lagerschaden Posted November 17, 2020 Posted November 17, 2020 I have the same problem like other users here, the 1-wire doesn't run correctly, I added 1-wire to armbianEnv.txt, 1-wire drivers are loaded, but I cannot access the data of DS18B20 attached to PA06. L. ___ ____ _ _____ / _ \| _ \(_) |__ /___ _ __ ___ | | | | |_) | | / // _ \ '__/ _ \ | |_| | __/| | / /| __/ | | (_) | \___/|_| |_| /____\___|_| \___/ Welcome to Armbian 20.08.17 Bionic with Linux 5.8.16-sunxi System load: 26% Up time: 0 min Memory usage: 14% of 491M IP: 192.168.3.163 CPU temp: 45°C Usage of /: 4% of 29G Last login: Tue Nov 17 15:06:39 2020 from 192.168.3.31 pi@orangepizero:~$ cat /boot/armbianEnv.txt verbosity=7 logo=disabled console=serial disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 rootdev=UUID=4618846b-19e6-421b-8872-767a46ed5e1e rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u overlays=w1-gpio param_w1_pin=PA06 # desired pin param_w1_pin_int_pullup=1 # internal pullup-resistor: 1=on, 0=off pi@orangepizero:~$ ls -l /sys/bus/w1/devices/ total 0 lrwxrwxrwx 1 root root 0 Nov 17 15:09 w1_bus_master1 -> ../../../devices/w1_bus_master1 pi@orangepizero:~$ sudo cat /sys/kernel/debug/gpio [sudo] password for pi: gpiochip0: GPIOs 0-223, parent: platform/1c20800.pinctrl, 1c20800.pinctrl: gpio-11 ( |sysfs ) out lo gpio-17 ( |orangepi:red:status ) out lo gpio-20 ( |reg_vcc_wifi ) out hi gpio-110 ( |onewire@0 ) out lo <-------------------- gpio-166 ( |cd ) in lo ACTIVE LOW gpio-204 ( |usb0_id_det ) in hi IRQ gpiochip1: GPIOs 352-383, parent: platform/1f02c00.pinctrl, 1f02c00.pinctrl: gpio-358 ( |vdd-cpux ) out hi gpio-359 ( |reset ) out hi ACTIVE LOW gpio-362 ( |orangepi:green:pwr ) out hi pi@orangepizero:~$ lsmod Module Size Used by aes_arm_bs 20480 2 crypto_simd 16384 1 aes_arm_bs ccm 20480 6 xradio_wlan 114688 1 mac80211 516096 1 xradio_wlan cfg80211 471040 2 mac80211,xradio_wlan lima 45056 0 rfkill 20480 3 cfg80211 gpu_sched 28672 1 lima libarc4 16384 1 mac80211 sun4i_gpadc_iio 16384 0 industrialio 53248 1 sun4i_gpadc_iio sun8i_thermal 16384 0 sun8i_ce 24576 0 crypto_engine 16384 1 sun8i_ce sun8i_di 20480 0 sunxi_cedrus 32768 0 w1_gpio 16384 0 <------------- zram 24576 2 wire 32768 1 w1_gpio cn 16384 1 wire uio_pdrv_genirq 16384 0 uio 16384 1 uio_pdrv_genirq cpufreq_dt 20480 0 sch_fq_codel 20480 6 usb_f_acm 20480 1 u_serial 24576 3 usb_f_acm g_serial 16384 0 libcomposite 45056 2 g_serial,usb_f_acm ip_tables 24576 0 x_tables 24576 1 ip_tables autofs4 36864 2 pwrseq_simple 16384 1 sunxi 20480 0 phy_generic 20480 2 sunxi pi@orangepizero:~$ ls -l /boot/dtb/overlay/ total 384 -rw-r--r-- 1 root root 5448 Oct 20 22:15 README.sun4i-a10-overlays -rw-r--r-- 1 root root 3262 Oct 20 22:15 README.sun5i-a13-overlays -rw-r--r-- 1 root root 6817 Oct 20 22:15 README.sun7i-a20-overlays -rw-r--r-- 1 root root 4736 Oct 20 22:15 README.sun8i-h3-overlays -rw-r--r-- 1 root root 267 Oct 20 22:15 sun4i-a10-analog-codec.dtbo -rw-r--r-- 1 root root 387 Oct 20 22:15 sun4i-a10-can.dtbo -rw-r--r-- 1 root root 4832 Oct 20 22:15 sun4i-a10-fixup.scr -rw-r--r-- 1 root root 500 Oct 20 22:15 sun4i-a10-i2c1.dtbo -rw-r--r-- 1 root root 500 Oct 20 22:15 sun4i-a10-i2c2.dtbo -rw-r--r-- 1 root root 2301 Oct 20 22:15 sun4i-a10-nand.dtbo -rw-r--r-- 1 root root 778 Oct 20 22:15 sun4i-a10-pps-gpio.dtbo -rw-r--r-- 1 root root 443 Oct 20 22:15 sun4i-a10-pwm.dtbo -rw-r--r-- 1 root root 1040 Oct 20 22:15 sun4i-a10-spdif-out.dtbo -rw-r--r-- 1 root root 1093 Oct 20 22:15 sun4i-a10-spi-jedec-nor.dtbo -rw-r--r-- 1 root root 1069 Oct 20 22:15 sun4i-a10-spi-spidev.dtbo -rw-r--r-- 1 root root 949 Oct 20 22:15 sun4i-a10-uart2.dtbo -rw-r--r-- 1 root root 1205 Oct 20 22:15 sun4i-a10-uart3.dtbo -rw-r--r-- 1 root root 935 Oct 20 22:15 sun4i-a10-uart4.dtbo -rw-r--r-- 1 root root 802 Oct 20 22:15 sun4i-a10-uart5.dtbo -rw-r--r-- 1 root root 806 Oct 20 22:15 sun4i-a10-uart6.dtbo -rw-r--r-- 1 root root 