Hey everyone. I have an MK802 II stick, which has the A10 s.o.c, so i use the Olinuxino Lime a10 image on it.
Everything works pretty much fine, except one little thing.
This machine has worked fine with non-standard resolutions, like 1440x900, or 1280x1024.
Now, when i turn it on, the U-boot screen appears correctly, it even shows that it set the resolution to 1440x900, and after that, the monitor says "signal out of range".
Of course, it works well with a 1080p monitor, but i wanted to use this one too.
Thanks!
