Coboy Ciamis Posted November 5, 2020 Posted November 5, 2020 Hai . . can you install cisco on armbian?
SteeMan Posted November 7, 2020 Posted November 7, 2020 If the software you require is included in the distribution you are installing (i.e. debian or ubuntu) under armbian, it likely will work, unless it depends on specific kernel configuration parameters, in which case you might need to build a custom kernel.
