I am going to use your Banana Pi image for my media server image release.
I would like to know how to re-enable the regenerate ssh keys and resize the SD card on first boot (I want the password to stay the same).
Script firstrun /etc/inid.d/firstrun
To re-enable it:
 update-rc.d firstrun defaults
This will keep the password which you set at first login.
If you want to force users to change (root) password in next login use:
chage -d 0 root
There is also an option to use my script for generating a custom distribution.
I am using one parameter for this:
AFTERINSTALL=""                             # command before closing image
So if you put everything in one script you run this script here or just download additional packages with apt-get ...
In this case you will have the same startup procedure as mine - same root pwd, shrunk install image, auto expand, ...
And if I want to build an image that uses a different default password, where would I change the default 1234?
Also thanks for adding the AFTERINSTALL (I requested it on github) as it will make building my media image much easier :)
Main call /configuration script ?  :)
ROOTPWD="1234"                              # forced to change @first login
lol of course, I remembered the configuration file looking different. Will build an image later today hopefully with modular PMP support and report back to you
  • Igor unlocked this topic
