Espressobin v5 - Armbian_20.08.2_Espressobin_buster_current_5.8.6.img bad image format
Go to solution Solved by voltagex,
Marvell>> bubt flash-image-DDR3-2g_2cs_7-600_600.bin
Burning U-BOOT image "flash-image-DDR3-2g_2cs_7-600_600.bin" from "tftp" to "spi"
Using neta@30000 device
TFTP from server 192.168.10.1; our IP address is 192.168.10.253
Filename 'flash-image-DDR3-2g_2cs_7-600_600.bin'.
Load address: 0x8000000
Loading: #############################################################
         4.8 MiB/s
done
Bytes transferred = 895012 (da824 hex)
Image checksum...OK!
722980 bytes written, 172032 bytes skipped in 8.713s, speed 105174 B/s
Done!
Marvell>> reset
resetting ...
TIM-1.0
WTMI-devel-18.12.1-e6bb176
WTMI: system early-init
DDR topology parameters:
ddr type               DDR3
ddr speedbin           12
bus width              16-bits
cs num                 2
  cs[0] - group num    0
  cs[0] - bank num     8
  cs[0] - capacity     1024MiB
  cs[1] - group num    0
  cs[1] - bank num     8
  cs[1] - capacity     1024MiB
CPU VDD voltage default value: 1.108V
DRAM windows:
WIN[0] - base addr     0x60000000
WIN[0] - size          0x40000000
WIN[1] - base addr     0xa0000000
WIN[1] - size          0x20000000
memory test region:
CS[0]                  0x60000000 - 0x9fffffff
CS[1]                  0xa0000000 - 0xbfffffff
SELF-REFRESH TEST PASS
CS0: QS GATE TRAINING PASSED
CS1: QS GATE TRAINING PASSED
DLL TUNING PASSED
NOTICE:  Booting Trusted Firmware
NOTICE:  BL1: v1.5(debug):1f8ca7e (Marvell-devel-18.12.2)
NOTICE:  BL1: Built : 09:15:30, Oct 20 2020
NOTICE:  BL1: Booting BL2
NOTICE:  BL2: v1.5(debug):1f8ca7e (Marvell-devel-18.12.2)
NOTICE:  BL2: Built : 09:15:30, Oct 20 2020
NOTICE:  BL1: Booting BL31
NOTICE:  BL31: v1.5(debug):1f8ca7e (Marvell-devel-18.12.2)
NOTICE:  BL31: Built : 09:15:30, Oct
U-Boot 2018.03-devel-18.12.3-armbian (Oct 20 2020 - 09:15:15 +0000)
Model: Marvell Armada 3720 Community Board ESPRESSOBin
       CPU     600 [MHz]
       L2      800 [MHz]
       TClock  200 [MHz]
       DDR     600 [MHz]
DRAM:  2 GiB
Comphy chip #0:
Comphy-0: USB3          5 Gbps
Comphy-1: PEX0          2.5 Gbps
Comphy-2: SATA0         6 Gbps
SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
flags: ncq led only pmp fbss pio slum part sxs
PCIE-0: Link down
MMC:   sdhci@d0000: 0, sdhci@d8000: 1
Loading Environment from SPI Flash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB
OK
Net:   eth0: neta@30000 [PRIME]
starting USB...
USB0:   Register 2000104 NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1:   USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
** Bad device usb 0 **
## Executing script at 06d00000
Wrong image format for "source" command
/boot/
scanning bus for devices...
Device 0: unknown device
** Bad device scsi 0 **
/boot/
Card did not respond to voltage select!
** Bad device mmc 1 **
/boot/
** File not found /boot.scr **
/boot/
3185 bytes read in 13 ms (239.3 KiB/s)
Boot script loaded from  0
** Bad device 0 0x9000000 **
** Bad device specification 0 /boot/uInitrd **
** Bad device specification 0 /boot/Image **
** Bad device specification 0 /boot/dtb/ **
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
Applying user provided fixup script (fixup.scr)
## Executing script at 09000000
Bad Linux ARM64 Image magic!
Marvell>> printenv
baudrate=115200
boot_a_script=ext4load ${boot_interface} ${devnum}:1 ${scriptaddr} ${prefix}boot.scr;source ${scriptaddr};
boot_interface=mmc
boot_prefixes=/ /boot/
boot_targets=usb sata mmc1 mmc0
bootargs=root=/dev/mmcblk0p1 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
bootcmd_mmc0=setenv devnum 0; setenv boot_interface mmc; run scan_dev_for_boot;
bootcmd_mmc1=setenv devnum 1; setenv boot_interface mmc; run scan_dev_for_boot;
bootcmd_sata=setenv devnum 0; scsi scan; scsi dev 0; setenv boot_interface scsi; run scan_dev_for_boot;
bootcmd_usb=setenv devnum 0; usb start;setenv boot_interface usb; run scan_dev_for_boot;
bootdelay=2
bootlogo=false
console=both
consoleargs=console=ttyS2,1500000 console=tty1
devnum=0
docker_optimizations=on
earlycon=off
eth1addr=00:51:82:11:22:01
eth2addr=00:51:82:11:22:02
eth3addr=00:51:82:11:22:03
ethact=neta@30000
ethaddr=00:51:82:11:22:00
ethprime=eth0
fdt_addr=0x6000000
fdt_high=0xffffffffffffffff
fdt_name=fdt.dtb
fdtcontroladdr=7f62d490
fileaddr=6d00000
filesize=c71
gatewayip=10.4.50.254
get_images=tftpboot $kernel_addr $image_name; tftpboot $fdt_addr $fdt_name; run get_ramfs
get_ramfs=if test "${ramfs_name}" != "-"; then setenv ramfs_addr 0x8000000; tftpboot $ramfs_addr $ramfs_name; else setenv ramfs_addr -;fi
hostname=marvell
image_name=Image
initrd_addr=0x1100000
initrd_image=uInitrd
initrd_size=0x2000000
ipaddr=0.0.0.0
kernel_addr=0x7000000
load_addr=0x9000000
loadaddr=0x8000000
netdev=eth0
netmask=255.255.255.0
overlay_error=false
ramfs_addr=0x8000000
ramfs_name=-
root=root=/dev/nfs rw
rootdev=/dev/mmcblk0p1
rootfstype=ext4
rootpath=/srv/nfs/
scan_dev_for_boot=for prefix in ${boot_prefixes}; do echo ${prefix};run boot_a_script; done
scriptaddr=0x6d00000
serverip=192.168.10.1
set_bootargs=setenv bootargs $console $root ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:none nfsroot=$serverip:$rootpath $extra_params
stderr=serial@12000
stdin=serial@12000
stdout=serial@12000
verbosity=1
Environment size: 2298/65532 bytes
Marvell>>
Apologies, I couldn't move the code block once I'd put it in here.
I'm trying to boot Armbian_20.08.2_Espressobin_buster_current_5.8.6.img written onto a known-good SD card. I've tried both on an older bootloader and the 2018 one suggested by Armbian.
The image "flash-image-DDR3-2g_2cs_7-600_600.bin" is not from the EspressoBin download page. Please try the current ones - they are from Sept. 2020 - branch 18.12-fixed.
The ones you have tied were probably produced by the Armbian build system on the fly and are not tested.
  • Solution
Weird, flashed back to the one you suggested now that the download page is back up, had the same issue - must have been the SD card after all.
It's also now working with my 2020.10 bootloader!
