[Lime/next/jessie/console] Armbian compilation stops
Hello
All in blue ...it's ok
but in red ....not ok
i started by
Clonage dans 'lib'...
remote: Counting objects: 1075, done.
remote: Compressing objects: 100% (935/935), done.
remote: Total 1075 (delta 155), reused 806 (delta 70), pack-reused 0
Réception d'objets: 100% (1075/1075), 50.19 MiB | 1.06 MiB/s, fait.
Résolution des deltas: 100% (155/155), fait.
Vérification de la connectivité... fait.
OK ! After i copy  compile.sh in my directory
and GO! ./compile.sh
I choose "full os image to generate a sdcard ... board LIME ....Next lastest stable @kernel.org....jessie debian8 .......image with console interface"
I résume
Compiling U-BOOT OK ( no error nowhere )
Compiling Kernel OK ( no error nowhere )
Creating kernel package OK
[ o.k. ] Creating board support package [ lime next ]
[ o.k. ] Fingerprinting [ Armbian 5.17 Lime Debian jessie next ]
[ o.k. ] Building package [ linux-jessie-root-next-lime ]
[ o.k. ] Starting build process for [ lime jessie ]
[ o.k. ] Creating new rootfs for [ jessie ]
[ o.k. ] Installing base system [ Stage 1/2 ]
But here
 Debootstrap (stage 1/2)...
  I: Retrieving InRelease
  I: Failed to retrieve InRelease
  I: Retrieving Release
After
cp: impossible de créer le fichier standard '/home/pascal/helixee/newversion/output/cache/sdcard/usr/bin/': Aucun fichier ou dossier de ce type
[ o.k. ] Installing base system [ Stage 2/2 ]
translation : cp: can't create the file 'home/pascal/helixee/newversion/output/cache/sdcard/usr/bin/'  No file or no directory
Debootstrap (stage 2/2)...
chroot: failed to run command ‘/bin/bash’: No such file or directory
and finally ...........
[ error ] ERROR in function create_rootfs_cache [ debootstrap-ng.sh:166 ]
[ error ] Debootstrap base system second stage failed
[ o.k. ] Process terminated
[ error ] ERROR in function unmount_on_exit [ debootstrap-ng.sh:553 ]
[ error ] debootstrap-ng was interrupted
What's wrong ? I suppose that's in 1st stage of debootstrap   ( debootstrap.sh) but what and where ?  For information few day ago i done this with u-boot 2016-05 an kernel V4.6.2  ( for the same board ) and all was good
Thank you for your help
Hello everybody ....
The never ending story  :)
And today new U-BOOT ... V2016-07
New problem
When compiling U-boot , It stop here
 Compiling u-boot...        â”‚
  │   CC      arch/arm/cpu/armv7/cache_v7.o        â”‚
  │   CC      arch/arm/lib/bootm-fdt.o        │
  │   AS      arch/arm/cpu/armv7/cache_v7_asm.o        â”‚
  │   CC      arch/arm/lib/bootm.o        │
  │   CC      arch/arm/cpu/armv7/cpu.o        │
  │   CC      arch/arm/cpu/armv7/cp15.o        â”‚
  │   CC      arch/arm/mach-sunxi/clock.o        â”‚
  │   CC      arch/arm/lib/sections.o        â”‚
  │   CC      arch/arm/cpu/armv7/syslib.o        â”‚
  │   CC      arch/arm/mach-sunxi/cpu_info.o        │
  │   CC      arch/arm/lib/stack.o        │
  │   CC      arch/arm/mach-sunxi/dram_helpers.o        │
  │   AS      arch/arm/cpu/armv7/lowlevel_init.o        │
  │   AS      arch/arm/cpu/armv7/nonsec_virt.o        │
  │   CC      arch/arm/cpu/armv7/virt-v7.o        │
  │   CC      arch/arm/lib/interrupts.o        â”‚
  │   CC      arch/arm/cpu/armv7/virt-dt.o        │
  │   CC      arch/arm/mach-sunxi/pinmux.o        │
  │   AS      arch/arm/cpu/armv7/psci.o        â”‚
  │   CC      arch/arm/mach-sunxi/usb_phy.o        â”‚
  │   CC      arch/arm/cpu/armv7/sunxi/timer.o        │
  │   CC      arch/arm/lib/reset.o        │
  │   CC      arch/arm/cpu/armv7/sunxi/psci.o        â”‚
  │   CC      arch/arm/lib/cache.o        │
  │   CC      arch/arm/mach-sunxi/clock_sun4i.o        â”‚
  │   CC      arch/arm/mach-sunxi/pmic_bus.o        │
  │   CC      arch/arm/lib/cache-cp15.o        â”‚
  │   AS      arch/arm/lib/ashldi3.o        │
  │   AS      arch/arm/lib/ashrdi3.o        │
  │   LD      arch/arm/mach-sunxi/built-in.o        │
