FloatingSunfish Posted October 5, 2020 Posted October 5, 2020 I'm trying to create a custom Armbian image based on the User Configurations documentation. I can see that I can install additional packages by editing `userpatches/lib.config` and adding entries to the `PACKAGE_LIST_ADDITIONAL` variable, and I can work with custom files like scripts by placing them inside `userpatches/overlay` and accessing them in `/tmp/overlay` via `customize-image.sh`. My question is, does `customize-image.sh` support the below commands given that it executes in a chroot environment: NOTE: Some commands below require `sudo`, but because we're already in a chroot environment, I assume we can run them without `sudo`. 1. Creating directories inside `/`: mkdir -m 777 /myscripts 2. Copying files from `/tmp/overlay` to other directories: cp -rf /tmp/overlay/myscript.sh /mysrcipts/ 3. Making script files executable by services: chmod a+x /myscripts/samplescript.sh 4. Starting and enabling system services: systemctl start systemd-networkd systemctl enable systemd-networkd 5. Updating repositories: apt-get -y update apt-get -y upgrade apt-get -y dist-upgrade 6. Copying custom service files to `/etc/systemd/system` and giving them proper permissions: cp -rf /tmp/overlay/myservice.service /etc/systemd/system/ chmod 644 /etc/systemd/system/myservice.service 7. Installing and starting custom services: systemctl daemon-reload systemctl start myservice systemctl enable myservice
Igor Posted October 5, 2020 Posted October 5, 2020 On 10/5/2020 at 7:01 AM, FloatingSunfish said: given that it executes in a chroot environment: Expand We build entire system and support packages in chroot environment. I don't see any reasons why this won't work. Did you at least tried it once? Make sure to check CLEAN_LEVEL to disable kernel rebuilding - everything else is cached. But when you are changing package structure, cache will be rebuild since its tied to the package list. 1
FloatingSunfish Posted October 6, 2020 Author Posted October 6, 2020 (edited) On 10/5/2020 at 7:06 AM, Igor said: I don't see any reasons why this won't work. Expand That's good to hear. On 10/5/2020 at 7:06 AM, Igor said: Did you at least tried it once? Expand Not yet, as the build process reportedly takes a few hours and I don't want to make such costly moves without first knowing as much as I can about them. On 10/5/2020 at 7:06 AM, Igor said: Make sure to check CLEAN_LEVEL to disable kernel rebuilding - everything else is cached. Expand Do you mean something like this? sudo ./compile.sh CLEAN_LEVEL="debs" Based on what I understand from the docs, the default value of `CLEAN_LEVEL` is "make,debs", and it's the "make" value that triggers kernel rebuilds. Will the above disable kernel rebuilding? Also, can I get some Likes or something to remove this "Validating" status so I can reply to this thread faster? Waiting 24 hours before being able to reply is quite limiting and waiting 7 days for the Validating status to go away feels too long. Lastly, I can't seem to edit my Avatar/Profile Pic. Has it been disabled or something? Edited October 6, 2020 by FloatingSunfish
Igor Posted October 6, 2020 Posted October 6, 2020 On 10/6/2020 at 8:44 AM, FloatingSunfish said: Do you mean something like this? Expand Full caching is when CLEAN_LEVEL is blank. On 10/6/2020 at 8:44 AM, FloatingSunfish said: Waiting 24 hours before being able to reply is quite limiting and waiting 7 days for the Validating status to go away feels too long. Expand This is not a professional support channel. Its a forum and this limit is that you think about before getting to excited asking for questions all over this place. Pick a way at least to cover your part of support costs if you don't support R&D. https://forum.armbian.com/subscriptions/ If you choose perk for 500 EUR per month, then you can expect someone will be here all the time and will reply you within lets say one hour. If you choose less, you will become unrestricted user at once but you will still need to wait ... if you choose to give nothing back, where is the source of the rights to complain? And this way we also get rid of those few % of the spam that penetrate automatic defence. 1