806 Oct 20 22:15 sun4i-a10-uart7.dtbo -rw-r--r-- 1 root root 777 Oct 20 22:15 sun4i-a10-w1-gpio.dtbo -rw-r--r-- 1 root root 267 Oct 20 22:15 sun5i-a13-analog-codec.dtbo -rw-r--r-- 1 root root 2146 Oct 20 22:15 sun5i-a13-fixup.scr -rw-r--r-- 1 root root 500 Oct 20 22:15 sun5i-a13-i2c1.dtbo -rw-r--r-- 1 root root 500 Oct 20 22:15 sun5i-a13-i2c2.dtbo -rw-r--r-- 1 root root 1239 Oct 20 22:15 sun5i-a13-nand.dtbo -rw-r--r-- 1 root root 382 Oct 20 22:15 sun5i-a13-pwm.dtbo -rw-r--r-- 1 root root 1069 Oct 20 22:15 sun5i-a13-spi-jedec-nor.dtbo -rw-r--r-- 1 root root 1045 Oct 20 22:15 sun5i-a13-spi-spidev.dtbo -rw-r--r-- 1 root root 974 Oct 20 22:15 sun5i-a13-spi0.dtbo -rw-r--r-- 1 root root 936 Oct 20 22:15 sun5i-a13-spi1.dtbo -rw-r--r-- 1 root root 563 Oct 20 22:15 sun5i-a13-spi2.dtbo -rw-r--r-- 1 root root 795 Oct 20 22:15 sun5i-a13-uart0.dtbo -rw-r--r-- 1 root root 505 Oct 20 22:15 sun5i-a13-uart1.dtbo -rw-r--r-- 1 root root 505 Oct 20 22:15 sun5i-a13-uart2.dtbo -rw-r--r-- 1 root root 505 Oct 20 22:15 sun5i-a13-uart3.dtbo -rw-r--r-- 1 root root 267 Oct 20 22:15 sun7i-a20-analog-codec.dtbo -rw-r--r-- 1 root root 386 Oct 20 22:15 sun7i-a20-can.dtbo -rw-r--r-- 1 root root 5532 Oct 20 22:15 sun7i-a20-fixup.scr -rw-r--r-- 1 root root 500 Oct 20 22:15 sun7i-a20-i2c1.dtbo -rw-r--r-- 1 root root 500 Oct 20 22:15 sun7i-a20-i2c2.dtbo -rw-r--r-- 1 root root 500 Oct 20 22:15 sun7i-a20-i2c3.dtbo -rw-r--r-- 1 root root 766 Oct 20 22:15 sun7i-a20-i2c4.dtbo -rw-r--r-- 1 root root 590 Oct 20 22:15 sun7i-a20-mmc2.dtbo -rw-r--r-- 1 root root 2301 Oct 20 22:15 sun7i-a20-nand.dtbo -rw-r--r-- 1 root root 778 Oct 20 22:15 sun7i-a20-pps-gpio.dtbo -rw-r--r-- 1 root root 443 Oct 20 22:15 sun7i-a20-pwm.dtbo -rw-r--r-- 1 root root 1040 Oct 20 22:15 sun7i-a20-spdif-out.dtbo -rw-r--r-- 1 root root 556 Oct 20 22:15 sun7i-a20-spi-add-cs1.dtbo -rw-r--r-- 1 root root 1093 Oct 20 22:15 sun7i-a20-spi-jedec-nor.dtbo -rw-r--r-- 1 root root 1069 Oct 20 22:15 sun7i-a20-spi-spidev.dtbo -rw-r--r-- 1 root root 808 Oct 20 22:15 sun7i-a20-uart2.dtbo -rw-r--r-- 1 root root 1078 Oct 20 22:15 sun7i-a20-uart3.dtbo -rw-r--r-- 1 root root 513 Oct 20 22:15 sun7i-a20-uart4.dtbo -rw-r--r-- 1 root root 513 Oct 20 22:15 sun7i-a20-uart5.dtbo -rw-r--r-- 1 root root 513 Oct 20 22:15 sun7i-a20-uart6.dtbo -rw-r--r-- 1 root root 513 Oct 20 22:15 sun7i-a20-uart7.dtbo -rw-r--r-- 1 root root 777 Oct 20 22:15 sun7i-a20-w1-gpio.dtbo -rw-r--r-- 1 root root 339 Oct 20 22:15 sun8i-h3-analog-codec.dtbo -rw-r--r-- 1 root root 384 Oct 20 22:15 sun8i-h3-cir.dtbo -rw-r--r-- 1 root root 478 Oct 20 22:15 sun8i-h3-cpu-clock-1.2GHz-1.3v.dtbo -rw-r--r-- 1 root root 982 Oct 20 22:15 sun8i-h3-cpu-clock-1.368GHz-1.3v.dtbo -rw-r--r-- 1 root root 898 Oct 20 22:15 sun8i-h3-cpu-clock-1.3GHz-1.3v.dtbo -rw-r--r-- 1 root root 4185 Oct 20 22:15 sun8i-h3-fixup.scr -rw-r--r-- 1 root root 374 Oct 20 22:15 sun8i-h3-i2c0.dtbo -rw-r--r-- 1 root root 374 Oct 20 22:15 sun8i-h3-i2c1.dtbo -rw-r--r-- 1 root root 374 Oct 20 22:15 sun8i-h3-i2c2.dtbo -rw-r--r-- 1 root root 778 Oct 20 22:15 sun8i-h3-pps-gpio.dtbo -rw-r--r-- 1 root root 862 Oct 20 22:15 sun8i-h3-pwm.dtbo -rw-r--r-- 1 root root 1040 Oct 20 22:15 sun8i-h3-spdif-out.dtbo -rw-r--r-- 1 root root 1177 Oct 20 22:15 sun8i-h3-spi-add-cs1.dtbo -rw-r--r-- 1 root root 804 Oct 20 22:15 sun8i-h3-spi-jedec-nor.dtbo -rw-r--r-- 1 root root 788 Oct 20 22:15 sun8i-h3-spi-spidev.dtbo -rw-r--r-- 1 root root 502 Oct 20 22:15 sun8i-h3-uart1.dtbo -rw-r--r-- 1 root root 502 Oct 20 22:15 sun8i-h3-uart2.dtbo -rw-r--r-- 1 root root 502 Oct 20 22:15 sun8i-h3-uart3.dtbo -rw-r--r-- 1 root root 504 Oct 20 22:15 sun8i-h3-usbhost0.dtbo -rw-r--r-- 1 root root 504 Oct 20 22:15 sun8i-h3-usbhost1.dtbo -rw-r--r-- 1 root root 504 Oct 20 22:15 sun8i-h3-usbhost2.dtbo -rw-r--r-- 1 root root 504 Oct 20 22:15 sun8i-h3-usbhost3.dtbo -rw-r--r-- 1 root root 777 Oct 20 22:15 sun8i-h3-w1-gpio.dtbo <----------- -rw-r--r-- 