  │   CC      arch/arm/lib/div0.o        â”‚
  │   CC      board/sunxi/board.o        â”‚
  │   AS      arch/arm/lib/div64.o        │
  │   AS      arch/arm/lib/lib1funcs.o        │
  │   AS      arch/arm/lib/lshrdi3.o        │
  │   AS      arch/arm/lib/muldi3.o        â”‚
  │ scripts/Makefile.build:425 : la recette pour la cible « arch/arm/cpu/armv7/sunxi » a échouée    ( the recipe for the target   Â« arch/arm/cpu/armv7/sunxi » fail )        â”‚
  │ Makefile:1210 : la recette pour la cible « arch/arm/cpu/armv7 » a échouée       ( the recipe for the target    Â« arch/arm/cpu/armv7 » fail )        â”‚
  │   CC      arch/arm/lib/eabi_compat.o        │
  │   CC      board/sunxi/ahci.o        │
  │   CC      board/sunxi/dram_sun5i_auto.o        â”‚
  │   LD      arch/arm/lib/built-in.o        â”‚
  │   AR      arch/arm/lib/lib.a        │
  │   LD      board/sunxi/built-in.o        │
*** [arch/arm/cpu/armv7] Erreur 2psci.o] Erreur
                                 make: *** Attente des tâches non terminées....v7/sunxi] Erreur 2rge {reglist}^ -- `pop {r0,r1,r2,r3,r4,r9,ip,pc}^'
[ error ] ERROR in function compile_uboot [ common.sh:94 ]
[ error ] U-boot file not found [ u-boot-sunxi-with-spl.bin ]
If someone can help me i will be sympatic
Thank you
I have one question .... Is it possible to force armbian script working with one kernel version and one u-boot version , downloading all needed on Hard disk and working only with this parameters without trying download anythings else ( Where i'll go for holydays there is no wifi, no network access ) :(
Thank you
New problem
New u-boot issue will be fixed (or u-boot version will be reverted to v2016.05). Meanwhile you can try setting
BOOTBRANCH="v2016.05"
in userpatches/lib.config
It can be done manually by disabling update procedures and building of additional applications and drivers.
Thanks a lot ZADOR !
I modify to have only uboot v2016-05
And now for u-boot it's ok .... But I already have my 1st problem ......I work on ununtu 16LTS  8GO ram Two core intel
Uboot  and kernel compile ok but when armbian want to download debootstrap file i have an error ... I dont know if it's my computer or anything else ....an update of my computer ?  server down ?
Can you provide output of
systemctl status -l apt-cacher-ng
And please building after adding
NO_APT_CACHER=yes
to compile.sh
Desktop or Server? Native or in the VM (Virtualbox, VMWare, ...)?
Hello
My computer is a desktop , ubuntu version too  native ( no virtualbox ..... ) .... If i remember , Ubuntu ask me to do some security updates 2/3 week ago ... But i don't know which pakage ...
Terminal output for "systemctl status -l apt-cacher-ng"
pascal@NTDEV:~$ systemctl status -l apt-cacher-ng
â— apt-cacher-ng.service - Apt-Cacher NG software download proxy
   Loaded: loaded (/lib/systemd/system/apt-cacher-ng.service; enabled; vendor pr
   Active: inactive (dead) (Result: exit-code) since mer. 2016-07-13 19:08:40 CE
  Process: 1459 ExecStart=/usr/sbin/apt-cacher-ng SocketPath=/run/apt-cacher-ng/
 Main PID: 1459 (code=exited, status=1/FAILURE)
juil. 13 19:08:40 NTDEV systemd[1]: apt-cacher-ng.service: Main process exited,
juil. 13 19:08:40 NTDEV systemd[1]: Failed to start Apt-Cacher NG software downl
juil. 13 19:08:40 NTDEV systemd[1]: apt-cacher-ng.service: Unit entered failed s
juil. 13 19:08:40 NTDEV systemd[1]: apt-cacher-ng.service: Failed with result 'e
juil. 13 19:08:40 NTDEV systemd[1]: apt-cacher-ng.service: Service hold-off time
juil. 13 19:08:40 NTDEV systemd[1]: Stopped Apt-Cacher NG software download prox
juil. 13 19:08:40 NTDEV systemd[1]: apt-cacher-ng.service: Start request repeate
lines 1-14/14 (END)
Thanks again for your help !!! you're cool !!! :)
I try NO_APT_CACHER=yes  and i do a "./compile.sh" to test
It's better ! It's still good but just before the "end" of process i have ....
