antonlyap Posted October 4, 2020 Share Posted October 4, 2020 Armbianmonitor: http://ix.io/2zHl Hi there! I am trying to set up communication between an Attiny85 and my RockPro64 over UART (running Armbian, kernel `Linux rockpro64 5.8.1-rockchip64 #20.08 SMP PREEMPT Mon Aug 17 08:17:08 CEST 2020 aarch64 aarch64 aarch64 GNU/Linux`). The issue is that I can't connect to the serial port: rock64@rockpro64:~$ sudo picocom -b 115200 /dev/ttyS4 picocom v3.1 port is : /dev/ttyS4 flowcontrol : none baudrate is : 115200 parity is : none databits are : 8 stopbits are : 1 escape is : C-a local echo is : no noinit is : no noreset is : no hangup is : no nolock is : no send_cmd is : sz -vv receive_cmd is : rz -vv -E imap is : omap is : emap is : crcrlf,delbs, logfile is : none initstring : none exit_after is : not set exit is : no FATAL: failed to add port: Filedes is not a tty Here are some details about my setup: An Attiny85 is powered from a 3V coin cell. Here is the wiring: Battery positive - Attiny85 pin 8 Battery negative - Attiny85 pin 4 - RockPro64 ground on GPIO pin 6 Attiny85 pin 6 (PB1) - RockPro64 UART4_RX on GPIO pin 21 (connected through a 1K current-limiting resistor) UART4_TX is not connected because currently I only need unidirectional communication I used Arduino IDE with a USBtinyISP programmer to program my Attiny85 with the following test code: #include <SoftwareSerial.h> #define RX 0 #define TX 1 SoftwareSerial serial(RX, TX); void setup() { // put your setup code here, to run once: serial.begin(115200); } void loop() { // put your main code here, to run repeatedly: serial.println("ping"); } I have tried using different kernels (including dev) and switching between different combinations of overlays (UART4 and SPI1 share the same pins on RockPro64). The RockPro64 itself is booting from an eMMC module, the SPI flash contains U-Boot for USB and PXE boot support. Is there any way I can fix this issue? Are there any other easy-to-use alternatives to UART for establishing bidirectional communication? Any help is appreciated! Thanks, Anton 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted October 4, 2020 Share Posted October 4, 2020 24 minutes ago, antonlyap said: Is there any way I can fix this issue? Did you loaded the uart4 overlay in /boot/armbianEnv.txt ? 0 Quote Link to comment Share on other sites More sharing options...
antonlyap Posted October 4, 2020 Author Share Posted October 4, 2020 Yes, I did, check out the armbianmonitor -u output link: verbosity=1 bootlogo=false overlay_prefix=rockchip rootdev=UUID=73fac48d-4f73-4ac1-b899-e67dc98b5794 rootfstype=ext4 overlays=uart4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 0 Quote Link to comment Share on other sites More sharing options...
piter75 Posted October 4, 2020 Share Posted October 4, 2020 2 hours ago, antonlyap said: the SPI flash contains U-Boot for USB and PXE boot support What is this u-boot's source? Does it have overlays support enabled (CONFIG_OF_LIBFDT_OVERLAY)? Can you also verify if you have uart4 overlay in your filesystem? root@rockpro64:~# ll /boot/dtb/rockchip/overlay/rockchip-uart4.dtbo -rwxr-xr-x 1 root root 384 Sep 4 18:23 /boot/dtb/rockchip/overlay/rockchip-uart4.dtbo* Your dmesg still contains spi-nor entry so either there is no uart4 overlay or it is not applied. [ 4.152295] spi-nor spi0.0: gd25q128 (16384 Kbytes) 0 Quote Link to comment Share on other sites More sharing options...
antonlyap Posted October 4, 2020 Author Share Posted October 4, 2020 Thanks for your message! Actually, it turns out that U-Boot is the source of the problem. I erased the SPI flash and now, when booting directly from eMMC, UART4 does get initialized. Here is the new output from armbianmonitor -u: http://ix.io/2zIr. When connecting to the serial port though, I get some garbage output instead of the ping messages I'm supposed to get. The baudrate is matched on both sides, what else could be wrong with my settings? 0 Quote Link to comment Share on other sites More sharing options...
antonlyap Posted October 4, 2020 Author Share Posted October 4, 2020 It worked after changing the baud rate on both sides to 9600. I'm not sure why it didn't work with 115200 baud - probably the problem is on the Attiny side, I just read that SoftwareSerial doesn't work well with high baud rates. Anyway, thanks everyone for your help, it is appreciated 0 Quote Link to comment Share on other sites More sharing options...