1 root root 374 Oct 20 22:15 sun8i-r40-i2c2.dtbo -rw-r--r-- 1 root root 374 Oct 20 22:15 sun8i-r40-i2c3.dtbo -rw-r--r-- 1 root root 547 Oct 20 22:15 sun8i-r40-spi-spidev0.dtbo -rw-r--r-- 1 root root 547 Oct 20 22:15 sun8i-r40-spi-spidev1.dtbo -rw-r--r-- 1 root root 505 Oct 20 22:15 sun8i-r40-uart2.dtbo -rw-r--r-- 1 root root 505 Oct 20 22:15 sun8i-r40-uart4.dtbo -rw-r--r-- 1 root root 505 Oct 20 22:15 sun8i-r40-uart5.dtbo -rw-r--r-- 1 root root 505 Oct 20 22:15 sun8i-r40-uart7.dtbo pi@orangepizero:~$ ls -l /sys/bus/w1/devices/ total 0 lrwxrwxrwx 1 root root 0 Nov 17 15:21 00-300000000000 -> ../../../devices/w1_bus_master1/00-300000000000 lrwxrwxrwx 1 root root 0 Nov 17 15:21 00-700000000000 -> ../../../devices/w1_bus_master1/00-700000000000 lrwxrwxrwx 1 root root 0 Nov 17 15:21 00-b00000000000 -> ../../../devices/w1_bus_master1/00-b00000000000 lrwxrwxrwx 1 root root 0 Nov 17 15:09 w1_bus_master1 -> ../../../devices/w1_bus_master1 pi@orangepizero:~$ ls -l /sys/bus/w1/devices/ total 0 lrwxrwxrwx 1 root root 0 Nov 17 15:21 00-700000000000 -> ../../../devices/w1_bus_master1/00-700000000000 lrwxrwxrwx 1 root root 0 Nov 17 15:21 00-b00000000000 -> ../../../devices/w1_bus_master1/00-b00000000000 lrwxrwxrwx 1 root root 0 Nov 17 15:09 w1_bus_master1 -> ../../../devices/w1_bus_master1 pi@orangepizero:~$ ls -l /sys/bus/w1/devices/ total 0 lrwxrwxrwx 1 root root 0 Nov 17 15:21 00-700000000000 -> ../../../devices/w1_bus_master1/00-700000000000 lrwxrwxrwx 1 root root 0 Nov 17 15:21 00-b00000000000 -> ../../../devices/w1_bus_master1/00-b00000000000 lrwxrwxrwx 1 root root 0 Nov 17 15:21 00-f00000000000 -> ../../../devices/w1_bus_master1/00-f00000000000 lrwxrwxrwx 1 root root 0 Nov 17 15:09 w1_bus_master1 -> ../../../devices/w1_bus_master1 pi@orangepizero:~$ ls -l /sys/bus/w1/devices total 0 lrwxrwxrwx 1 root root 0 Nov 17 15:22 00-080000000000 -> ../../../devices/w1_bus_master1/00-080000000000 lrwxrwxrwx 1 root root 0 Nov 17 15:21 00-700000000000 -> ../../../devices/w1_bus_master1/00-700000000000 lrwxrwxrwx 1 root root 0 Nov 17 15:21 00-f00000000000 -> ../../../devices/w1_bus_master1/00-f00000000000 lrwxrwxrwx 1 root root 0 Nov 17 15:09 w1_bus_master1 -> ../../../devices/w1_bus_master1 pi@orangepizero:~$ ls -l /sys/bus/w1/devices/00-700000000000/ ls: cannot access '/sys/bus/w1/devices/00-700000000000/': No such file or directory pi@orangepizero:~$ ls -l /sys/bus/w1/devices/00-080000000000/ total 0 lrwxrwxrwx 1 root root 0 Nov 17 15:23 driver -> ../../../bus/w1/drivers/w1_slave_driver -r--r--r-- 1 root root 4096 Nov 17 15:23 id -r--r--r-- 1 root root 4096 Nov 17 15:23 name drwxr-xr-x 2 root root 0 Nov 17 15:23 power -rw-r--r-- 1 root root 4096 Nov 17 15:23 rw lrwxrwxrwx 1 root root 0 Nov 17 15:23 subsystem -> ../../../bus/w1 -rw-r--r-- 1 root root 4096 Nov 17 15:22 uevent pi@orangepizero:~$ ls -l /sys/bus/w1/devices/00-f00000000000/ ls: cannot access '/sys/bus/w1/devices/00-f00000000000/': No such file or directory
lagerschaden Posted November 17, 2020 Author Posted November 17, 2020 The names of the files in /sys/bus/w1/devices/ change every few seconds and there is never a /sys/bus/w1/devices/00-............/w1-slave
martinayotte Posted November 17, 2020 Posted November 17, 2020 5 minutes ago, lagerschaden said: param_w1_pin=PA06 Shoud be "PA6" (pin 7) instead ...
lagerschaden Posted November 17, 2020 Author Posted November 17, 2020 28 minutes ago, martinayotte said: Shoud be "PA6" (pin 7) instead ... Didn't help pi@orangepizero:~$ ls -l /sys/bus/w1/devices/ total 0 lrwxrwxrwx 1 root root 0 Nov 17 16:07 w1_bus_master1 -> ../../../devices/w1_bus_master1
martinayotte Posted November 17, 2020 Posted November 17, 2020 1 hour ago, lagerschaden said: gpio-110 ( |onewire@0 ) out lo Is this still present ? Because 110 is wrong ... It is like you still have the default pin which is PD14 ... What "dmesg | grep w1" command is giving you ?