 Get:217 http://httpredir.debian.org/debian/jessie/main lirc armhf 0.9.0~pre1-1.2 [348 kB]        │
  │ Get:218 http://httpredir.debian.org/debian/jessie/main sysbench armhf 0.4.12-1.1 [57.1 kB]        â”‚
  │ Get:219 http://httpredir.debian.org/debian/jessie/main sysfsutils armhf 2.1.0+repack-4 [23.5 kB]        â”‚
  │ Get:220 http://httpredir.debian.org/debian/jessie/main wireless-tools armhf 30~pre9-8 [130 kB]        â”‚
  │ Get:221 http://httpredir.debian.org/debian/jessie/main hddtemp armhf 0.3-beta15-52 [60.1 kB]        â”‚
  │ Get:222 http://httpredir.debian.org/debian/jessie/main stress armhf 1.0.1-1+deb8u1 [18.5 kB]        â”‚
  │ Fetched 106 MB in 1min 3s (1667 kB/s)        â”‚
led to fetch http://httpredir.debian.org/debian/pool/main/u/u-boot/u-boot-tools_2014.10+dfsg1-5_armhf.deb Error reading from server. Remote end closed connection [iP: 128.31.0.66 80]──────────┘
        E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Free space:
tmpfs                         1,5G    453M  1,1G  31% /home/pascal/helixee2/version1/output/cache/sdcard
[ o.k. ] Ending debootstrap process and preparing cache [ jessie ]
jessie-ng-armhf.d11...b44.tgz:  250MiO [38,5MiB/s] [============================================================================================================================================] 108%
[ o.k. ] Applying distribution specific tweaks for [ jessie ]
sed: impossible de lire /home/pascal/helixee2/version1/output/cache/sdcard/etc/ssh/sshd_config: Aucun fichier ou dossier de ce type
[ o.k. ] Applying common tweaks
sed: impossible de lire /home/pascal/helixee2/version1/output/cache/sdcard/etc/default/console-setup: Aucun fichier ou dossier de ce type
[ o.k. ] Installing kernel [ linux-image-next-sunxi ]
[ o.k. ] Installing u-boot [ linux-u-boot-next-lime ]
[ o.k. ] Installing headers [ linux-headers-next-sunxi ]
[ o.k. ] Installing DTB [ linux-dtb-next-sunxi ]
[ o.k. ] Installing board support package [ lime ]
sed: impossible de lire /home/pascal/helixee2/version1/output/cache/sdcard/etc/lirc/hardware.conf: Aucun fichier ou dossier de ce type
cp: impossible de créer le fichier standard '/home/pascal/helixee2/version1/output/cache/sdcard/etc/lirc/lircd.conf': Aucun fichier ou dossier de ce type
[ o.k. ] Installing extra applications and drivers
[ o.k. ] Merging and packaging linux firmware [ @host ]
[ o.k. ] Installing linux firmware [ 5.17 ]
[ o.k. ] Building deb [ hostapd ]
[ o.k. ] Downloading sources [ hostapd ]
[ o.k. ] Compiling hostapd [ v2.5 ]
[ error ] ERROR in function compiling [ hostapd.sh:72 ]
[ error ] Error building [ hostapd ]
[ error ] ERROR in function unmount_on_exit [ debootstrap-ng.sh:555 ]
translation "impossible de lire " = "can't read "
                  "Aucun fichier ou dossier de ce type" = " No files or directory with this name "
To help you the content of Output.log
Displaying message: Preparing host info
Displaying message: Build host OS release xenial info
## BUILD CONFIGURATION
Config: linux-sunxi-next
Kernel source: git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git
Branch: v4.6.4
linuxsource: linux-vanilla
Offset: 1
bootsize: 0
bootloader: git://git.denx.de/u-boot.git
bootsource: u-boot
bootbranch: v2016.05
CPU 480000 / 960000 with ondemand
13.07.2016 19:19:43 Armbian 5.17 Lime Debian jessie next
Displaying message: Starting Armbian build script @host info
Displaying message: Building Armbian 5.17 Lime Debian jessie next info
Displaying message: Syncing clock host info
Displaying message: source downloading @host info
Displaying message: ... you have latest sources u-boot v2016.05 info
Displaying message: ... you have latest sources linux-vanilla v4.6.4 info
Displaying message: ... you have latest sources sunxi-tools  info
Displaying message: ... you have latest sources sunxi-display-changer  info
Displaying message: Compiling sunxi tools @host & target info
Displaying message: Cleaning u-boot/v2016.05 info
Displaying message: Cleaning linux-vanilla/v4.6.4 info
Displaying message: Cleaning /home/pascal/helixee2/version1/output/debs for lime next info
Displaying message: Started patching process for u-boot u-boot-next 2016.05 info
Displaying message: Looking for user patches in userpatches/u-boot/u-boot-next info
Displaying message: ... add-awsom-uboot.patch succeeded info
Displaying message: ... add-cubieboard4.patch succeeded info
Displaying message: ... u-boot-02-support-cheap-mmc.patch succeeded info
Displaying message: Compiling uboot 2016.05 info
Displaying message: Compiler version arm-linux-gnueabihf-gcc 5.3.1 info
