:02 CEST 2020 aarch64 aarch64 aarch64 GNU/Linux
NAME="Ubuntu"
VERSION="18.04.5 LTS (Bionic Beaver)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Armbian 20.08.9 Bionic"
VERSION_ID="18.04"
  Subdevices: 1/1
My experience shows that the original Radxa kernel 4.4.153 shows audio devices and the Alsamixer offers many options.
It would be very nice if the same behavior occurs in the armbian (without the old legacy kernel).
It is fixed in master as of https://github.com/armbian/build/commit/1c29779e573956461b985c03cd293f5cf6ae1609
It will be part of v20.11 release.
If you want it sooner... Put the following content into fix-es8316.dts file.
/dts-v1/;
/plugin/;
        compatible = "rockchip,rk3399";
        fragment@0 {
                target = <&i2s0_8ch_bus>;
                __overlay__ {
                        rockchip,pins =
                                <3 24 1 &pcfg_pull_none>,
                                <3 25 1 &pcfg_pull_none>,
                                <3 26 1 &pcfg_pull_none>,
                                <3 27 1 &pcfg_pull_none>,
                                <3 31 1 &pcfg_pull_none>;
Run "armbian-add-overlay fix-es8316.dts", reboot and enjoy!