lagerschaden Posted November 17, 2020 Author Posted November 17, 2020 11 minutes ago, martinayotte said: Is this still present ? Because 110 is wrong ... It is like you still have the default pin which is PD14 ... What "dmesg | grep w1" command is giving you ? pi@orangepizero:~$ dmesg | grep w1 [ 10.918414] w1-gpio onewire@0: there is not valid maps for state default [ 13.026099] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search. [ 60.043354] w1_master_driver w1_bus_master1: Attaching one wire slave 00.800000000000 crc 8c [ 60.053853] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered. [ 118.651988] w1_master_driver w1_bus_master1: Attaching one wire slave 00.400000000000 crc 46 [ 118.661513] w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46 is not registered. [ 165.455530] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c00000000000 crc ca [ 165.461396] w1_master_driver w1_bus_master1: Family 0 for 00.c00000000000.ca is not registered. [ 235.892434] w1_master_driver w1_bus_master1: Attaching one wire slave 00.200000000000 crc 23 [ 235.898397] w1_master_driver w1_bus_master1: Family 0 for 00.200000000000.23 is not registered. [ 294.518468] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a00000000000 crc af [ 294.527735] w1_master_driver w1_bus_master1: Family 0 for 00.a00000000000.af is not registered. [ 329.521925] w1_master_driver w1_bus_master1: Attaching one wire slave 00.600000000000 crc 65 [ 329.528850] w1_master_driver w1_bus_master1: Family 0 for 00.600000000000.65 is not registered. [ 366.186710] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e00000000000 crc e9 [ 366.193140] w1_master_driver w1_bus_master1: Family 0 for 00.e00000000000.e9 is not registered. [ 424.451012] w1_master_driver w1_bus_master1: Attaching one wire slave 00.100000000000 crc 9d [ 424.456823] w1_master_driver w1_bus_master1: Family 0 for 00.100000000000.9d is not registered. [ 460.156559] w1_master_driver w1_bus_master1: Attaching one wire slave 00.900000000000 crc 11 [ 460.165709] w1_master_driver w1_bus_master1: Family 0 for 00.900000000000.11 is not registered. [ 529.873516] w1_master_driver w1_bus_master1: Attaching one wire slave 00.500000000000 crc db [ 529.880819] w1_master_driver w1_bus_master1: Family 0 for 00.500000000000.db is not registered. [ 577.478516] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d00000000000 crc 57 [ 577.486009] w1_master_driver w1_bus_master1: Family 0 for 00.d00000000000.57 is not registered. [ 601.598000] w1_master_driver w1_bus_master1: Attaching one wire slave 00.300000000000 crc be [ 601.604024] w1_master_driver w1_bus_master1: Family 0 for 00.300000000000.be is not registered. [ 647.507023] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b00000000000 crc 32 [ 647.513166] w1_master_driver w1_bus_master1: Family 0 for 00.b00000000000.32 is not registered. [ 683.415700] w1_master_driver w1_bus_master1: Attaching one wire slave 00.700000000000 crc f8 [ 683.421654] w1_master_driver w1_bus_master1: Family 0 for 00.700000000000.f8 is not registered. [ 730.960493] w1_master_driver w1_bus_master1: Attaching one wire slave 00.f00000000000 crc 74 [ 730.966974] w1_master_driver w1_bus_master1: Family 0 for 00.f00000000000.74 is not registered. [ 788.901338] w1_master_driver w1_bus_master1: Attaching one wire slave 00.080000000000 crc c2 [ 788.907217] w1_master_driver w1_bus_master1: Family 0 for 00.080000000000.c2 is not registered. [ 837.233978] w1_master_driver w1_bus_master1: Attaching one wire slave 00.880000000000 crc 4e [ 837.240541] w1_master_driver w1_bus_master1: Family 0 for 00.880000000000.4e is not registered. [ 872.307557] w1_master_driver w1_bus_master1: Attaching one wire slave 00.480000000000 crc 84 [ 872.314802] w1_master_driver w1_bus_master1: Family 0 for 00.480000000000.84 is not registered. [ 919.036110] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c80000000000 crc 08 [ 919.043360] w1_master_driver w1_bus_master1: Family 0 for 00.c80000000000.08 is not registered. [ 989.661007] w1_master_driver w1_bus_master1: Attaching one wire slave 00.280000000000 crc e1 [ 989.670331] w1_master_driver w1_bus_master1: Family 0 for 00.280000000000.e1 is not registered. [ 1048.216544] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a80000000000 crc 6d [ 1048.222266] w1_master_driver w1_bus_master1: Family 0 for 00.a80000000000.6d is not registered. [ 1106.778063] w1_master_driver w1_bus_master1: Attaching one wire slave 00.680000000000 crc a7 [ 1106.783881] w1_master_driver w1_bus_master1: Family 0 for 00.680000000000.a7 is not registered. [ 1143.420175] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e80000000000 crc 2b [ 1143.429445] w1_master_driver w1_bus_master1: Family 0 for 00.e80000000000.2b is not registered. [ 1201.748193] w1_master_driver w1_bus_master1: Attaching one wire slave 00.180000000000 crc 5f [ 1201.754066] w1_master_driver w1_bus_master1: Family 0 for 00.180000000000.5f is not registered. [ 1237.584915] w1_master_driver w1_bus_master1: Attaching one wire slave 00.980000000000 crc d3 [ 1237.590931] w1_master_driver w1_bus_master1: Family 0 for 00.980000000000.d3 is not registered. [ 1283.465783] w1_master_driver w1_bus_master1: Attaching one wire slave 00.580000000000 crc 19 [ 1283.472311] w1_master_driver w1_bus_master1: Family 0 for 00.580000000000.19 is not registered. [ 1331.134640] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d80000000000 crc 95 [ 1331.140569] w1_master_driver w1_bus_master1: Family 0 for 00.d80000000000.95 is not registered. [ 1355.295052] w1_master_driver w1_bus_master1: Attaching one wire slave 00.380000000000 crc 7c [ 1355.301015] w1_master_driver w1_bus_master1: Family 0 for 00.380000000000.7c is not registered. [ 1401.263815] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b80000000000 crc f0 [ 1401.269638] w1_master_driver w1_bus_master1: Family 0 for 00.b80000000000.f0 is not registered. [ 1460.613998] w1_master_driver w1_bus_master1: Attaching one wire slave 00.780000000000 crc 3a [ 1460.623177] w1_master_driver w1_bus_master1: Family 0 for 00.780000000000.3a is not registered. [ 1508.269479] w1_master_driver w1_bus_master1: Attaching one wire slave 00.f80000000000 crc b6 [ 1508.275477] w1_master_driver w1_bus_master1: Family 0 for 00.f80000000000.b6 is not registered. [ 1566.259014] w1_master_driver w1_bus_master1: Attaching one wire slave 00.040000000000 crc 61 [ 1566.266563] w1_master_driver w1_bus_master1: Family 0 for 00.040000000000.61 is not registered. [ 1614.675262] w1_master_driver w1_bus_master1: Attaching one wire slave 00.840000000000 crc ed [ 1614.681407] w1_master_driver w1_bus_master1: Family 0 for 00.840000000000.ed is not registered. [ 1673.243833] w1_master_driver w1_bus_master1: Attaching one wire slave 00.440000000000 crc 27 [ 1673.249694] w1_master_driver w1_bus_master1: Family 0 for 00.440000000000.27 is not registered. [ 1720.024472] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c40000000000 crc ab [ 1720.030365] w1_master_driver w1_bus_master1: Family 0 for 00.c40000000000.ab is not registered. [ 1743.204900] w1_master_driver w1_bus_master1: Attaching one wire slave 00.240000000000 crc 42 [ 1743.211094] w1_master_driver w1_bus_master1: Family 0 for 00.240000000000.42 is not registered. [ 1801.818256] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a40000000000 crc ce [ 1801.825776] w1_master_driver w1_bus_master1: Family 0 for 00.a40000000000.ce is not registered. [ 1826.570166] w1_master_driver w1_bus_master1: Attaching one wire slave 00.640000000000 crc 04 [ 1826.575799] w1_master_driver w1_bus_master1: Family 0 for 00.640000000000.04 is not registered. [ 1873.306830] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e40000000000 crc 88 [ 1873.313309] w1_master_driver w1_bus_master1: Family 0 for 00.e40000000000.88 is not registered. [ 1931.903404] w1_master_driver w1_bus_master1: Attaching one wire slave 00.140000000000 crc fc [ 1931.909127] w1_master_driver w1_bus_master1: Family 0 for 00.140000000000.fc is not registered. [ 1967.740962] w1_master_driver w1_bus_master1: Attaching one wire slave 00.940000000000 crc 70 [ 1967.750266] w1_master_driver w1_bus_master1: Family 0 for 00.940000000000.70 is not registered. [ 2037.280620] w1_master_driver w1_bus_master1: Attaching one wire slave 00.540000000000 crc ba [ 2037.286595] w1_master_driver w1_bus_master1: Family 0 for 00.540000000000.ba is not registered. [ 2084.890718] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d40000000000 crc 36 [ 2084.899901] w1_master_driver w1_bus_master1: Family 0 for 00.d40000000000.36 is not registered. [ 2156.095202] w1_master_driver w1_bus_master1: Attaching one wire slave 00.340000000000 crc df [ 2156.101045] w1_master_driver w1_bus_master1: Family 0 for 00.340000000000.df is not registered. [ 2202.016954] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b40000000000 crc 53 [ 2202.024525] w1_master_driver w1_bus_master1: Family 0 for 00.b40000000000.53 is not registered. [ 2237.818316] w1_master_driver w1_bus_master1: Attaching one wire slave 00.740000000000 crc 99 [ 2237.827495] w1_master_driver w1_bus_master1: Family 0 for 00.740000000000.99 is not registered. [ 2285.430112] w1_master_driver w1_bus_master1: Attaching one wire slave 00.f40000000000 crc 15 [ 2285.435977] w1_master_driver w1_bus_master1: Family 0 for 00.f40000000000.15 is not registered. [ 2343.519916] w1_master_driver w1_bus_master1: Attaching one wire slave 00.0c0000000000 crc a3 [ 2343.526649] w1_master_driver w1_bus_master1: Family 0 for 00.0c0000000000.a3 is not registered. [ 2391.853559] w1_master_driver w1_bus_master1: Attaching one wire slave 00.8c0000000000 crc 2f [ 2391.862673] w1_master_driver w1_bus_master1: Family 0 for 00.8c0000000000.2f is not registered. [ 2427.009253] w1_master_driver w1_bus_master1: Attaching one wire slave 00.4c0000000000 crc e5 [ 2427.015645] w1_master_driver w1_bus_master1: Family 0 for 00.4c0000000000.e5 is not registered. [ 2473.778242] w1_master_driver w1_bus_master1: Attaching one wire slave 00.cc0000000000 crc 69 [ 2473.784744] w1_master_driver w1_bus_master1: Family 0 for 00.cc0000000000.69 is not registered. [ 2496.842353] w1_master_driver w1_bus_master1: Attaching one wire slave 00.2c0000000000 crc 80 [ 2496.848331] w1_master_driver w1_bus_master1: Family 0 for 00.2c0000000000.80 is not registered. [ 2555.408580] w1_master_driver w1_bus_master1: Attaching one wire slave 00.ac0000000000 crc 0c [ 2555.415890] w1_master_driver w1_bus_master1: Family 0 for 00.ac0000000000.0c is not registered. [ 2603.884316] w1_master_driver w1_bus_master1: Attaching one wire slave 00.6c0000000000 crc c6 [ 2603.890262] w1_master_driver w1_bus_master1: Family 0 for 00.6c0000000000.c6 is not registered. [ 2650.613148] w1_master_driver w1_bus_master1: Attaching one wire slave 00.ec0000000000 crc 4a [ 2650.619205] w1_master_driver w1_bus_master1: Family 0 for 00.ec0000000000.4a is not registered. [ 2709.155413] w1_master_driver w1_bus_master1: Attaching one wire slave 00.1c0000000000 crc 3e [ 2709.164588] w1_master_driver w1_bus_master1: Family 0 for 00.1c0000000000.3e is not registered. [ 2745.016024] w1_master_driver w1_bus_master1: Attaching one wire slave 00.9c0000000000 crc b2 [ 2745.025158] w1_master_driver w1_bus_master1: Family 0 for 00.9c0000000000.b2 is not registered. [ 2790.984781] w1_master_driver w1_bus_master1: Attaching one wire slave 00.5c0000000000 crc 78 [ 2790.993984] w1_master_driver w1_bus_master1: Family 0 for 00.5c0000000000.78 is not registered. [ 2838.616666] w1_master_driver w1_bus_master1: Attaching one wire slave 00.dc0000000000 crc f4 [ 2838.623070] w1_master_driver w1_bus_master1: Family 0 for 00.dc0000000000.f4 is not registered. [ 2909.653619] w1_master_driver w1_bus_master1: Attaching one wire slave 00.3c0000000000 crc 1d [ 2909.659207] w1_master_driver w1_bus_master1: Family 0 for 00.3c0000000000.1d is not registered. [ 2955.667376] w1_master_driver w1_bus_master1: Attaching one wire slave 00.bc0000000000 crc 91 [ 2955.674685] w1_master_driver w1_bus_master1: Family 0 for 00.bc0000000000.91 is not registered. [ 3015.127169] w1_master_driver w1_bus_master1: Attaching one wire slave 00.7c0000000000 crc 5b [ 3015.133061] w1_master_driver w1_bus_master1: Family 0 for 00.7c0000000000.5b is not registered. [ 3062.731951] w1_master_driver w1_bus_master1: Attaching one wire slave 00.fc0000000000 crc d7 [ 3062.737811] w1_master_driver w1_bus_master1: Family 0 for 00.fc0000000000.d7 is not registered. [ 3085.180293] w1_master_driver w1_bus_master1: Attaching one wire slave 00.020000000000 crc bc [ 3085.186235] w1_master_driver w1_bus_master1: Family 0 for 00.020000000000.bc is not registered. [ 3120.996817] w1_master_driver w1_bus_master1: Attaching one wire slave 00.820000000000 crc 30 [ 3121.002685] w1_master_driver w1_bus_master1: Family 0 for 00.820000000000.30 is not registered. [ 3180.465728] w1_master_driver w1_bus_master1: Attaching one wire slave 00.420000000000 crc fa [ 3180.471665] w1_master_driver w1_bus_master1: Family 0 for 00.420000000000.fa is not registered. [ 3227.978446] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c20000000000 crc 76 [ 3227.985100] w1_master_driver w1_bus_master1: Family 0 for 00.c20000000000.76 is not registered. [ 3309.320910] w1_master_driver w1_bus_master1: Attaching one wire slave 00.220000000000 crc 9f [ 3309.330184] w1_master_driver w1_bus_master1: Family 0 for 00.220000000000.9f is not registered. [ 3345.124197] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a20000000000 crc 13 [ 3345.130176] w1_master_driver w1_bus_master1: Family 0 for 00.a20000000000.13 is not registered. [ 3381.024729] w1_master_driver w1_bus_master1: Attaching one wire slave 00.620000000000 crc d9 [ 3381.030641] w1_master_driver w1_bus_master1: Family 0 for 00.620000000000.d9 is not registered. [ 3438.733732] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e20000000000 crc 55 [ 3438.739413] w1_master_driver w1_bus_master1: Family 0 for 00.e20000000000.55 is not registered. [ 3474.839350] w1_master_driver w1_bus_master1: Attaching one wire slave 00.120000000000 crc 21 [ 3474.848520] w1_master_driver w1_bus_master1: Family 0 for 00.120000000000.21 is not registered. [ 3533.467650] w1_master_driver w1_bus_master1: Attaching one wire slave 00.920000000000 crc ad [ 3533.475242] w1_master_driver w1_bus_master1: Family 0 for 00.920000000000.ad is not registered. [ 3592.079815] w1_master_driver w1_bus_master1: Attaching one wire slave 00.520000000000 crc 67 [ 3592.085701] w1_master_driver w1_bus_master1: Family 0 for 00.520000000000.67 is not registered. [ 3638.896493] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d20000000000 crc eb [ 3638.902422] w1_master_driver w1_bus_master1: Family 0 for 00.d20000000000.eb is not registered. [ 3651.693922] w1_master_driver w1_bus_master1: Attaching one wire slave 00.320000000000 crc 02 [ 3651.703123] w1_master_driver w1_bus_master1: Family 0 for 00.320000000000.02 is not registered. [ 3710.317520] w1_master_driver w1_bus_master1: Attaching one wire slave 00.b20000000000 crc 8e [ 3710.323562] w1_master_driver w1_bus_master1: Family 0 for 00.b20000000000.8e is not registered. [ 3745.386025] w1_master_driver w1_bus_master1: Attaching one wire slave 00.720000000000 crc 44 [ 3745.391997] w1_master_driver w1_bus_master1: Family 0 for 00.720000000000.44 is not registered. pi@orangepizero:~$