Displaying message: Target directory /home/pascal/helixee2/version1/output/debs/ info
Displaying message: Building deb linux-u-boot-next-lime_5.17_armhf.deb info
Displaying message: Started patching process for kernel sunxi-next 4.6.4 info
Displaying message: Looking for user patches in userpatches/kernel/sunxi-next info
Displaying message: ... 01-wens-banana-m1plus.patch succeeded info
Displaying message: ... axp20x-sysfs-interface.patch succeeded info
Displaying message: ... b53_switch.kernel_4.5+.patch succeeded info
Displaying message: ... bananapipro-wifi-codec-led-fix.patch succeeded info
Displaying message: ... bash_to_afterinstall.patch succeeded info
Displaying message: ... cubieboard_enable_mmc0_trigger_to_green_LED.patch succeeded info
Displaying message: ... cubietruck-enable-uart2.patch succeeded info
Displaying message: ... cubietruck_enable_mmc0_trigger_to_green_LED.patch succeeded info
Displaying message: ... linux-vanilla_v4.5.1_sun7i-a20-bananapro_dts.patch succeeded info
Displaying message: ... packaging-4.x-NEXT-with-postinstall-scripts.patch succeeded info
Displaying message: ... spi_allow_transfer_larger.patch succeeded info
Displaying message: ... support_for_second_mmc_cubieboard2.patch succeeded info
Displaying message: Compiling next kernel 4.6.4 info
Displaying message: Using kernel config file lib/config/kernel/linux-sunxi-next.config info
Displaying message: Creating board support package lime next info
Displaying message: Fingerprinting Armbian 5.17 Lime Debian jessie next info
Displaying message: Building package linux-jessie-root-next-lime info
Displaying message: Starting build process for lime jessie info
Displaying message: Creating new rootfs for jessie info
Displaying message: Installing base system Stage 1/2 info
Displaying message: Installing base system Stage 2/2 info
Displaying message: ERROR in function create_rootfs_cache debootstrap-ng.sh:168 err
Displaying message: Debootstrap base system second stage failed  err
Displaying message: Process terminated  info
Displaying message: ERROR in function unmount_on_exit debootstrap-ng.sh:555 err
Displaying message: debootstrap-ng was interrupted  err
Do you have a " magic" variable or command  to résolve this problem ?
Thanks
This is either a network problem or autoselected mirror problem, and this is when apt-cacher is useful, but for some reason it doesn't start properly on your system.
First, you need to delete cache files from output/cache/rootfs
After that, try reinstalling apt-cacher-ng
sudo apt-get purge apt-cacher-ng; sudo apt-get install apt-cacher-ng
sudo systemctl start apt-cacher-ng
And building without NO_APT_CACHER=yes
If there are errors still, you will need to find Debian mirror that will work for you and put it in userpatches/lib.config like this:
DEBIAN_MIRROR='ftp2.fr.debian.org/debian'
or
DEBIAN_MIRROR='ftp.fr.debian.org/debian'
and use this setting with NO_APT_CACHER=yes
Hello
I try to uninstall apt-cacher-ng  and  install it again ... and remove NO_APT_CACHER=yes
No change
I try to find "userpatches/lib.config" somewhere .....but i didn't find it
But after looking error message a long time , i tell me that apt-cacher-ng wasn't the problem ( perhaps )
Too much error when compiling extra application ( hostapd , lirc etc ).
I set in compile.sh  the parameter EXTERNAL="no" instead of "yes" , save it, and run compile.sh
A miracle append !!! All compilation process finished ... I try after rebooting my computer , with and without lot of running applications( chromium , thunderbird , geany, xfe, etc ...)
It work well all the time ....I can obtain my image.raw exepting external applications .... It's a solution , not the most beautiful but it's one
Perhaps there is something to adjust in the compiling "external application" script ....or not ....i don't know but for me it's good
I must tell to the Armbian community something .
Igor, you ( Zador ) and all the team inside this forum are wonderful peoples , your work is amazing .
And if you haven't the solution your can give some way to investigate .... :thumbup:
Thanks you for all and to be patient with newbies like me ...and with my bad english too  :)
I dont like virtualbox ....but if i must use it ...i ll use it .....but compilation time will explose !!   :D
@Pascal
As zador.blood.stain does, you can use a spare low-end laptop to install a fresh Ubuntu 14.04 or 16.04 and dedicate the laptop for this.
Zador.blood.stain has spent a lot of time to optimize the processes (like ccache to reduce compilation time) so Armbian tool is affordable for many users around the world.
Zador.blood.stain -- yes cheers up :beer:
