Good afternoon dear gurus. help to transfer please system with sdcard to sata hdd in OrangePI +2. Debian jessy and additional software is established. what needs to be made? if it is possible, then on steps. the point is that I want to refuse completely loading with sdcard and emmc. To be loaded only with sata hdd.
Thanks in advance.
No go. At minimum you need to load u-boot from emmc / sd.
if now the system is installed on sdcard, then having chosen option boot from SD, system on SATA/USB, the same sdcard for storage of the loader will be used? I will be able to transfer then the loader to sdcard of the smaller size? if I am able, then how then to transfer the loader?
Image 1MB of the old SDcard to the new SDcard. This contains the loader.
On Linux as root :
stick in old SDcard, check device with lsblk ( e.g. /dev/sdb )
dd if=/dev/sdb of=loader.img bs=1M count=1
eject sdcard, stick in new SDcard, check device with lsblk ( e.g. /dev/sdb )
dd if=loader.img of=/dev/sdb