lagerschaden Posted November 17, 2020 Author Posted November 17, 2020 Now I removed the DS18B20 from the Orange Pi zero and Uuups: pi@orangepizero:~$ ls -l /sys/bus/w1/devices/ total 0 lrwxrwxrwx 1 root root 0 Nov 17 17:33 00-100000000000 -> ../../../devices/w1_bus_master1/00-100000000000 lrwxrwxrwx 1 root root 0 Nov 17 17:34 00-500000000000 -> ../../../devices/w1_bus_master1/00-500000000000 lrwxrwxrwx 1 root root 0 Nov 17 17:33 00-900000000000 -> ../../../devices/w1_bus_master1/00-900000000000 lrwxrwxrwx 1 root root 0 Nov 17 17:25 w1_bus_master1 -> ../../../devices/w1_bus_master1 pi@orangepizero:~$ dmesg | grep w1 [ 10.748887] w1-gpio onewire@0: there is not valid maps for state default [ 13.130265] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search. [ 59.998244] w1_master_driver w1_bus_master1: Attaching one wire slave 00.800000000000 crc 8c [ 60.004443] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered. [ 118.654109] w1_master_driver w1_bus_master1: Attaching one wire slave 00.400000000000 crc 46 [ 118.660629] w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46 is not registered. [ 165.419201] w1_master_driver w1_bus_master1: Attaching one wire slave 00.c00000000000 crc ca [ 165.425341] w1_master_driver w1_bus_master1: Family 0 for 00.c00000000000.ca is not registered. [ 235.897723] w1_master_driver w1_bus_master1: Attaching one wire slave 00.200000000000 crc 23 [ 235.906918] w1_master_driver w1_bus_master1: Family 0 for 00.200000000000.23 is not registered. [ 294.510450] w1_master_driver w1_bus_master1: Attaching one wire slave 00.a00000000000 crc af [ 294.519639] w1_master_driver w1_bus_master1: Family 0 for 00.a00000000000.af is not registered. [ 329.522339] w1_master_driver w1_bus_master1: Attaching one wire slave 00.600000000000 crc 65 [ 329.530005] w1_master_driver w1_bus_master1: Family 0 for 00.600000000000.65 is not registered. [ 366.223328] w1_master_driver w1_bus_master1: Attaching one wire slave 00.e00000000000 crc e9 [ 366.232760] w1_master_driver w1_bus_master1: Family 0 for 00.e00000000000.e9 is not registered. [ 424.435951] w1_master_driver w1_bus_master1: Attaching one wire slave 00.100000000000 crc 9d [ 424.445176] w1_master_driver w1_bus_master1: Family 0 for 00.100000000000.9d is not registered. [ 460.228297] w1_master_driver w1_bus_master1: Attaching one wire slave 00.900000000000 crc 11 [ 460.237421] w1_master_driver w1_bus_master1: Family 0 for 00.900000000000.11 is not registered. [ 529.876961] w1_master_driver w1_bus_master1: Attaching one wire slave 00.500000000000 crc db [ 529.886380] w1_master_driver w1_bus_master1: Family 0 for 00.500000000000.db is not registered. [ 577.468995] w1_master_driver w1_bus_master1: Attaching one wire slave 00.d00000000000 crc 57 [ 577.474916] w1_master_driver w1_bus_master1: Family 0 for 00.d00000000000.57 is not registered. [ 601.542743] w1_master_driver w1_bus_master1: Attaching one wire slave 00.300000000000 crc be [ 601.551880] w1_master_driver w1_bus_master1: Family 0 for 00.300000000000.be is not registered. pi@orangepizero:~$ "Zombie" 1-wire-devices ??? L.
martinayotte Posted November 17, 2020 Posted November 17, 2020 10 minutes ago, lagerschaden said: [ 10.918414] w1-gpio onewire@0: there is not valid maps for state default This line looks strange ... Can you try PA7 (pin 12) instead, and look again at /sys/kernel/debug/gpio ?
lagerschaden Posted November 17, 2020 Author Posted November 17, 2020 I tried other pins and other DS18B20 and there was the same issue. Same issue with an Orange Pi one. Then I tested two Rasperries -> everything is ok. I will switch to a Raspberry. L.
martinayotte Posted November 17, 2020 Posted November 17, 2020 2 minutes ago, lagerschaden said: I tried other pins and other DS18B20 and there was the same issue. Try using external 4K7 pullup instead of internal one ... BTW, which kernel are you using ?
lagerschaden Posted November 17, 2020 Author Posted November 17, 2020 I tried also external and internal pullup, Kernel is Armbian 20.08.17 Bionic with Linux 5.8.16-sunxi L.
